Hi guys
After over 6 months of indecision I decided to pull the trigger and try the GAIA's out since I have not heard one bad wrap anywhere on these. I had these onto my Sopra 2's over the weekend and man, what a difference it made. The improvement you get is not the kind where you ponder and thought to yourself "maybe that wasn't quite worth it as the difference is so subtle". It's more like "Whoa! Every single floor-standing speaker should come with these pre-fitted". What I think the GAIA's do is isolate the speakers from the ground, as if the drivers are floating in the air unconstrained and unimpeded. Hence you hear a lot of spatial information and truer musical timbre overall. Bass becomes more defined and tighter. Now I cannot imagine my Sopra 2's without these. There are a few YouTube videos on these. Some even doing A-B demos which I don't think do these justice because you need professional highly sensitive mics to capture the spatial dimension of the sound.
If like me you have been sitting on the fence because of price, doubts on the improvement it can make on your already "perfect" system, "another snake oil product", etc. all I can tell you is KlappAV is having a 10% sale (was 20% a few weeks ago) and there is a rebate campaign from the distributor on these until April.
You can thank me later.
https://klappav.com.au/search?q=gaia*&view=ls&type=product
https://www.ehifi.com.au/isocashback
sonusfidelio
I also have Sopra 2s with Gaia 1s and completely agree. Installation is a little tricky due to the Sopra’s glass base plate and pre-existing spikes, but once you’ve navigated that hurdle I also found the results well worth the price of admission. As always YMMV but nice to hear from a fellow SNAr who had the same experience.
Do they have the Gaia 1's in stock? I've been waiting on some for my TAD CR-1's for a month and got a call last week saying stock is delayed. I'll give Klapp AV a call today.
Thanks!
GS
My main concern is the floor placement on carpets. I will require Gaia 3 and the spikes that they sell to go with them. The speakers are Opera Grand Mezza and they are slender things so I have them on a platform. I’m just not sure that the spikes will go through the carpet, the current ones don’t.
The narrow aspect of the speaker is also concern.
thoughts from members, not so much on if the Gaia will work or not, but a solution of application in my case
Neo
Edited by Neo
Thanks!
GS
You'd have to call them but I ordered them online about two weeks ago (20% discount then) and got them delivered 3-4 days after. It might be worthwhile to mention their 20% discount, and that you had missed it, to see if they can accommodate. You'll never know. Nothing venture, nothing gained.
Edited by sonusfidelio
3 minutes ago, Neo said:
My main concern is the floor placement on carpets. I will require Gaia 3 and the spikes that they sell to go with them. The speakers are Opera Grand Mezza and they are slender things so I have them a platform. I’m just not sure that the spikes will go through the carpet, the current ones don’t.
Neo
Hi Neo, apparently you can get a special spiked plate for these that are placed below the GAIA's especially for carpeted floors. The GAIA's have quite a broad circumference so if anything would make your speakers more stable.
I believe that Len Wallis has plenty of stock,
most of their Sonus Faber speakers on display have Gaia various versions fitted already
Give them a call, if the other store has a reasonable discount I’m sure they will match or come close
Neo
Based on the fact that my current spikes which are sharp don’t penetrate the carpet and underlay, I don’t like my chances and having Gaia on these plinths I’m not sure if I get their full benefits
Neo
Neo
The spikes are a lot longer than they look. Mine spike through carpet and underlay to concrete - but my speakers are 75kg - but that still only works out to <7kg of weight through each of 12 spikes
You could easily force them through yourself, as an alternative
I don’t have much weight to play with, under 20kg and the speaker are tall and slender which ends up a wobbly affair. Gaia spike will be same or similar unfortunately
Neo
  • Administrators
Neo
I don't believe you will have a problem, thanks to the outrigger at the rear which already provides stabilisation.
I use the IsoAcoustics carpet spikes myself, and anyone that's been here will vouch for how thick the carpet and underlay is. They're nasty sharp so should have no problem penetrating. Stability should be just as good as the original spikes or better, because as mentioned they will spread the load over a wider contact point.
Neo
Is it just the camera lens, or is the front right (as you look at them) spike or footer thread bent?
Angle
I love my Gaias. I've seen Sopras on Gaias a number of times in hifi show reports. I wonder whether there's something amiss with the Sopras that makes them a good candidate to show how big a difference the Gaias make. Are the Sopras light?
Sopra 2 are 55kg so not that light (the Sopra 3 weigh 70kg). It's also not easy to install the Gaia relative to other speakers due to the glass bases and pre-existing spikes on the Sopra which are quite long, requiring you to lever out the base from the speaker cabinet in order to unscrew the spikes. Not for the faint of heart as it's not immediately obvious which part of the base/cabinet intersection will loosen. I contacted Isoacoustics directly for advice before applying the necessary pressure in order to release the bases. Once you've seen a photo of where they disconnect all become clear.
Good point you make about the Sopra often appearing at Isoacoustics demos. That had caught my attention too due to owning a pair.
55kg certainly isn't what I would call a light speaker.
  • Administrators
You make a really good point. Hopefully I don't upset anyone with my opinion, but each and every single time I've heard Sopras I've never liked the bass. It seemed sloppy and uncontrolled. So much so it really sticks in my mind about this particular model of loudspeaker. Now I wonder if others have felt the same way and that's why it's been common to see Gaias installed on them. In my experience on any loudspeaker, one of the characteristics of Gaia that is repeatable, is tighter control of bass, so it makes absolute sense to me.
Interesting point Marc. I run my Sopra 2 with Devialet 400s, which are known for their good control of bass extension. Add SAM to that and problems with bass frequencies on the Sopra are not something I’ve experienced, but it may be the case in other systems (I’ve not heard them in any other settings). The reason for frequent use of Sopra in Gaia demos would be an interesting question to pose the Isoacoustics people.
The Sopra's put out good bass alright. However, it depends on the upstream equipment and synergy. Like jason101, I've used them with the Devialet 400's, and recently I changed my setup to the Octave MRE 130 mono-blocks (tubes). In both setups, the bass is tight and tuneful. The value proposition of the GAIA's is not mainly in the bass. It's in the spatial clarity and timbre.
  • 2 weeks later...
1 hour ago, Rhymenocerous said:
I believe a big part of why you see IsoAcoustics on Focal models is that they are distributed in the US by Focal America.
That makes a lot of sense!
  • 3 months later...
Well, I'm going to chip in here as a noobie on this thread - I have a pair of Focal Sopra 2's (coming from a background of Sonus Faber Amati's). I run in parallel with a pair of Martin Logan BalanceForce 210 subs - I like bass! The difference in slam and imaging throughout the spectrum, not just bass, with Gaias throughout (I's on the speakers sitting on dedicated solid sheaok plinths, II's on each of the subs) was significant!  Far less secondary floor propagation (I have a wooden floor so can feel that) as a result. Cleaned up the soundstage. Almost as much an improvement as introducing the Isotek Sigmas 6 and a dedicated Isotek Regen for the DAC an preamp to clean up the power supply. In short, they work! Prior to this I had my speakers sitting on Townshend seismic podiums. They seemed to reduce bass extension but were actually cleaning up the sound, but not to the same degree as the Gaias in my view.
  • 2 weeks later...
An interesting thread as I have Sopra 2's partnered with Naim amplification. There's quite a lot of positive comments posted on the Naim forum about the Gaia feet.
Once I've upgraded my power supply for my pre amp this year, I think the Gaia's will be next on the list.
  • 8 months later...
Hi Lozza,
How did you find Sopra vs Amati? Which Amati did you have? All Amaties are very beautiful speakers, I suppose there must be something that you dont like thus changed to Sopra?
Tom
  • 2 weeks later...
+1 for Gaia's here
Gaia 3 under my Dynaudio Heritage Specials on Stand 20's
The Gaia's definitely made my Heritages even more special.... :)
167539731_4230378896974191_8901737828326054501_n.thumb.jpg.27afcd6f6c997d397d3c29b770be64fc.jpg
169096035_4230395970305817_3786671862345781576_n.thumb.jpg.fe5d3e5dc12cba979b6fd7255afef03c.jpg
Edited by michaelp2
Is that just a concrete base or something else? Did you make it yourself?
No, It's a Slate paver, 400 x 400 - not the prettiest but it's what I had - Hammer Barn has some nice Granite ones , but I can't be arsed moving my speakers again
Is it worth putting Gaia's under my subs?
My main speakers roll off around 50Hz, and the room could do with some tighter bass...
My advice is yes - I have yet to read a bad report on the Gaia's
I'm sure online research will back this up
Here's some I just found on the 'bay
https://www.ebay.com.au/itm/153377616791
  • Thanks 1
    • By sufioz
      Item Condition: as new, used for couple of months Shipping Options: Pickup available but audition is not available. Suburb or Town: Aspendale Gardens State: Victoria Payment Method: Cash on pickup Reason for selling: Need the size up so NLR! Further information: I am at home this long weekend so you can pick up from me. Prefer local pickup. I think postage is about $14 extra if you are interested.
