foolishman
Voltage conversion of Accuphase A-48
Does anyone know how to convert voltage of Accuphase A-48 100v to 220-240v? Or does anyone provide information on voltage conversion table of Accuphase A-48?
If it has a multi-tap- switch over to 240v... most don’t.
Usually a stepdown, or transformer replacement (impractical).
Take it to an experienced electronic technician, it should be a quick 5-10 min job 🤙
Yeah, owners manual I found here says
Remarks
*This product is available in versions for 120/220/230 V AC. Make sure that the voltage shown on the rear panel matches the AC line voltage in your area.
*The 230 V version has an Eco Mode that switches power off after 120 minutes of inactivity.
*The shape of the plug of the supplied AC power cord depends on the voltage rating and destination country
http://www.accuphase.com/pdf/a-48_e.pdf
So looks like you may need to get a step down transformer from Tortech in Sydney, one that will handle the supply to that beast with some over head.
Remarks
No need for a transformer, IME  Accuphase components can be setup by changing the wiring configuration.
Older models are simple whereas newer ones can be tricky and require an experienced technician.
@Conch
Good to know.
If I were Accuphase I'd have that fairly well pointed out in user manuals, or on there site, but I'm not them.
I know the older Accuphase models are multi tapped. I had always thought the newer 2000-onwards models, especially the domestic 100v units have a single 100v primary.
If the current and recent models are switchable that's good to know.
Edited by kelossus
