Bradj86 1 Posted March 12, 2020 Share Posted March 12, 2020 Hi all, Total newbie here Does anyone have any experience/opinions on using either a UM12-22 or SWR-1242D in a 2cuft enclosure for home use? would there be a significant difference in sound quality between the two? Link to post Share on other sites
Maz4bz 104 Posted March 13, 2020 Share Posted March 13, 2020 (edited) I have some experience with a few Alpine 12's (but all in ported or tapped horn enclosures) and must say they are my preference over pretty much anything in a 12" for reasonable money. A buddy had an Ultimax 12 that he imported from the US that developed a coil rub - there are quite a few reports of this on the PartsExpress reviews for this driver. We replaced the UM12 with an Alpine R and side by side there is a stark difference in build quality. The other great quality of the Alpines (and the UM's) are their low FS and Vas. You can get low for little enclosure size. Plus the current model has 20mm xmax. There are very few drivers that can claim this much excursion and that translates directly into how loud it will play cleanly. Finally the price difference nails it for me. Alpines are plentiful second hand (and practically indestructible) or the last new pair I paid $250 each delivered (to WA) from the Life Style Store in NSW. The Type X and R below are in ported 75 liter (2.6 cubic feet) enclosures. For a minor increase in size and complexity of a port you'll get a lot more output. Good luck! Edited April 15, 2020 by Maz4bz 1 Link to post Share on other sites
Bradj86 1 Posted March 13, 2020 Author Share Posted March 13, 2020 (edited) Thanks mate, Ive decided to go for the Alpine R - especially because of the insane cost, due to the exchange rate at the moment. Thanks for the advise! Edited March 13, 2020 by Bradj86 Link to post Share on other sites
Bradj86 1 Posted March 13, 2020 Author Share Posted March 13, 2020 Out of curiosity - what sort of power are you throwing at the r's Link to post Share on other sites
Maz4bz 104 Posted March 13, 2020 Share Posted March 13, 2020 (edited) I personally have a pair of Crown XLS 2500 running 4 subs. I use a DCX2496 for room eq (using Paul Spencer's Bass Integration Guide) and to high pass my subs at 20hz for some excursion protection. Edited March 13, 2020 by Maz4bz Link to post Share on other sites
