afie
Help me go round in circles!
So currently I have nothing setup, but have narrowed down on speakers and am looking for what avr/power amp/dac are required to make work everything I desire.
Id like to be able to have a 2ch setup for a main tv/kitchen/living area, with speakers to play:
- music currently on a hard drive (internal and external);
- tv/movies through streaming apps like Netflix through a Fetch box or a Xbox1 or a Chromecast;
- streaming apps/Youtube through casting from an iphone.
Sound quality of music is the priority, but I do find it much easier to hear spoken words on tv with separate speakers.
I have been looking at Ascension speakers from Adelaide and talked to the guy there last year.  The likely model will be around 150 wrms at 8 ohms. I will call him again to discuss, but if I remember correctly from what he recommended last time, an AVR to drive such speakers is expensive relative to the speakers just to offer extra channels that I don't need. Would a suitable alternative be a 2ch power amp plus a second device to hand all the digital inputs?
Emotiva BASX A-300 or AMC: 2N100MKII-2 are both 150w 8ohm power amps for about $800, but an AVR that can do 150w at 8 ohms are about $5k - what am I missing here? Ive looked into this several times over the last year and I feel like I am just going round in circles.
Any help would be appreciated. Cheers.
If music sound quality is a priority then a stereo amp will generally out perform an AVR amp. I personally don't bother with AVR amps.
If $5k is your budget that you mentioned for the AVR, you could easily split this and get a vastly superior DAC from Giesler Audio and a stereo integrated amp.
By stereo amp I assume you mean an integrated amp rather than a power amp which also requires a separate pre amp.
There are lots of previous posts on avr vs stereo amp choices and issues.
Yes, you could do that...  but an integrated amplifier would be simpler - a one box solution that would provide great two channel audio quality and handle inputs from a number of sources (including TV potentially)
An integrated amp is made up of a power amp and a built in preamp.
What do mean by  "I do find it much easier to hear spoken words on tv with separate speakers"?
Are you referring to centre channel speaker?, 3.0 or 3.1 system?
Sorry, $5k looks to be the cost of an AVR that is comparable to a $800 power amp - my budget is $1000 (and may have to go second hand to achieve this).
The AMC and Emotiva I listed look to be just power amps. So I would need a pre-amp to handle all the inputs, but the cheaper ones starting at $500 dont have hmdi. A new pre-amp plus power amp is going to cost too much, I was hoping I could just add a DAC to a power amp?
Yes, and reading them its easier to see Beginners go round in circles. I struggle to see what motivated you to post such a useless response - a waste of energy only surpassed by me responding to you.
Don't worry about the power too much, sometimes 80w integrated has more power than 150w in AVR - it's complicated.
As example Marantz PM 8006 integrated vs Marantz 6014 AVR - same price.
Thanks - do you recommend anything in particular? I can't find an integrated amp with enough power for less than $1500 retail - what could I look for as second hand that would suit?
Hello @afie,
I was in the same boat as you not so long ago. I purchased a second hand, vintage Yamaha CA-1000iii integrated from Japan for around $1000 delivered (make sure you understand the cost of delivery before buying, mine was $500 - as much as the amp cost). It is an integrated amplifier from the late 70's with an excellent amount of wpc @8ohms and a really fantastic quality sound. I now have it set up with a DAC which allows me to play lossless audio files and streaming (Tidal Master currently). It runs through some KEF LS50s and sounds really nice to me.
If you are up for a challenge then I can recommend looking at vintage gear, Accuphase, Sansui and Yamaha can be phenomally good and if you search hard and intelligently enough, you can find a great unit, as I had the luck to.
The older amps, as long as they are not VFET, seem to be almost infinitely serviceable too, so you can generally fix any issues you may have with them moving forward.
A full service (re-cap) on mine runs around $300. I believe you would have to spend thousands for an equivalent price of equipment today.
I remember a feature called HT passthrough that the more expensive AVRs have so that you can use a more powerful amplifier but still retain the inputs of an AVR. Would the power amplifiers I listed work in such an arrangement or would they need a pre-amp as well?
Do people use more powerful integrated amps in HT passthrough to an AVR - whats the point of Marrantz offering such similar units?
3 minutes ago, Harts said:
Hello @afie,
I have a 1983 Denon something 800 that does 2ch 40w 8 ohms, and was serviced five years ago, but I assume it wont be powerful enough?
They are not similar, only the price is similar. The stereo integrated has very limited number of features, only 2ch power amp and only 70W into 8 ohm but for music it's much better. It's only example of how the power numbers are not quite honest.
Some DACs can drive a power amp. Although you'll lose functionality and risk start up at full volume if something gets reset as the volume control is digital. You will also get a quality drop with a digital volume control except at max volume. Although it may not be that noticeable in the 70% plus range and can certainly be a stop gap.
I'd definitely take the advice here on second hand. I have myself on power amps and integrateds.
I'd avoid HDMI and use optical or coax out of the TV or player. For music out of a player especially, HDMI seems to drop quality in my experience.
I think the power you need from an amp really only depends on the speakers you intend to use, some are efficient and won't need a powerful amp.
You mentioned 150wrms @8ohms in your first post, that is pretty decent power handling afaik. My speakers are also not efficient, which is why I looked to vintage gear. I got quite a powerful, quality amp for relatively little money to drive my speakers, I wasn't looking to over capitalise, like you.
I am somewhat of a novice, there are other, more knowledgeable users here that can advise better. Nonetheless, in a similar situation to you, my vintage experience has been successful.
Edited by Harts
In my experience, avoid AVRs going near the signal if your priority is music. And same advice again if you want movies, TV etc in 2 channel.
You can spend $3k on a new AVR and be worse off for 2 channel than a good 1980s $300 integrated amp. And for $1000 second hand you'd be laughing.
Excellent DACs are any of the Kleins. Version III you'd need the toslink version. I and II had this and USB I believe.
Edited by DrSK
What about Emotiva PT-100 Pre-Amp, D/A + Emotiva BASX A-300?
USB for PC (HDD)
coax, optical for TV
Try the Denon, you have nothing to lose and it should drive the speakers at least reasonably well. You don't actually need a 150w amp to drive speakers that are rated to handle 150w.
If you find the Denon doesn't cut the mustard, you then also have something of a reference point.
All things being equal the difference between 40W and 150W is only 6dB.
In practice a good 40W amp can sound better than a 150W amp. Depends more on other things like delivery of current and a whole load of other factors.
You'd be surprised how often people listen to music at 0.5W to 10W volume settings. Our ears are in no way linear to Watts.
The speaker Watt rating is more about maximum rating so they don't get blown when paired with various amps. A more important factor for loudness is their efficiency.  I think my speakers are rated to 700W but run fine off 80W to 100W amps which sound way better than my old 150W amp.
You only really need higher power levels when driving subs as our ears are very insensitive to noise in the low frequency region. Takes a lot more energy to sound as loud.
Edited by DrSK
If you had read enough of those posts you should have seen the final same conclusions that would assist you in turn eventually. Many newbies post repetitive questions without seeing if the question has been asked before and is often normal forum etiquette or rules.
I'm in a similar position and am looking at a Yamaha A-S701 to get my system started.
Denon PMA-800NE is another option.
Digital Inputs, MM/MC phonostage, not stupidly expensive.
g'day afie
Perhaps you could consider a mini-system, for example Denon DM41DAB as i think this latest model might have inputs for all the items you listed in your original post and is possibly a simple, neat, compact and cost effective solution.
I've previously used for around 5-8 years each the Denon DM31 and DM38 models in a 5.5 x 10m open plan lounge/dining/kitchen area where they did a fine job for general tv, movies and casual (background) music.  The DM38 now moved to the kids rumpus room for gaming and Netflix.
There alternatives such as Cambridge One, etc depending on what you can demo, preferred/perceived sound quality etc.
Obviously with these mini-systems you don't get the absolute level of clarity, scale and punch possible from a well chosen large and/or more expensive set up but at around $800-1000 street price this type of min-system might just fit the bill.    And the beauty with these "3 box mini systems" is you can easily move them off to a rumpus, bedroom, office, workshop when time/desire/budget/madness leads to a serious upgrade.
2B
Right. I think the whole thread is going round in circles too. Lets start from the beginning. @afie so can you clarify your budget for everything, amp, speakers and dac? Is it $1000? So you want something for mainly music, but want to be able to switch source to tv and stream stuff like movies/Youtube? How big is the room, what shape? Do you prefer floorstanders/bookshelves or no preference? Is second hand or vintage ok? Have you heard the Ascensions?
@MTsoul you need to answer these questions too. You also need to start by listening to and choosing speakers first.
From my experience, AVRs are constantly changing and always trying to compete with each other in the numbers game so most of them rate their ‘peak’ power outputs whereas stereo amps usually rate their ‘nominal’ power outputs.
    • By Jing
      Item Condition: mint Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Vermont State: Victoria Payment Method: COD Reason for selling: surplus Further information:
      Very good player, excellent review.
      Being Used as DAC(Audio/Video) only.
      Maybe a bit too big for a DAC, and waste of its Blueray and CD player capabilities.
      Therefore try to simplify things.
    • By SBM
      Hi Guys,
      Good day, I am new to DAC and I see here in SNA details on Speakers brands, details and price in every bracket. Just thinking to have list of DAC quality DAC. If in case we have the list already please point me.
      Below 1000$
      1001$-3000$
      3001-6000$
      I am not sure does people spend more than 5000$ on DAC!
      To my knowledge :
      Gieseler(great Australia DAC)
      SoTM
      Chord
      RME
      Denafrips
      Atleast , it will give some pointers to the beginner(like me) in this community, to decide what is best when planning a DAC new/used. As we have lot of brands .
      Thank you
    • By mtan002
      Item Condition: Like new Shipping Options: Audition is not available, but in-person pickup can be arranged with limited personal contact,I can ship this item Suburb or Town: Point Cook State: Victoria Payment Method: EFT cash Paypal Reason for selling: Redundant equipment Further information:
      I bought this few months ago for $700.
      It is an excellent DAC at this price range with clear mellow sound.  But I decided to sell it because I miss the MQA sound.
      You can get the full description here: http://www.audio-gd.com/R2R/R2R11/R2R11EN.htm
      In summary:
      Discrete DAC single ended headphone- and preamplifier True NOS , R-2R discrete ladder DAC Built in pre- and headhpone amp Built in 2 groups DA-8 R-2R modules with 450MHz ultra speed CPLD Unique noise process technology will remove any digital artifact DSD native , DXD, PCM up to 384KHz Support Amanero Combo 384 USB interface High quality ALPS 27 volume potentiometer
      INPUTS
      1.USB input.
      2.Toslink optical SPDIF
      3.RCA coaxial SPDIF
      OUTPUTS
      •RCA single ended (Output is configurable: fixed or variable)
      •Headphone 6,3mm jack
      The price includes postage within Australia. If you come and pickup yourself, you save $25.
    • By hu4man
      Item Condition: Fully Functional Shipping Options: Pickup is available,I can ship this item Suburb or Town: Brisbane, QLD State: Queensland Payment Method: Cash on Pickup, PayPal, Bank Transfer Reason for selling: NLR Further information:
      24 bit/192k. Comes with stock power supply. SPDIF , Coaxial and USB inputs.
      Bought as backup DAC, but never used
    • By Luciano Milioli
      Item Condition: Very Good Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact,I can ship this item Suburb or Town: Wetherill Park State: New South Wales Payment Method: Paypal, Cash, EFT, other equipments... Reason for selling: Upgrade Working Great, this refined and powerfull amp is made in New Zealand by the well known Perreaux, a renowned maker of high quality, high-end audiophile audio.
      There is only a small visual damage in the letter "R" (see picture), only visible if looking close. That is why the price is half of the same model on used market and 1/4 of a similar new one.
      I may accept small speakers or DAC to trade.
      REgards,
      Luciano
