billy170468 Posted May 4, 2020 Author Share Posted May 4, 2020 Can anyone suggest a good/great dock? Cheers Andy Link to comment Share on other sites More sharing options...
billy170468 Posted May 4, 2020 Author Share Posted May 4, 2020 Ok. Think I might invest in NAS, This one to be specific https://www.scorptec.com.au/product/Network-Storage-(NAS)/1-4-Bays/70441-DS218play?gclid=Cj0KCQjw-r71BRDuARIsAB7i_QNU1gTIYQrY53nwpg1pPubK-1tsdjXp30Ljmv1uj5geDWDoCUdHHMkaAnRdEALw_wcB Will talk to an IT Guru/music lover friend of mine, see what he thinks Cheers Andy Link to comment Share on other sites More sharing options...
Snoopy8 Posted May 4, 2020 Share Posted May 4, 2020 (edited) 26 minutes ago, billy170468 said: Ok. Think I might invest in NAS, This one to be specific https://www.scorptec.com.au/product/Network-Storage-(NAS)/1-4-Bays/70441-DS218play?gclid=Cj0KCQjw-r71BRDuARIsAB7i_QNU1gTIYQrY53nwpg1pPubK-1tsdjXp30Ljmv1uj5geDWDoCUdHHMkaAnRdEALw_wcB Will talk to an IT Guru/music lover friend of mine, see what he thinks The "Play"models allow for video transcoding. If you do not need it, go for a cheaper model. Synology is easy to use. Have a 4 bay NAS (DS414), for my music and for rest of family. As long as you are comfortable with setting up the NAS and the disk drives (suggest buying either Seagate Ironwolf or WD Red), go for it. There is some work involved is setting up. Or you could ask your friend to set it up. Edited May 4, 2020 by Snoopy8 Typo 1 Link to comment Share on other sites More sharing options...
billy170468 Posted May 4, 2020 Author Share Posted May 4, 2020 @snoopy8 The "play" model of the ds218 is $60 cheaper than the 218 Link to comment Share on other sites More sharing options...
Snoopy8 Posted May 4, 2020 Share Posted May 4, 2020 16 minutes ago, billy170468 said: @snoopy8 The "play" model of the ds218 is $60 cheaper than the 218 Need to check what CPU is used, memory. There is a model compare on Synology site. Link to comment Share on other sites More sharing options...
billy170468 Posted May 4, 2020 Author Share Posted May 4, 2020 (edited) @Snoopy8 So I should get the "non-play" version? https://www.synology.com/en-au/products/DS218 Edited May 4, 2020 by billy170468 Link to comment Share on other sites More sharing options...
Snoopy8 Posted May 4, 2020 Share Posted May 4, 2020 Use this to select according to your needs and budget https://www.synology.com/en-au/support/nas_selector At the end of the day, music creates a small load on a NAS and any one will do. Link to comment Share on other sites More sharing options...
craka Posted May 4, 2020 Share Posted May 4, 2020 I use the Synology DS415play to stream movies and music. Music is directly to an SOTM ultra. Does it all without a breaking a sweat. Link to comment Share on other sites More sharing options...
Indie Hi-Fi Posted May 6, 2020 Share Posted May 6, 2020 @billy170468 with the synology, i have the DS118. It's fast enough for music with Roon but just note that synology have a recycle function by default. Just this week i tried to delete and re-add half the disc size in music files. Then it said it was max capacity and roon ground to a halt. I realised the synology had put all the deleted files in the recycle folder within it and so the disk truly was full. You can turn off the recycle feature easily though. It did my head in for a stretch. Link to comment Share on other sites More sharing options...
Jhsg Posted June 21, 2020 Share Posted June 21, 2020 (edited) Hello @billy170468 How’s your hunt going? Did you get the NAD? If you wanted to have a look at my digital rig you’re welcome to pop around as I’m also in Canberra. Cheers John Edited June 21, 2020 by Jhsg Link to comment Share on other sites More sharing options...
billy170468 Posted June 24, 2020 Author Share Posted June 24, 2020 Hey @Jhsg Hi John, No, not as yet Good to know you're in Canberra. Curious as to what your rig consists of? Might make a trip up the clyde soon Cheers Andy Link to comment Share on other sites More sharing options...
Jhsg Posted June 24, 2020 Share Posted June 24, 2020 1 hour ago, billy170468 said: Hey @Jhsg Hi John, No, not as yet Good to know you're in Canberra. Curious as to what your rig consists of? Might make a trip up the clyde soon Cheers Andy Hi @billy170468 No probs mate. Let me know if you’re in town and i can take you through what I’ve got and, more importantly, what I’ve learnt along the way. I currently run the following for my 2ch setup: - blue sound node 2i - Primaluna prologue preamp - ps audio m700 mono’s - twenty5.23 / rel t9i sub. Cheers John Link to comment Share on other sites More sharing options...
