Class A Audio
FS: Bel Canto REF500M Monoblock Power Amplifiers
Price: $2995
Item Condition: Trade in, excellent physical condition and function
Shipping Options: Pickup is available,I can ship this item
Suburb or Town: Notting Hill
State: Victoria
Reason for selling:
Further information:
Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, VIC, 3168. phone (03) 8555 0735
REF500M Monoblock Amplifier
The REF500M monoblock amplifier has excellent power combined with upper midrange and high frequency clarity and openness that lets the subtle detail from your source component pass through to your speakers.
Max Power Output: 500W 4 ohms, 250W 8 ohms per Channel
Minimum Load: 3 ohms per Channel
Peak Output Current: 35 Amps
Balanced Input Impedance: 200 Kohms
Specifications
Maximum Power Output: 500W 4 ohms, 250W 8 ohms
Power Output 1% THD: 450W 4 ohms, 225W 8 ohms
Peak Output Current: 35 amperes
Frequency Response: +/-3 dB 1.5Hz-70KHz, all loads
THD+N: 0.003% 1W, 1KHz, 4 ohms
IMD (CCIF): 0.0003%, 1W, 14:15KHz, 4 ohms
Output noise: 35uVRMS A-weighted 10Hz-20KHz
Voltage gain: 27dB (single ended or balanced input)
Damping factor: >1000
Output Impedance at 100Hz: <8 milliohms
Dynamic Range: 121dB
Input Voltage for Max Output: 2Vrms
Input connections: Single-ended RCA or balanced XLR
RCA input impedance: 100Kohms
Balanced input impedance: 200Kohms
Output connections: 1-set WBT Nextgen 5-way binding posts
Power On usage: 10W
Power Off usage: 0.0W
Internally Set Operating Voltages: 100-120VAC or 230-240VAC 50/60 Hz
Size: 8.5 x 3.5 x 12[inches], 216 x 88 x 305[mm] (WxHxD)
Weight: 15 lbs, 7 Kg
