SBM
Left and Right channel
Hi Guys ,
I am using a vintage Rotel integrated amplifier to power by stereo speakers and noticed that one channel is 10db louder than the other.
Is that because of the amplifier is old?
Using the same speaker cables on left and  right speakers. Connected via mobile using the RCA cable.
Attached the measurements using the db meter. It's approximate only.
Are you measuring using bandwidth limited  pink noise?AVR internal test tones?
Is  the mic the EXACT same distance from each speaker?
Do not touch the volume control Swap the left/right Input to the amp and play the same track and measure again
10dB will be audiable, you can hear the difference but wanted to quantify??? Check your test procedure as above. What model RA-xxx amp? Does it have PRE-OUT/MAIN-IN RCA connectors at rear, if so plug your phone (at minimum volume) into the MAIN-IN's and check for balance. Alst test the preamp by crossing the PRE-OUTs to MAIN-IN with RCA cables, ie, Left PRE-OUT to Right MAIN-IN, Right PRE-OUT to Left MAIN-IN, still same channel louder etc...
Most probably a dirty switch or contact issue. Apply gentle pressure to each switch in turn, rock slightly back and forward, then fully switch, any impact? Could also be dirty protection relay...
Hi mate, it's very approximate measurements only. Tested using the sound meter app. And tested almost close to the speaker at the same distance and volume.
Thanks. Yes I tested in same way as you said. Same track played twice . Measured using the decibel meter app at same distance from speaker. As I am not using the proper device but the difference is close to 9db in the max.
Yes , one speaker sound is high, I swapped the connection and the same channel is always louder. RA971 Mkll Rotel amp.  Will check the switch tomm. Thanks
If. by this, you mean you crossed the Left PRE-OUT to Right MAIN-IN etc... then it's a power amp issue or dirty protection relay, not dirty preamp amp switches. Will try and track down the service manual... You could try and give the relay a tap with something non-conductive (chopstick...) while play music, any significant change...
EDIT:
Service manaul does not show any PRE-OUT/MAIN-IN RCA's at rear. Also, the unit does not have a speaker protection relay. However there is a relay between the pre/power stages that grounds the audio presumeably during the power on/mute period.
So it could be a switch issue. Work through switches as previously mentioned.
Edited by mbz
Update
Thanks, it's faulty switch . Tone switch was not proper.
Needs a clean then, unless It's badly worn, though It's usually just dirty.
Can you set different left and right volumes as well? My RC-971 has the split volume knob so maybe that's not quite right. Otherwise the tone controls on it have also gotten a bit iffy but I lose an entire channel with it turned on rather than a difference in volume.
    • By Jovan.s1987
      Current Setup is an LG smart TV, HDMI out into my Yamaha AV receiver. I watch & listen to my content through the apple tv or chromecast, both of which are hooked into the receiver.
      If I want to access apps through the TV, so the native Netflix app on the TV for instance, I get no sound - what's the easiest solution?
      Should add, the toslink optical input is being used on the receiver from my Google Audio Chromecast.
    • By Swart042
      🎄It's Christmas, I would  consider any reasonable offers!🎄
       you can pick it up today and listen to great music toning!  Also including cables as per picture.
      Item: Kef and Marantz surround sound system
      Price: Originally advertised for $6900 retail $9200 25% off
      Item Condition: Brand new, never been opened, have the original receipts
      Reason for selling: Financial fundrasing
      Payment Method: Pickup - Cash, Paypal, COD and buyer pays for shipment if not picked up
      KEF Q400B centre speaker retail $800
      KEF Q 200C bookshelf speakers  retail $800
      KEF Q 300 subwoofer retail $1000
      KEF Q 700 floor speakers (black oak) retail $2300
      MARANTZ UD7007 AMPLIFIER retail $1100
      MARANTZ 7009 MEDIA PLAYER retail $3200
      This system is new we have never opened the boxes never used any of the items.  It would suite a music lover that loves good quality sound.  We are selling as we need to raise money to repatriate a dog stuck in transit overseas.  Please don't make an offer if you are not serious and please be reasonable.  This is NEW, it's just not in the shop anymore, the packaging has never been cut open. If you would like to buy seperate items please message me.
    • By Josh Ballard
      Item: marantz pm8000 Black
      Price: 750
      Item Condition: Good. No marks
      Reason for selling: Upgrading
      Great amp, used it to power some B&W 603 S3s and was very pleased with the warm midrange and delicate highs.
      specs:
      Power output: 95 watts per channel into 8Ω (stereo)
      Frequency response: 10Hz to 50kHz
      Damping factor: 150
      Input sensitivity: 2.5mV (MM), 150mV (line)
      Signal to noise ratio: 85dB (MM), 109dB (line)
      Channel separation: 70dB (line)
      Switchable class A switch
    • By 57John
      Can anyone recommend me a great AV/HT Installer who can handle Krix speaker systems for HT? And does Intercoms preferably wireless.
      I need someone with advanced experience if possible. House plans available.
    • By Ashtray83
      So recently I have been upgrading my hifi and Av set up, it's more centered around audio but I have just got a 4k tv and blueray player , which has the ability to play all audio formats including sacd and flac files, at a claimed 24bit 192kz . How much better is a dedicated cd player going to be? Is it really necessary
