flipswitch
Am I getting lossless atmos ( HDMI ARC) question
I’m a bit confused about this now, because I’ve gotten different answers.
I am using the HDMI arc connection ( it’s the only HDMI out) (Denon avr-x1600h) connected to the HDMI arc on my tv ( Panasonic fz950 OLED  (which is full bandwidth)
I have my 4K blu ray player and PS4 Pro connected to my avr HDMI ports.
When I’m playing a 4K movie with Atmos on my blu-ray player, am I getting it down-converted to something lower quality, or full lossless atmos?
I understand that playing something from my tv, eg the Netflix app, I wont be able to get Atmos.
 Eg;
When playing a movie with atmos connected to the  HDMI ARC port of my tv, my AVR says Dolby Atmos – True HD.
Now when playing it on the HDMI non arc port, it says the say thing, Dolby Atmos -True HD.
 Everything sounds the same.
How are your speakers set up? 7.X or 5.X.2?
Atmos signals are contained within the Dolby True HD bitstream. How your AVR treats them depends on its capabilities and your speaker set up.
If you have Atmos speakers, the overhead sounds will be decoded and directed there. If not, overhead signals will be sent to your surround speakers.
I have a 5.1 setup, and you’re right, overhead sounds will be directed to the rear channels.
 But that wasn’t what I wanted to know.
 My question is,  how I described my setup in the opening post, am I getting lossless  atmos or lossy ( compressed) audio.
 My AVR says Dolby True HD Atmos when I press info on my avr remote. So I’m assuming it’s lossless.
Yes it will be lossless when sourced from a disc with a lossless soundtrack e.g. Dolby True HD. Lossy soundtracks will appear as something like Dolby Digital.
Not quite true.
compressed Atmos from Netflix or Disney+ or Amazon Prime or the Apple Store will appear as "Dolby Atmos" on the receiver as well.
Edited by Lil Caesar
Ok, but through my 4K player connected to my receiver it will be lossless not compresses atmos.
Edited by flipswitch
...When playing a blu-ray / UHD disc - yes.
Ok. Even though I’m using the HDMI arc port on my tv? ( this is the bit that’s confusing me, because I read that HDMI ARC cannot do atmos or any lossless audio)
 but that’s only when playing something though the tv like the Netflix app I think.
The ARC "should" parse the audio signal it's sent without issue - how old is the TV - are we talking "e-ARC" or the older "arc" iteration ?
TV is 2018 model and arc only.
If you are using external sources, why are you bothering with HDMI ARC at all?
I use the Netflix app on my tv because through Netflix on PS4 it always activates HDR even during SD content.
OK not sure you can actually verify this in any way BUT it should be lossless Atmos coming thru 'cos a 2018 set would not have any way to "compress Atmos".
Lossy / VBR Atmos is a 2019 development pioneered by the streaming services, which I believe just places the compressed datastream in a "container" which HDMI / AVR knows is to be decoded as Atmos.
Your on money !
my bet ... telly won’t allow atmos back via arc
inwhich case better to use also external source for Netflix eg appletv which does better than ps4 with things like sdr/hdr to suit set
I don’t care about Netflix not being in atmos :). I’m only worrying about my 4K Blu-Ray player not playing lossless atmos ;).
with sources like 4k Blu-ray connected directly to age should not be using arc as source for that. Look at your hdmi assignment :) refer that hifi guy note above
I am puzzled?   Can you hear it the difference between lossless and not???  Why worry about it when there are things which impact the sound more.  The AVR and your speakers and particularly the room will have a far, far bigger influence on the sound quality.
So in summary. Avoid using ARC on tv, buy external device such as Apple TV for Netflix, etc.  This will avoid any issues regarding lossless audio or not on 4K BR, because I’m not using ARC. :)
id feel restricted if not getting atmos etc from disc source on my system ... that id consider a big loss :D
if you have external sources eg 4k uhd player... you shouldn't be able setup so indeed do get atmos from that source. only one impacted would be telly which would rely on arc ?  unless arc on telly is somehow impacting other sources as well ?
That’s what I think, but then someone says something different! So I’m still unsure. :)
well its really easy to check just hit info button on the avr or look at the display on avr will show you whats incoming and whats outgoing..... will makes sure with 4k uhd when its playing you are getting the full deal... and also see whats happening with telly as source feeding back over arc...
I have done that. When playing a movie with atmos connected to the  HDMI ARC port of my tv, my AVR says source Dolby Atmos – True HD when I choose info on my AVR
”Sound - Dolby Atmos
Signal - Dolby Atmos - TrueHD.”
Now when playing it on the HDMI non arc port, it says the same thing, source  Dolby Atmos -True HD..
https://community.cedia.net/blogs/david-meyer/2018/06/25/dolby-atmos-over-hdmi-arc
Quote
In summary, a basic, lower resolution form of Dolby Atmos may work through existing HDMI ARC, but it is highly system and link dependent. This is why we tend to generalise that ARC doesn't support Atmos, as it's out of spec and can't be relied upon. If you are designing this capability into systems, sticking with proven product combinations and short connectivity can give your systems an edge until eARC comes along and opens up our options.
Hmm...
well thats good then and answered in that case ....
I think I have found the answer!
Quote
ARC stands for Audio Return Channel, which basically means it uses the same wire that sends video from the AVR to the TV to send audio back from the TV to the AVR. Nothing more.
The only job ARC does is between the AVR and the TV. Everything else that connects directly to the AVR works as is, lossless audio included, no limitation.
eARC is only needed to send lossless audio from the TV (or devices connected to the TV) to the AVR. So without eARC if you play a file on the TV with lossless audio it cannot be sent to the AVR as is, only the lossy core will be sent.
So since I have my 4K blu ray player and PS4 Pro connected directly to my AVR, I’m getting lossless Atmos audio.
OT,  I looked at my profile page and it shows I joined in 2005. And I’m thinking I don’t remember joining this forum all those years ago. Then it came to me. This used to be dtvinfo forum!
In summary - my understanding ...
Atmos is channel metadata attached to:
1. Dolby Digital TrueHD - uncompressed (lossless)
2. Dolby Digital Plus - compressed
eARC - can pass Atmos TrueHD
ARC - can only pass (up to) Atmos DD+
Your AVR handles (up to) Atmos /  TrueHD / eARC
Your TV only has ARC so will only carry (up to) Atmos DD+
Furthermore - Netflix only distributes Atmos as DD+
(Begs the question - Why does your AVR report TrueHD from TV/Netflix? Do you have that as a hard set output mode on the AVR? I see it's not of great importance to you anyway.)
You will get full Atmos TrueHD from capable BluRay direct to your AVR (over HDMI).
The simplest overview I've  seen is from Digital Trends.
https://www.digitaltrends.com/home-theater/dolby-atmos
Edited by ShellstaX
fix typo
    • By zakblue
      Item Condition: Excellent (small mark on top as pictured) Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Balwyn State: Victoria Payment Method: Paypal, Bank Deposit Reason for selling: No Longer Required Comes with box and all accessories (remote, calibration mic, manual)
      Happy to courier Australia wide through Interparcel.
      PM for further details.
    • By VinodS
      Item Condition: Used Shipping Options: Pickup available and you can audition. Suburb or Town: Carlingford State: New South Wales Payment Method: EFT, Cash on pickup Reason for selling: upgrading to 11.2 Further information:
      Pioneer VSX 1130K (US Version) receiver in great working condition. No packaging, but comes with physical remote, MACCPro Calibration mic, Transformer to convert 220V to 110V
      Does nearly every format you throw at it, including ATMOS. Upgrading to 11.2 setup hence selling. 2 years old and in immaculate condition. Supports MultiZone audio.
      The back photo is stock photo, too many wires to take a proper photo
      https://www.digitalcinema.com.au/pioneer-vsx-1130-7-2-channel-av-receiver.html
      PLEASE READ
    • By kerisabe
      Item Condition: Mint, very low hours. Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: North Melbourne State: Victoria Payment Method: EFT, Cash on Pickup. Reason for selling: Surplus Further information:
      Silver Audio Research DAC 9.
      Selling due to surplus in my system. Unit is in mint condition, very low hours of use. Serious buyers only, can check condition upon pick up. Located in North Melbourne, 5 mins walking distance from Queen Victoria Market.
      Some review articles to read:
      http://www.enjoythemusic.com/magazine/equipment/0320/Audio_Research_DAC9_Digital_To_Analog_Converter_DAC_Review.htm
      https://audiophilestyle.com/ca/reviews/audio-research-dac-9-review-r644/
    • By mfroes
      Hi guys,
      I would really appreciate any guidance.
      I have front right/left speakers which are 6ohm 250w (nominal)
      central, rear left and rear right are 8ohm 150w (nominal)
      My amp is at the moment struggling to push all those speakers so i was wanting to upgrade.
      budget wise i think up to about 1k would be something for a 5 channel (just guessing here), if more how much more would be needed ?
      would there be one the would be HDCP 2.2-compliant ?
      if some that have atmos capability so i can buy some speakers and add in the future would be great.
      so would be 5.1.2 i'm guessing here?
      would a 7.1.2/7.2.4 be better ? havent seen a lot of bluray that comes with 7channel capability like that.
      the 7 i see usually are counting the atmos speakers.
      Thanks in advance for reading and for any suggestions that comes my way.
      Current Setup
      Receiver: Yamaha HTR-3066
      Front: NHT C4
      Centre: Gale 20
      Rear: Axis LS28
      Subwoofer: Sound Dynamics THS-10
    • By Eugene.cho
      Item Condition: near New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Bella Vista State: New South Wales Payment Method: cash Reason for selling: Need pre-outs
      Near new Sony STR DN1080, purchased from JB hifi hornsby 2 weeks ago on 20 May  for $1749. receipt available,
      What Hi-Fi? Awards 2019 winner.
      https://www.whathifi.com/au/sony/str-dn1080/review
      Reason for sell: set up then realized I should buy  a AV receiver with preouts so I can use my stereo system for the front channels. so I bought a Yamaha instead. This Sony was only set up for the test then back to the box.
      This is a very well reviewed and highly praised 7.2 or 5.2.2 Dolby Atmos, DTS-X AVR and comes with all the latest technologies, including 4K HDR, Dolby Vision, DSD play back and DSEE HX upscaling. built in audio Chromecast, Apple Airplay and multiroom audio.
      Manufacturer's website: https://www.sony.com.au/electronics/av-receivers/str-dn1080
      Reviews: https://www.whathifi.com/au/sony/str-dn1080/review
      https://www.cnet.com/reviews/sony-str-dn1080-review/
      https://www.avforums.com/reviews/sony-str-dn1080-7-2-channel-av-receiver-review.14623
      https://addictedtoaudio.com.au/products/sony-str-dn1080-7-2-channel-home-theater-av-receiver
