Happy Easter to all interesting times at the moment, I am wondering if any member have had any experience with the Cocktail Audio X45Pro ripper/streamer as I have just ordered one to look at converting my extensive CD collection and although I have read a number of reviews it appears they have limited availability in AU for some reason. I look forward to any comments you may have on this unit as I looked at a number of others but found this unit to be hopefully just what I am looking for with a straight forward easy way to store files and a playback quality at least equal to my current CD players thank you.
Hi Garry, sorry but no experience with the Cocktail Audio X45Pro.  I was looking for a ripping solution sometime ago but ended up going with a simple external CD ripper attached to my computer and using dbPoweramp as the ripping software. I ripped my collection (about 650 CDs) to FLAC.
Then went with a Roon Nucleus with 1TB SSD for storage as dedicated Core (headless computer) to run Roon.  This allows me to combine streaming with my ripped CDs with rich metadata. The Roon Nucleus outputs to Brooklyn DAC+ for ultra high quality playback, to AVR for multichannel and to Oppo for headphones. The published Roon white paper went into pros and cons of internal CD and went for external CD ripping (based on reliability).
Reading the HiFi mags Cocktail Audio seems to have come a long way in the last 3 or 5 years, so I would be interested in hearing how it performs for you and what it looks like in you system. Good luck and enjoy.
Thanks for the information KR your setup sounds like the way to go I sort of went that way originally bought a Zidoo X20Pro initially with an external drive to rip the cd's with it has two drive bays (2x5TB) tried all the file configurations but the playback sound just wasn't there. There is also no display on the Zidoo unit as such so you either use your phone or the TV to run it and really just to much trouble. So I will use this as a NAZ off the back of the Cocktail unit and apparently this will work quite well so my IT specialist son tells me and at least it then gives me a backup of all the files as well.
Will do a full report on the Cocktail unit and the final setup once I get it and installed could be a few weeks though with the way things are but I will have quite a few months ahead to fine tune while I recover cheers.
As the units in the Cocktail range offer a lot, I can only assume its in stores who understand the product, its strength (and its weaknesses).
I am not a huge fan of the GUI - it looks outdated and a little cheesy however could be streamlined using something like a universal remote.
Of course, for streaming/digital music playback, they all operate as Roon Ready endpoints so that takes care of any shortcomings in the software.
As to their performance, they sound absolutely fantastic and have excellent build quality. I recently put the N15D through its paces and really liked it:-
My dad has an N15 and made very similar comments about the GUI on the app. He’s very happy with it however otherwise.
James, (Tivoli Hifi) rang me yesterday to say he had preconfigured the unit checked all the latest firmware/software was loaded and would deliver as soon as my new Stax headphone (ear speaker system) arrived and anticipated by weeks end.  Thankyou Frank for your honest assessment of the CA product especially the audio quality as this is my biggest concern as I see no sense in taking a backward step sound wise just for convenience. As for the GUI will just have to see how that goes but couldn't be any more complicated than the Zidoo X20Pro the CODI box and the myriad of other bits that were the original system just did my head in to be honest hence the X45Pro migration.
On 14/4/2020 at 8:38 ΠΜ, Frank Prowse Hi-Fi said:
Καθώς οι μονάδες της σειράς κοκτέιλ προσφέρουν πολλά, μπορώ να υποθέσω μόνο σε καταστήματα που κατανοούν το προϊόν, τη δύναμη του (και τις αδυναμίες του).
Δεν είμαι οπαδός του GUI - φαίνεται ξεπερασμένο και λίγο τυρό, ωστόσο θα μπορούσε να βελτιωθεί χρησιμοποιώντας κάτι σαν ένα τηλεχειριστήριο.
Φυσικά, για αναπαραγωγή ροής / ψηφιακής μουσικής, όλα λειτουργούν ως τελικά σημεία Roon Ready, έτσι ώστε να αντιμετωπίζονται τυχόν ελλείψεις στο λογισμικό.
Όσον αφορά την απόδοσή τους, ακούγονται απολύτως φανταστικά και έχουν εξαιρετική ποιότητα κατασκευής. Πρόσφατα έβαλα το N15D στους ρυθμούς του και μου άρεσε πολύ:
very nice
Well I have now had the X45 Pro for several weeks in my system that comprises the following equipment Audio Analogue Maestro Stereo line SE Preamp, pair of AA Class A SE Power Amps, AA Ver 1 & 2 CD Players, Amphion Krypton 2 Speakers, Amphion Argon 2 Anniversary Speakers, 2 of Shunyata Hydra V-Ray Power Conditioners BCD cables and Interdyn interconnects mounted on Solid Steel racks.
First impressions of the X45 Pro very well made and finished nice large front screen quality feel to all the switches and dials with solid mounting of all connectors on the rear panel, unit came with a 2TD 7200 HDD and with a rudimentary read of the manual was quite easy to setup. I purchased the unit from Tivoli Hifi and James had already loaded a cd onto the drive to test and load latest firmware prior to delivery, sitting back for an initial listen I was to be honest underwhelmed by what I was hearing. To be fair the system had only been on for around an hour so this was to be expected as the amps especially take several hours to warm-up and make any listenable sounds.
In the following hours I started loading CD's onto the drive in Flac format with a very rare Hybrid copy of Elton Johns first album. At the same time I purchased the X45 Pro I also bought from James a pair of Stax SRL-007 Mk 2 head phones and a Stax SRM-007t11 driver unit as I am a long time owner of Stax equipment with two other pair. Later that night I settled back for a decent listen both through the speakers and headphones and what a difference a few hours makes, I consider my CD' players to be pretty decent units with a smooth detailed sound the best of the around eight different players I have accumulated.
The difference is not subtle and if I am honest I really didn't know what to expect with the X45 Pro but thought the performance would be comparable (did not audition the unit prior) to my Ver 2 AA Player but the reality is it just blows it away in every respect. There is far greater depth, width, height, separation and dynamics on all the tracks I played it was easy to hear the considerable additional information the ripping process imparted to the music when played back. I found myself hearing many things on well know CD's that I have never heard before and it is very dynamic but not in your face or fatiguing and very much surprised me to be honest.
I understand the comments about the GUI, it is functional but clumsy but I will integrate ROON to fix this as the next step in the process. listening through the Stax head phones is an experience making on some tracks the hairs on my arms and neck stand up it was really that good. I have noticed that with continued use it is getting better, listening extensively everyday at the moment. I admit to being a streaming skeptic previously and really looked at this step as a convenience for my extensive CD collection I have yet to try ripping any LP's to file as my turntable (a Luxman PD-310) needs some work done on the speed control so can't comment on this aspect of the X45 Pro's performance.
I can see this unit being the centerpiece of my system in the future with any new music being ripped first before a listen, it really is that good and integrating ROON functionality will only make this better so at this stage I am very happy with this excellent sounding product but this is just my opinion.
Edited by Loco57
Grammar and continuity issues
Great to hear, the Roon integration is superb and that combined with the Cocktail is a potent combo!
