Bush thug 40 Posted April 7, 2020 Share Posted April 7, 2020 Just wondering how i go about making a speakon neutrik cable for my rel sub. I am thinking i need a speakon conector that has 4 inputs and use the +1 +2 and -1 also speaker cable should any do from memeory it was pretty thin or is worth going a bit bigger. I only need 3 metres so maybe using sonething like the audioquest rocket 11 which has the 4 cales for bi wiring would do. Any thoughts or help would be appreciated. Link to post Share on other sites
haygeebaby 62 Posted April 7, 2020 Share Posted April 7, 2020 (edited) I just did this last month. I used kimber 8tc. was worth it as there was a sound improvement I could notice. I only needed two cables as my amp is balanced. So it’s very clean and connects via banana, while my speaker cables connect via spades. Jaycar has the original 4 connector speakercon. Not expensive. watch the gauge of cable you use. The kimber 8tc just fit. ill grab details for you shortly. Edited April 7, 2020 by haygeebaby Link to post Share on other sites
haygeebaby 62 Posted April 7, 2020 Share Posted April 7, 2020 (edited) 4 Pole InLine Neutrik Speakon - $14.95 from sources like Jaycar. Type NL4FX There is another slightly cheaper option but you can tell the Nertrik is better made - and I believe they are industry leaders. So I went Neutrik. Assembly instructions here - under downloads. Shows the lengths you want to cut for the cable and sheath. https://www.neutrik.com/en/product/nl4fx They recommend pozidriv #1 screwdriver but you can get away with a small Phillips - expect some slip. Small flat head screwdriver works better. Max wire size is 4mm or 12AWG - for the entire plug cavity. There is some discussion about how thick you really need the cable to be since it is just sending voltage. Stock cable is 24AWG. Some say that is fine. Some say 18AWG is best. Who knows - my DIY setup uses 2x9AWG - because I had some spare 8TC and thats what the size was. Connection details: (I think this is right - but double check - I can't take responsibility) 1+ right (red) 1- ground (black) 2+ left (yellow) Good luck Edited April 7, 2020 by haygeebaby 1 Link to post Share on other sites
Bush thug 40 Posted April 7, 2020 Author Share Posted April 7, 2020 Awesome thanks heaps thats how i thought it would work. Ill give it a go. Did you have the original cable so you think it sounds better with the kimber Link to post Share on other sites
audiofeline 2,552 Posted April 7, 2020 Share Posted April 7, 2020 Quality speaker cable is audibly better and worth buying compared to cheap wire. Link to post Share on other sites
haygeebaby 62 Posted April 8, 2020 Share Posted April 8, 2020 (edited) Yes - I have the original cable - they are in the pics attached. Yes - In my setup I did notice better extension and detail over stock cable. I think every situation will be different - as in hifi everything matters and makes a difference - good or worse or different. Even REL make an upgraded cable and most reviews say there is improvement over stock. What cable you use (copper - how pure, silver), how much shielding, what solder you use if any, what speakon brand, and what termination you use at the speaker terminal side - are all going to make a difference. I'd rank this as a medium size improvement - and worth doing if you DIY and the costs are low. Other areas of improvement will be your power, power cable, power plugs, power fuse, isolation/decoupling, and room placement. Good luck Stephen. Post some pics and your impressions when you are done with your cable. Edited April 8, 2020 by haygeebaby Link to post Share on other sites
punkterfuge 15 Posted April 19, 2020 Share Posted April 19, 2020 On 08/04/2020 at 12:11 AM, haygeebaby said: I I only needed two cables as my amp is balanced. So it’s very clean and connects via banana, while my speaker cables connect via spades. @haygeebaby I just made up a similar cable out of some old cord speaker cables but I used an XLR cable as it is an older Sonus Faber Sub with an XLR connector instead of a speakon. I used two connectors to L and R positive and one to negative. I have a pair of balanced monoblocks and a balanced power amp I'd like to try the sub with. I have seen a few REL guides saying with balanced power amps to only use the two positive connectors and not to use them with monoblocks, but to instead use the line-level inputs. I'd prefer to use the high-level outputs. Can using this connector with the ground do any damage to the amps? They are both Electrocompaniet. Thanks Link to post Share on other sites
haygeebaby 62 Posted April 20, 2020 Share Posted April 20, 2020 Don't know Punkter. Don't want you to blow up your equipment either. But I have tried with and without a ground cable in my setup. And both methods work. I connect to the ground terminal which exists on Pass Labs amps - specifically for use with subs outlined in their manual. I don't get hum from the sub when all equipment is switched on. If I turn the subwoofer on before the power amp - I still get hum - even if I use the ground cable. But in both scenarios - I get no hum during operation. Are you getting any hum from your subwoofer when using only L and R on the XLR cable you made? 1 Link to post Share on other sites
punkterfuge 15 Posted April 20, 2020 Share Posted April 20, 2020 Unfortunately, one of my monoblocks has stopped working! It would work at lower volumes and then cut out when I would turn it up. It was the one with both the positive and negative coming out of it. It worked ok for a couple of weeks when I disconnected the sub and now has stopped working all together! I'm not sure that it is because of the sub though as previously I had the sub connected with a different cable and it worked fine for a few weeks, it was only when I made up an XLR cable from better speaker wire that it started to have problems. I'm keen to try again with another power amp that I have (thank god I have a backup!) but am worried just in case the problem is from connecting the sub. I have tried both with and without the ground and have not had any hum issues. I thought the ground placement was mainly to deal with any hum issues, so hoping my monoblock not working is just coincidence! As I don't understand how it could get damaged. I might try speaking to the tech before I plug the sub back into my poweramp, probably without the ground. Whaddyareckon? Link to post Share on other sites
haygeebaby 62 Posted April 20, 2020 Share Posted April 20, 2020 Can't hurt. Go for low hanging fruit first. Good luck man - hifi 1st world problems. Link to post Share on other sites
punkterfuge 15 Posted April 20, 2020 Share Posted April 20, 2020 Def 1st world problems, but it's a bloody good distraction at the moment! Link to post Share on other sites
davewantsmoore 6,720 Posted April 20, 2020 Share Posted April 20, 2020 On 08/04/2020 at 1:09 AM, haygeebaby said: since it is just sending voltage ? Link to post Share on other sites
punkterfuge 15 Posted April 27, 2020 Share Posted April 27, 2020 On 20/04/2020 at 1:40 PM, haygeebaby said: Don't know Punkter. Don't want you to blow up your equipment either. But I have tried with and without a ground cable in my setup. And both methods work. I connect to the ground terminal which exists on Pass Labs amps - specifically for use with subs outlined in their manual. I don't get hum from the sub when all equipment is switched on. If I turn the subwoofer on before the power amp - I still get hum - even if I use the ground cable. But in both scenarios - I get no hum during operation. Are you getting any hum from your subwoofer when using only L and R on the XLR cable you made? Ok, I've spoken to my tech, and he reckons that the ground shouldn't make a difference except for reducing hum. I think in this case, not having ground applies to balanced output (Speakers) rather than balanced input (line level), which is what I have. Is this what you have too? Link to post Share on other sites
Bush thug 40 Posted May 4, 2020 Author Share Posted May 4, 2020 Got a cable made up from puresonics for it was not much more expensive for him to do it all for me the whole cable was $107 fitted and delivered for 6m mogami 2921 quad cable it is a xlr cable for a sonus faber sub. Changed subs since started post. I just wraped the tape around the brown cable so i knew which was the negative. 1 Link to post Share on other sites
punkterfuge 15 Posted May 4, 2020 Share Posted May 4, 2020 4 hours ago, Bush thug said: Got a cable made up from puresonics for it was not much more expensive for him to do it all for me the whole cable was $107 fitted and delivered for 6m mogami 2921 quad cable it is a xlr cable for a sonus faber sub. Changed subs since started post. I just wraped the tape around the brown cable so i knew which was the negative. Which sonus sub are you plugging into? Link to post Share on other sites
Bush thug 40 Posted May 4, 2020 Author Share Posted May 4, 2020 cremona Link to post Share on other sites
