Price: $6500
Item Condition: Ex Demo , Full Warranty
Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact
Suburb or Town: Notting Hill
State: Victoria
Reason for selling:
Further information:
Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, VIC, 3168. phone (03) 8555 0735
All the promises of an Expert Pro system.
2x140 Watts Under 6Ω
All the promises of an Expert Pro system. ADH®, SAM®, RAM®, EVO®... The Expert 140 Pro features all of Devialet's exclusive technologies.
Expert Pro is the world’s most advanced audiophile system, meant for music lovers in search of a refined and emotional listening experience. Designed to replace traditional Hi-Fi systems, Expert Pro delivers all the core elements of playback – preamp, amp, DAC, streamer, phono stage – in a single and ultra-compact unit. By rethinking sound reproduction at every turn, Devialet engineers have been able to achieve the best performance ever measured, at all power levels. With a precise and natural attack, explosive dynamics, naked silence and beautifully true timbre, the experience is breathtaking.
Entirely configurable and upgradable, Expert Pro reveals your music’s full potential, whatever the source or speakers.
Specifications
PERFORMANCE
Power : 2x140WRMS 6Ω
Signal-to-Noise ratio : 130dB
THD – 130W/6Ω : 0,0005% / -106dB
THD – 10W/6Ω : 0,00025% / -112dB
Output impedance : 0,001Ω
Damping factor : 8000
Thermal distorsion : Below measurement threshold
Technologies : ADHV2®, SAM®, AIR®, EVO®, DAC Magic Wire®, RAM®
PHONO STAGE
Type of supported cartridges: MM/MC
MM sensitivity from 1mVRMS to 15mVRMS
MC sensitivity from 100 μVRMS to 5000 μVRMS
256 combinations for the resistive/capacitive loading of the cartridge
Stereo/mono/left/right mixing
13 equalisation curves available
Specific menu for dynamic adjustment of all these settings
PREAMPLIFIER & MAIN DAC
Patented Magic Wire Digital / Analogue Converter, D/A T.I. PCM1792
Unique high-precision MasterClock with very low jitter: 2ps RMS
Conversion of all inputs into 24-bit/192 kHz
Built-in DSD / PCM conversion
SAM profile via configurator allowing the precise adaptation of the sound signal to the specifications of your speakers
Available active filtering on all analogue outputs via configurator
Volume control in increments of 0.5 dB
Volume adjustment range: -97.5 dB to +30.0 dB
Bypass/pass-thru mode available input by input
Balance adjustment
Tone control: bass +/-18 dB, treble +/-18 dB with variable frequency cut-off via configurator
GENERAL
Finish : Chassis carved out of a single aluminium block
Color : Dark chrome finish
Dimensions : Length: 383mm | Width: 383mm | Height: 40mm
Weight : 5.65Kg
Installation : Horizontal or vertical installation with automatic tilt detection
CONTENTS OF THE BOX
1 Devialet Expert 140 Pro
1 Power cable
1 User Manual
1 Warranty booklet (5 years)
1 Microfibre cloth
1 Pair of gloves
1 SD card
1 Remote Expert (3 AAA batteries LR03 1,5V provided)
Devialet Expert Pro in More Depth
The ultimate audiophile system
Expert Pro is the ultimate audiophile system, for the most discerning of music lovers.
Well above and beyond an ordinary amplifier, Devialet reinvents and combines for the first time all of the key components of expert playback (preamplifier, amplifier, DAC, streamer, phono stage) in a single and extremely thin slab.
Your Expert Pro is unlike any other: set each of the thousands of possible configurations for a unique musical experience.
Regardless of the source. Regardless of the speakers.
Unmatched performance
Devialet technologies reinvent each step of the musical signal chain for never before achieved levels of performance.
Pure sound. Explosive dynamics. Absolute silence. Perfect audiophile playback, completely transparent. A rare emotional experience.
The performance delivered by Expert Pro is the best ever measured, at all power levels :
THD+noise (harmonic distortion) at full power under 6Ω
0.00025%
THD at 10W/6Ω
0,0001%
Output impedance
0.001Ω
Signal-to-noise ratio
133 dB
Devialet inventions
ADH® analogue-digital hybrid amplification, SAM® system for real-time adaptation of the signal transmitted to the speakers, free, regular updates using the EVO® platform, HD audio stream (wired or wireless) via AIR®, DAC Magic Wire®, RAM® Phono stage… The Expert is Pro system an engineering gem.
All Expert Pro systems incorporate all of Devialet’s audiophile technologies. 107 patents. 58 awards. The most award-winning audio system of all time.
In addition to these technologies exclusive to Devialet, Expert Pro benefits from many major innovations developed for this new line :
New ADH Intelligence®
New Magic Wire® DAC
New Class A Amplifier
New Class D Amplifier
New Power Supply
New Thermal Management
Your Expert Pro unlike any other
Vinyl turntable, CD player, tuner, computer, smartphone, tablet, NAS, online music services, television : the Expert Pro system elevates all of your music.
The Configurator enables you to adjust with absolute precision each setting of your audiophile installation. From defining active sources to setting the specifications of your phono cell, create a system unlike no other in the world.
A unique listening experience, whatever your preferences may be
Regardless of your source and regardless of your speakers, Expert Pro renders your audiophile setup breathtaking. From the most delicate of turntables to the highest quality file of your digital library, Expert Pro allows you to rediscover all your music.
COMPUTER
CD
VINYL
MOBILE / TABLET
TELEVISION
ALL SPEAKERS
Speaker Active Matching SAM®
For the first time, your speakers operate at peak performance levels while being perfectly protected.
No speaker models are exactly the same. Expert Pro sends a signal that is precisely adapted to their acoustical architecture. Displacement, driver excursion, acceleration, speed… with the SAM® technology, the Expert Pro system has perfect knowledge of how your speakers behave.
The sensoriality of audiophile refinement
A technological gem, the fully omnidirectional Devialet remote enables you to control your installation with the tips of your fingers, with no latency.
A joyful experience.
Each Expert Pro system incorporates all of the exclusive technologies invented by Devialet.
A revolutionary electronic architecture that radically optimises the entire sound signal path, from its input in the Expert Pro system to its output to your speakers.
The key elements of this unique architecture have been thoroughly reviewed for the new Expert Pro line which introduces many major innovations :
New Magic Wire®
New Power Supply
These technologies are protected by 107 patents, rewarded by 57 awards and acclaimed by the international audiophile press.
ADH®
The best of both worlds
Invented by Devialet, ADH Intelligence is the first hybrid amplification technology that combines the refinement of analog amplification (Class A) with the power and compactness of digital amplification (Class D).
Both types of amplification operate in parallel, for radically increased performance.
With Expert Pro, Devialet introduced a new version of the ADH Intelligence®, pushing once again the extreme performance of this unique technology.
SAM®
The best of your speakers
For the first time, the SAM® technology (Speaker Active Matching) enables the precise adaptation of the sound signal to the specifications of your speaker model. This is made possible by the powerful DSP at the heart of each Expert Pro system.
These built-in systems protect your speakers and ensure top performance.
DAC Magic Wire®
The world’s shortest signal path
The invention of Magic Wire® technology enables Devialet to ensure the world’s shortest path between the DAC and speaker connections: 5 cm.
To achieve this technological feat, Devialet refined the best digital-to-analog converter to achieve the world’s best performance in noise and distortion levels
Switch-mode power supply
All the power of current, with complete transparency
Supported by a revolutionary switching mode power supply, the Expert Pro system goes from absolute silence to explosive dynamics in the blink of an eye.
AIR®
High definition streaming
Invented for high definition music, AIR® enables you to enjoy all your streaming audio content without compromise (up to 24 bits / 192 kHz), via Ethernet or Wi-Fi, regardless of the format, multimedia player or streaming service that you use.
AIR® (Asynchronous Intelligent Route) is the world’s most advanced audio streaming technology.
RAM®
The world’s most advanced phono stage
Thanks to the exclusive RAM® (Record Active Matching) technology, your phono stage is entirely and dynamically configurable. It precisely adapts itself to the characteristics of your turntable and your vinyl records. Serving the musical heritage.
EVO®
The permanent upgrade
Expert Pro systems are designed to perpetually remain state-of-the-art.
The EVO® platform, the electronic architecture of Expert Pro systems, is fully driven by upgradeable software. As such, your Expert Pro undergoes constant improvement via free, regular updates, for ever improved features and performance.
Devialet Remote
The weight of audiophile refinement
Carved out of a single aluminium block, the Expert Pro Remote enables you to drive your system with unparalleled finesse.
Responsive and precise, the Expert Pro Remote offers the best audiophile experience.
Using zero latency radio transmission technology, the Expert Pro Remote is fully omnidirectional.
    • By mekon76
      Price: $100 Item Condition: Excellent Shipping Options: Pickup is available Suburb or Town: Mount Eliza State: Victoria Payment Method: Cash, EFT, Paypal Reason for selling: No home theatre room anymore to hang them in Further information: 75cm tall x 38cm wide in frame. Original daybill. Framed professionally, UV protective glass, spacers so daybill can be removed from frame (not glued).
       Excellent addition for your home theatre room.
    • By mekon76
      Price: $100 Item Condition: Excellent Shipping Options: Pickup is available Suburb or Town: Mount Eliza State: Victoria Payment Method: Cash, EFT, Paypal Reason for selling: No home theatre room anymore to hang them in Further information: 75cm tall x 37cm wide in frame. Original daybill. Framed professionally, UV protective glass, spacers so daybill can be removed from frame (not glued).
    • By mekon76
      Price: $100 Item Condition: Excellent Shipping Options: Pickup is available Suburb or Town: Mount Eliza State: Victoria Payment Method: Cash, EFT, Paypal Reason for selling: No home theatre room anymore to hang them in Further information: 79cm tall x 37cm wide in frame. Original daybill. Framed professionally, UV protective glass, spacers so daybill can be removed from frame (not glued).
    • By mekon76
      Price: $80 Item Condition: Excellent Shipping Options: Pickup is available Suburb or Town: Mount Eliza State: Victoria Payment Method: Cash, EFT, Paypal Reason for selling: No more room to hang these Further information: 72cm tall x 37cm wide in frame. Original daybill. Framed professionally, UV protective glass, spacers so daybill can be removed from frame (not glued).
    • By mekon76
      Price: $110 Item Condition: Excellent Shipping Options: Pickup is available Suburb or Town: Mount Eliza State: Victoria Payment Method: Cash, EFT, Paypal Reason for selling: No home theatre room anymore to hang them in Further information:  72cm tall x 37cm wide in frame. Original daybill. Framed professionally, UV protective glass, spacers so daybill can be removed from frame (not glued).
