Class A Audio Posted March 14, 2020 Share Posted March 14, 2020 Price: $1990 Item Condition: Ex Demo , Full Warranty Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Notting Hill State: Victoria Payment Method: Pickup - Cash, Paypal, COD Only Reason for selling: Further information: Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, VIC, 3168. phone (03) 8555 0735 Product Description Revolution XT 6F has a crossover that uses low loss laminated core inductors and audiophile components throughout and further benefits from high purity oxygen free copper (OFC), silver plated wiring. Dual Concentric Its 150mm (6.00”) Omnimagnet Dual Concentric driver is augmented with a matching 150mm (6.00”) bass driver to deliver LF extension down to below 40Hz. Both the Omnimagnet Dual, with its 25mm Linear PEI dome HF unit and Torus-Ogive waveguide, and the auxiliary driver feature a multi-fibre cone with rubber surround and a 44mm edge wound voice coil to ensure seamless bass performance. 31.1 Litre Cabinet The 31.1 litre Revolution XT 6F cabinet utilises the most compact iteration of Tannoy new twin-cavity coupled reflex system, featuring separate cavities coupled internally by tuned ports. Bass energy exits from a down-firing port between the angled base of the cabinet and the integrated plinth. Wave Guide The precisely engineered angle of the ‘waveguide’ formed between cabinet and plinth encourages LF energy to disperse forward into the room, making closer-to-wall placement of the speaker than is typically possible without major detrimental effect on sound quality. The result is tight and articular bass with exceptional power and extension whatever you room layout or loudspeaker placement requirements. Front Baffle For a more subtle aesthetic, magnetic grille mounts are installed below the veneer to ensure a smooth and uncluttered appearance on the front baffle and easy fitment of the supplied grille. Revolution XT 6F is Tannoy’s most affordable Dual Concentric floor standing loudspeaker, yet offers the unrivalled performance and outstanding finish that Tannoy owners have come to expect. Wood Veneer Each Revolution XT 6F cabinet is offered in Medium Oak or Dark Walnut real wood veneer, hand finished to the same exacting standards expected of bespoke cabinetry. The Omnimagnet driver is finished with an etched trim ring and driver bolts that contrast the black driver chassis. Specifications PERFORMANCE Recommended Amplifier Power (Watts RMS) 25 - 150 Continuous Power Handling (Watts Peak RMS) 75 Peak Power Handling (Watts) 300 Sensitivity (2.83 Volts @ 1m) 90 dB Nominal Impedance (Ohms) 8 Frequency Response (-6dB) 38 Hz - 32 kHz DRIVE UNIT Dual Concentric™ High Frequency 25 mm (1”) Linear PEI dome with Torus Ogive WaveGuide and Omnimagnet technology Dual Concentric™ Low Frequency 150 mm (6”) multi-fibre paper 44 mm (1.75”) voice coil Bass Driver 150 mm (6”) multi-fibre paper pulp cone with rubber surround. 44 mm (1.75”) edge wound voice coil CROSSOVER Crossover Frequency 250 Hz & 1.8 kHz Crossover Type Passive low loss 2nd order low pass, 1st order high pass CONSTRUCTION Enclosure Type Downwards ported twin cavity coupled reflex Volume 30.7 l (1.08 cu. ft.) Dimensions H x W x D (incl. plinth) 1005 x 269 x 317 mm (39.6 x 10.6 x 12.5”) Link to comment Share on other sites More sharing options...
