I currently have Dynaudio Contour S1.4  and looking forward to upgrade to a floor stander. I want to try 3-way if possible. Budget - 8-10K
Associated equipment:
Mcintosh MC452 power amp
Mcintosh C46 Preamp
Sony SACD player
Denafrips Ares DAC
SoTM SMS-200
REL T5
Thank you
Magneplanar MG3.7i 😄
You have the amps and a sub
Thank you for your recommendation but i believe it's too much for my listening room :)
Forgot to mention - listening room is not big , only about 4m x 6m
Also, wouldn't want a sub if it is possible hence looking for a 3-way...
1 hour ago, Bunno77 said:
Thanks mate...this is definitely an end-game speaker. I am surprised no one in VIC has taken this yet..with this price ....
But this will be too big for my space - will be suitable for someone with big listening area with high ceiling....
Maybe aesthetically but footprint is the same as any speaker and we had them setup in a smaller room than yours at 3.7x4.9 and it was amazing, was also on your MC452. Sure a bigger room brought more from them but I wouldn't turn them down due to room if in budget and to your liking.
Plenty of other fantastic used speakers here in your budget. You'll end up with something great.
Edited by Bunno77
pic
  • Like 3
found few choices:
Sonus Faber Sonetto V -  beautiful speaker - haven't heard any Sonus Faber speakers so i am not familiar with their sound signature
Dynaudio Contour 60 - i like my Contour S1.4 , maybe this is safe choice :)
Go audition a set of Q Acoustics Concept speakers.
Either the Concept 500 (floor standing) or the Concept 300 (Stand Mount) but absolutely delicious.
Both are two-way but I think you will be presently surprised. Certainly worth checking them out if you have a local dealer...
1 hour ago, andrei said:
found few choices:
You shoukd wait for the revised Contour 60i.
https://www.dynaudio.com/home-audio/contour-i/contour-60i
Refer to the tagged speaker audition list on this forum page.
What music do you listen to ?
Your 4x6m is big enough to take large floorstanders.
For $10k used choices would get you up to $30k rrp options, but if that is not preferred consider the likes of VAF I-66 or 93, Osborne speakers and similar.
Thanks for pointing this out to me, nice reference...
Hulgich Ella's are about that price as well for more Australian made.
Edited by Rakalel
  • Like 4
My own opinion, dynaudio and mcintosh may be too laid back. Try focal and Mcintosh? Sound quite nice to me.
or keep dynaudio try a different amp.
Hulgich would be good also. The VAF speakers are using very expensive detailed sounding Seas Excel Range drivers like Excel magnesium cone $250 mids and near top of line $500 per unit tweeters vs the other model Hulgich speaker use Scanspeak HDS $170 tweeters. Ella model appears to be a $200 Satori tweeter. Both good but VAF pound for pound better on paper, greater component cost and lots of sound engineering design like time alignment of drivers and felt diffraction padding resulting in high imaging result etc.
Edited by Al.M
I recently had the opportunity to audition the latest model VAF i66 mkIII and I was shocked at how good they were. I had never been the biggest fan of the previous series, respect yes, but lust no.
  After listening to them for about 45 minutes, on a variety of my music I was enchanted.
My impressions at an older model VAF I-66 some years ago in a larger room was not as favourable as my second go in a smaller room second time around  and I was shocked at how much better they are. VAF I66 model configuration is tried and proven has been around since 1998 with significant tweeter upgrade from $170 unit to $500 model and crossover upgrades. The bass isn’t bloated and would sub match.
Edited by Al.M
The Vienna Acoustics Liszt model speakers are beyond your budget but a friend of mine bought these as his endgame speaker on retirement.  I had a chance to hear them.  It has been a long time since I heard such expensive speakers but wow! The cabinetry work is such a delight they are a pleasure just to look at without any sound.
I don't know if the Liszt's represent the house signature sound of VA so perhaps something lower down in the price range?
We had listening session with the speakers, at for me, very loud volume and they didn't even break a sweat. Later in the day they were just playing in the background while we sat around the dinner table just chatting and even at low volumes they were just wonderful to listen to.
Thank you very much Gents, keep them coming...
while in the background - i am so busy researching each and every recommendation made here so far... good thing we are stuck at home every day of the week  :)  bad thing - i cannot audition :(
Keep an eye and ear out for some Audio Physic.
Maybe touch base with 3dl3, he was maybe thinking of selling some.
  • Thanks 1
If you like the sound of the Dynaudio then Addicted to Audio have the Contour 60's on special for $8.5k down from $15k.
yes i was looking at that last week, it was $7499 then and yesterday it jumped by another $1k :(
They must have sense how many times i visited their site LOL :)
Reverse psychology them. Put it in your cart and then don't buy it, make them chase you again!
Choices you will lots of choices
You're room at 6x 4m isn't what would call small.
having had dynaudio speakers in the past , I now have Revel f208 in a 4m deep x 5m(ish) wide with a 2.4m high ceiling and they work very well in what can be a difficult room to get right. I would imagine they work perfectly we'll in your room.
I don't know how they would team up with the McIntosh, I've only listened to them with the ATC P1 amp, but give the ATC SCM40 some consideration. You definitely have the room and more than enough power.
They won't seduce you with their looks or brutally honest spec sheet but these speakers are capable of rejuvenating your music collection.
There are safer choices out there though and I wouldn't recommend buying ATC speakers without a demo.
These.
https://sydneyhifimonavale.com.au/collections/goldenear-technology/products/goldenear-triton-2-floor-standing-speakers
Narrow footprint makes them fit in small rooms too, but you'd be getting a massive sound with them, but you'd have to retire your sub as these will give you better bass than it.
Edited by Ittaku
Good evening all, i was looking around and found some interesting speakers but not available locally e.g.  Ryan Speakers and Salk Signature Sound  - anyone who has experience importing speakers especially from the US, is it worth it ?  I did research on import duties , used an online calculator and it seems not a bad idea looking at the figures....but not sure how easy or hard the process is ....
Not sure know would be the right time to be importing speaker from the USA with the slowness of the world wide post/shipping ?
The other thing to consider is aftersales service and warranty
Edited by cafe67
That's True..good point,  thanks
  • 2 weeks later...
Sorry, the speakers I wanted to trade them in for got sold. Thanks for the shout out Pops110 :)
Edited by 3dl3
  • 2 months later...
On 02/05/2020 at 1:04 PM, Ittaku said:
These.
These look great and the added sub is a bonus ,  read a couple of reviews , was getting keen until I saw that they are made in China ,  would need some convincing to part with 18K . Have you heard them yourself mate . ?
No, I've heard ones either side of this model - the reference, the one and the three (all older models as well). Given how good these were, I'm reasonably confident the 2 would be great as well. Think of the Chinese production as what's making them a bargain in hi-fi compared to other brands.
Where did you get 18k? The one I linked was the model 2+ (for the opening poster). 18k gets you the reference model and that is most definitely a fantastic sounding speaker which I have heard in its older form.
Edited by Ittaku
I have a pair of Vienna Acoustics Beethoven Concert Grand Symphony Editions (Piano Black) for sale in the Classifieds at the moment. Unlike you I have gone back to StandMounts.
Mick
 Hi Con,
Yes I was looking at wrong model ,  will check these out in my ongoing look for  a new speaker for my new room.
Loz
On 01/05/2020 at 8:33 PM, andrei said:
found few choices:
Also a big recommendation for Sonus Faber speakers.
I think Carlton audio still have a second hand pair in there for around $3500??
I saw a picture recently but they’ve taken them off their website (they have new Sonus faber on there).
I remember Auditioning that very pair, amazing a very powerful.
Too expensive for me back then.
whoever gets them for $3k is a thief.
