The Fez
Vintage HiFi
Finally got this one back in the house..looking forward to firing this beast up again...
Let me guess.... another VFET beast?
Too many vents to be a Yamaha CA2010
Must be a Sony ??
On 17/05/2018 at 9:47 AM, alanpartridge said:
I have had it serviced, recapped, replaced the speaker terminals and AC power lead.
Sounds superb.
G'day Mr Partridge, I know it's been a while since this post but who did you get your Sansui serviced by? my Sansui power amp recently had one of it's speaker terminals broken so want to find someone to replace/repair it.
when I bought it, it was not used for a period of time but I had checked over and since then it's had a  couple of years of use and wanted to retest caps and what not also.
Thanks again.
Mike.
Must be a Sony ??
Technics -- SE-A100...
Its a bit big-- bout 33kg?? but its the circuit in this beast that is the goods...Rated about 170w-180w-@8ohm. I posted about it earlier
Thanks again.
Mike.
Hello Mike, I used Chamilla at RF Waves Australia in Hammersley. 9342 7161
He also replaced the speaker terminals.
Appears to have done a good job.
Cheers, thanks Pete, most appreciated.
Oh yes, I remember that thread now....
I genuinely hope you store these classics in a environment controlled room with gas fire suppressors and a big intruder alarm. The world needs to keep these alive for as long as is possible :)
LOL..They are stored whereverr I can fit the bloody things. I've still got more in Sydney to bring to Melbourne, and another waiting in Japan to come over, and another one in the Netherlands waiting for a total rebuild...:blink:
Hi just to say I got the Kenwood KT-5500 working .I have refurbished it along with a Kenwood KA-6100 amp added blue led lights as well. It all sounds great now just need a volume , balance and selector knob for the Kenwood KA-6100 amp dose any one have any.I love 70s/80s Hi Fi
Edited by Who42
Can anyone  shade bit of light on Vintage Sony receivers?.I can see on Ebay  Sony STR-7065A $600  and i really like the look:-).
I have only vintage  Sansui 551and Marantz 1060 in use at the moment to compare .
Edited by same64
Nice  Receiver a little pricey but seems  in very good condition ! I give it add a review
But its not the neatest build inside.
Manual Library / Sony
Sony STR-7065A
AM/FM Stereo Receiver (1975-76)
add a review (2 reviews)
sony str-7065a front
Sony STR-7065A
Specifications
Tuning range: FM, MW
Power output: 65 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 70kHz
Total harmonic distortion: 0.2%
Damping factor: 50
Input sensitivity: 1.6mV (mic), 3mV (MM), 250mV (DIN), 250mV (line)
Signal to noise ratio: 65dB (mic), 72dB (MM), 90dB (DIN), 90dB (line)
Output: 250mV (line), 30mV (DIN), 1V (Pre out)
Speaker load impedance: 4Ω (minimum)
Dimensions: 471 x 157 x 375mm
Weight: 15.2kg
Downloads
Related Catalogues
HiFi Stereo Quadro
If you have any problems opening files please read the download FAQ. All files are provided under strict licence and reproduction without prior permission or for financial gain is strictly prohibited.
If you have additional documentation please consider donating a copy to our free archive.
Reviews
 Login or register to post reviews
rating
Reviewed Jan 15th, 2018 by ddlf
Saved a STR-7065A from a neighbours garbage. Cleaned 30 years of nicotine off the face and case. So bad I thought it had a bronze/gold finish. She cleaned up well and is as sweet as can be. Beautiful Japanese design and engineering.
rating
Reviewed Jan 06th, 2016 by TheSleezstak
My STR-7065A has a wonderful sound thats easy on the ears, yet fills my ears with great separation of highs, mids, and lows from a pair of GNP Valkyries. All powered by the Sony. When wanted, the pre out/in jacks are great to have. Also theres three sets of speaker connectors, screw type.
The radio pulls in from afar. Clear.
The build is very compact inside and designed well.
Nice since this is not light weight.
I love the classic silver styling accented by the green illumination.
All original and still keeps trucking!
Sony STR-7065A
Sony STR-7065A
Specifications
Damping factor: 50
Weight: 15.2kg
Downloads
Related Catalogues
HiFi Stereo Quadro
Reviews
rating
rating
My latest acquisition  Advance Acoustic MAP-305 II
Specifications
Power output: 150 watts RMS per channel into 8Ω (stereo)
                       :   250 watts RMS per channel into 4Ω (stereo)
Frequency response: 10Hz to 60kHz
Total harmonic distortion: 0.05%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 300mV (line)
Signal to noise ratio: 97dB (line)
Channel separation: 70dB (line)
Weight: 15.5kg
Sony STR-7065A
Sony STR-7065A
Specifications
Damping factor: 50
Weight: 15.2kg
Downloads
Related Catalogues
HiFi Stereo Quadro
Reviews
rating
rating
Advance Acoustic MAP-305 II  look nice and neat  and Sony:-).
1 minute ago, Happy said:
Some actual vintage
Naaaaw you kept grandpa’s amp
I hear my maternal grandpa was a bit of an audiophile for his time.
Also a huge womaniser while the grandma worked hard to raise their kids.
Looks chunky but not vintage.
You do have some gear though.👍
