Rori Posted May 7, 2020 Share Posted May 7, 2020 (edited) SOLD Item Condition: 8.5/10 Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Emerald State: Victoria Payment Method: Cash, EFT, Paypal Reason for selling: NLR Further information: 2 years old, purchased from Big Picture People Narre Warren. Plenty of reviews online about this subwoofer. It has 2 x 12" drivers opposing each other to cancel out vibrations. The outcome is clear, low distortion and clean bass. The customization for best in room response from the amp is second to none with low pass filtering, phase alignment, gain and when measuring with the PBK kit (supplied) can give close to perfectly flat frequency response. This sub looks amazing especially in piano gloss black. Can ship however it does weigh 65kg's... I have all boxes and accessories for it. See specs and pics below. Specs: BalancedForce 212 System Frequency Response 18–120 Hz ±3dB; Anechoic through LFE effects input 20–120 Hz ±3dB; Low Pass Filter Frequencies 30 - 80Hz Phase 0°, 90°, 180°, 270° 0° 25Hz Level Control ±10dB at 25Hz ±10dB at 25Hz Power Control On, Auto (12V Trigger), Off On, Auto (12V Trigger), Off Room Correction Perfect Bass Kit (PBK) Ready (Sold Separately) Woofers Two 12" (30.5cm) cast-basket, highexcursion, aluminum cone with extended throw driver assembly, sealed non-resonant asymmetrical chamber format Amplifiers 2 x 850 watts (3,400 watts peak system total) 850 watts (1,700 watts peak) Inputs RCA: Left, Right and LFE. XLR: Left, Right and LFE. Speaker Level: Left and Right banana jacks. 12V Trigger: 3.5mm Mini USB (for PBK) USB (for crossover & firmware updates) RCA: Left, Right and LFE. XLR: Left, Right and LFE. Speaker Level: Left and Right banana jacks. 12V Trigger: 3.5mm Mini USB (for PBK) USB (for crossover & firmware updates) Output (RCA) Multi Out (for multi-sub connection) Multi Out (for multi-sub connection) Input Impedance RCA: 10,000 Ohms XLR: 15,000 Ohms per phase Speaker Level: 10,000 Ohms per phase (20,000 Ohms red to black) Power Draw Typical: 250 Watts Idle: 30 Watts Typical: 125 Watts Idle: 15 Watts Weight 140lbs. (63.5kg) each 96lbs. (43.5kg) each Overall Dimensions HxWxD ( 57.4cm x 57.4cm x 58.2cm) Photos: Advertisements without photos of the actual item will not be approved. Edited May 16, 2020 by Rori Price drop 2 Link to comment Share on other sites More sharing options...
Presjar Posted May 16, 2020 Share Posted May 16, 2020 (edited) Hi! Sorry if this seems a low ball but i thought I would offer anyway as this is my max budget and there are not many 2nd hand units on here at the moment. $3k Delivered to QLD ? Edited May 16, 2020 by Presjar Link to comment Share on other sites More sharing options...
Rori Posted May 16, 2020 Author Share Posted May 16, 2020 No thanks, bit too low. I will price drop to 3.5k firm and if postage is required, that cost is on the buyer. Link to comment Share on other sites More sharing options...
Presjar Posted May 16, 2020 Share Posted May 16, 2020 I understand, and thanks for the counter. However I'll have to let it pass. I hope someone else will be able to pick it up. Link to comment Share on other sites More sharing options...
