LostIdentity
Subwoofer Cable and Banana Plug Recommendations
Hey Folks
Any brands and links appreciated...
Edited by LostIdentity
The Monoprice Affinity Series 24k Gold Speaker Banana Plugs are supposed to be a good thing, but the shipping cost makes them a ridiculous proposition.
For the sub cable I would go the Soundpath (SVS) sub cable - good quality and not overly expensive.
(running one into my SB2000)
Thanks didn't know that.. will get them 2m or 3m.. any cheap seller you might know? Would just require 1 right?
yeah i saw the reviews.. Any alternates from above or another?
I would get a Blue Jeans Cable LC-1 subwoofer cable, the best quality cable I've had . Hand made in the USA and absolutely top shelf customer service. The connectors are clones of the Canare RCAP connectors and are excellent quality and give a very solid connection.
No snake oil, ground unicorn horn or pixie dust, just a solid product at an affordable price (due to the extensive shielding - they are not overly flexible though)
https://www.bluejeanscable.com/store/subwoofer/index.htm
yes just one into the LFE input
Thanks.. Interesting.. about $75 delivered for 2m.. Hmm..
I would recommend getting one a bit longer than you need right now, to allow for future placement flexibility. Adding a ft or 2 now will only add a few dollars to the price, but may save you having to buy another later on because it's not long enough.
I'm not sure what your budget is for this, so  $75 may seem lot for a subwoofer cable - though compared with some other brands , it's actually a minuscule amount-  but this cable will last a LONG time. I've owned one of their older model cables for well over 10yrs  and I've gone through probably 8-10 subwoofers since then (God help me!) I purchased 3 of the newer models using their LC-1 cable a few years ago and all have been perfect.
BJC is also excellent to deal with and (IMHO) a great company to support (a small, family run business)
Appreciate it..
Any tips on banana plugs guys?
If you can solder... these beryllium copper multi-contact BFAs:
https://au.rs-online.com/web/p/banana-plugs-connectors/2817018/
Just under $5ea with free deliver (unfortunately they are only available in batches of five). You can discard the plastic outer covering and simply heat-shrink over the termination for neatness.
If not, these screw-type BFAs are good:
https://www.ebay.com.au/itm/KnuKonceptz-BFA-Style-Banana-Plugs-Accept-8-to-16-Gauge-Speaker-Wire-Pack-of-4/381663629354?epid=1165278785&hash=item58dcecd02a:g:z50AAOSwyjBW4ZPX
Thanks.. these look good.. might go for these..
