zanlation Posted March 24, 2020 Share Posted March 24, 2020 Price: $320 Item Condition: Used, Excellent Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Murrays Beach State: New South Wales Payment Method: Paypal, cash on pickup or Direct Debit Reason for selling: No longer required Further information: Integra DTR-30.4 4K AV Receiver working perfectly. See specs AMPLIFIER: # Channels 7.2 Power (8 Ω, 20 Hz–20 kHz, 0.08%, FTC) 100 W/Channel Power (6 Ω, 1 kHz, 0.08%, JEITA) 175 W/Channel Amplifier Frequency Response (WRAT) 5 Hz–100 kHz THX Certified Continuous 6 Ω Rated Certified 4 Ω Performance - Discrete Output Stages for All Channels Push-Pull Amplifier Design Three-Stage Inverted Darlington Circuitry Independent Block Construction (Amp/Preprocessor) - Shielded Toroidal Transformer - Independent Power Supply 2 High Quality Extruded Aluminum Heatsink Bi-Amp Capability for Front PROCESSING: Dolby TrueHD, Dolby Digital Plus Decoding DTS-HD Master Audio, DTS-HD Express Decoding DTS Neo:X (Front High / Wide Channels) - Dolby Pro Logic IIz (Front High Channels) Dolby Volume - THX Processing Modes & Loudness Plus THX Media Director Pass-Through Digital Processing Crossover Network - Differential DAC Mode for Front Channels - Audyssey Room Correction & Calibration 2EQ Audyssey Sub EQ HT - Audyssey MultEQ Pro / Installer Ready - Audyssey DSX (Front High / Wide Channels) (Front High) Audyssey Dynamic EQ & Dynamic Volume Audyssey Movie / Music Modes / Game Surround Modes (Rock, Action, Sports, Role Play) Advanced Music Optimizer to Enhance Compressed Audio Files DSD Processing / Direct Mode / - 192 kHz / 24-Bit Audio DAC 192 kHz / 32-Bit Audio DAC - Vector Linear Shaping Circuitry (VLSC) - 32-Bit DSP Chip for Advanced Processing Ultra-Low-Jitter Circuitry to Improve Audio Adjustable Crossover by Channel Pair 40/45/50/55/60/70/80/90/ 100/110/120/130/150/200 Hz Accurate Speaker Distance Setting 0.2-foot A/V Sync Delay (by Source) 800 ms Multi-Band Speaker EQ 5 Band ISF Certified Calibration Controls (ISFccc) - Picture Control Settings per Source CONNECTIVITY: HDMI v1.4a (3D Support, Audio Return Channel) Deep Color, x.v.Color, Lipsync, CEC Support HDMI Inputs / Output(s) 8 / 2 Front Panel HDMI Input MHL (Mobile High-Definition Link) InstaPrevue Technology (PIP for HDMI Sources) HDMI Upscaling & Upconversion (Qdeo by Marvell) 1080p Upscaling (Qdeo by Marvell) 4K Upscaling (Qdeo by Marvell) D-Sub (15-pin) VGA Input - Component Video Inputs / Output(s) 2 / 1 Component Video Upscaling & Upconversion - Composite Video Inputs / Output(s) 5 / 1 S-Video Inputs / Output(s) - Digital Audio Inputs (Optical / Coaxial) 2 / 2 Analog Audio Inputs / Output(s) 7 / 0 Phono Input - Front Panel A/V Input Multi-Channel Input - Analog Pre-outs 7.2 iPod Ready/iPhone Ready (Direct Digital USB Input) HD Radio - NETWORK: Network Audio Steaming (Windows 7, DLNA v1.5 Certified) "Home Media" Sharing Apple Lossless, DSD, Dolby TrueHD Playback via Network Pandora, Rhapsody, vTuner, SiriusXM iRadio* Spotify, Slacker, Aupeo!, Last.fm* USB Input for Streaming Audio (Front & Rear) Wireless Network Ready via USB (Optional UWF-1) Bluetooth Ready via USB (Optional UBT-1) Firmware Updates via Network / USB / Firmware Update Notification *Availability of services depends on region. MULTIZONE: Powered Zone 2/ Zone 3 / Zone 4 / - / - Fixed or Variable Zone 2 / Zone 3 / Zone 4 Line Out / / - Zone 2 / Zone 3 Subwoofer Output - Zone 2 Video Output - INTEGRATION ACCESS: Bi-Directional RS-232 Control Port Bi-Directional Ethernet Control Port Rear Panel IR Input / Output 2 / 1 RIHD (Remote Interactive over HDMI) RI System Control 12 V Trigger (w/adjustable delay) Assignable (x3) MISC: Pre-Programmed / Learning Remote / - GUI for Remote Control Programming GUI for Setup Menu Home Menu / Quick Setup Menu / Bi-Directional Remote Control Setup - Activity Remote (My Movie, My TV, My Music, All Off) - Input Name Edit HDMI Standby "Through" Mode (Selectable) Setup Store & Recall Function Screensaver Function Hybrid Standby to Reduce Power Consumption Solid Aluminum Front Panel Aluminum Volume Knob (Sand Finished) Detachable AC Cord Rack Mount Kit Available IRK-155-3C Warranty 3 Years Amplifier Section Power (8 Ω, 20 Hz–20 kHz, 0.08%, FTC) 100 W/Channel Power Output (6 Ω, 1 kHz, JEITA) 175 W/Channel Dynamic Power 240 W (3 Ω) 210 W (4 Ω) 120 W (8 Ω) THD (Total Harmonic Distortion) 0.08% (Half Power) Damping Factor 60 (Front, 1 kHz, 8Ω) Input Sensitivity and Impedance 200 mV/47 kΩ (Line) Rated RCA Output Level and Impedance 200 mV/2.2 kΩ (Line Out) Maximum RCA Output Level and Impedance 2.0 V/2.2 kΩ (Line Out) Frequency Response 5 Hz–100 kHz/+1 dB, -3 dB (DSP Bypass) Tone Control ±10 dB, 30 Hz (Bass) ±10 dB, 20 kHz (Treble) Signal to Noise Ratio 106 dB (Line, IHF-A) Speaker Impedance 4 Ω–16 Ω or 6 Ω–16 Ω Video Section Input Sensitivity/Output Level and Impedance 1.0 Vp-p/75 Ω (Component Y) 0.7 Vp-p/75 Ω (Component Pb/Cb, Pr/Cr) 1.0 Vp-p/75 Ω (Composite) Component Video Frequency Response 5 Hz–100 MHz, -3 dB Tuner Section FM Tuning Frequency Range 87.5 MHz–108 MHz AM Tuning Frequency Range 522 kHz–1,611 kHz FM/AM Preset Memory 40 Stations General Power Supply AC 220–240 V~, 50/60 Hz Power Consumption 620 W Dimensions (W X H X D) 435 × 174.5 × 326.5 mm Weight 11.5 kg Photos: Link to comment Share on other sites More sharing options...
