chrisp78 8 Posted May 4, 2020 Share Posted May 4, 2020 Hello I'm try to hook up my yamaha rx a3040 to a external amp HK vintage pm650 to power the fronts the Yamaha part is straight forward but I'm have trouble connecting to the hk have tried all sorts of combos Any help would be appreciated Link to post Share on other sites
mbz 182 Posted May 4, 2020 Share Posted May 4, 2020 Did you try running RCA cables from RX-A3040 PRE-OUT FRONT to HK External Processor IN. I would have expected to see jumper links from Ext Pro IN/OUT, These RCA are the same as PRE_OUT/MAIN-IN on other amps, can also be used to connect a graphic EQ (=ext processor) Link to post Share on other sites
