Juzbear
LP12- Hifi guru plinth- Lingo 4
This review is somewhat of a hybrid review, being the component in question started off as somewhat of a mongrel, as many Linn LP12s are- an original afromasia plinth with the classic fluting, made in 1975. When I first purchased it, I took it to Audio Genesis in Sydney, where they performed budget priced upgrades to a late pre-cirkus bearing and subchassis, along with a new armboard and cable for the Basik arm which graced it. For some years I used a high output excel MC cartridge, and then an AT OC-9, and all was well, as I enjoyed purchasing second hand vinyl in the 1990s at cheap prices. After moving down south to Melbourne, it continued to make good music, with a steady diet of music from the 2000s, and the riches of the as yet sleepy used market. After having kids and spending lots of the past 15 years riding bikes, in the past 3-4 years, I decided that it was time to give the old girl a bit of love. I had purchased a few cartridges over the years, which given it was running through an ME-15 pre with an MC board, were all moving coil. AT PT-33 was a well priced favourite, which was superseded by an AT OC-9/mk3, and the Basik gave way to a Jelco 750D, with it's ability to swap head shells. The first big structural modification that I did to the table was a about 2 years ago, when I bought both a cirkus bearing and kore subchassis. This clearly made a difference to the sound of the deck, and the subchassis was much easier to set up, largely due to the fact the the old subchassis was slightly bent! The turntable retained a lot of the Linn rhythmic sound that keeps you listening, though the bottom end was tighter. I found that at times the detail in the high percussion was good, though it seemed to come and go a little. I also bought a trampolin 2 base, which I thought was an improvement on running it without a base, as I had done. Given I had given myself a little bit of a buzz before with the valhalla and its greater than mains voltage, and my kids were getting tall enough to reach it on the wall shelf, this was more a safety upgrade rather than a sound upgrade, though it definitely improved the looks of the deck. Another amateur structural mod that I did was to fit corner braces to the original plinth, and re-glue the corners, which did seem to tighten up the sound. This brings me to the subject of the current review...
2019 was a year of reduced spending and hard work, and towards the end of it, as a Christmas present, my partner suggested that I should think about getting one of those plinths that I had talked about after I saw them at the Hifi show.
I had seen this sign with a few examples in the VAF room, and discussed them with Simon from VAF, who said that he and another bloke, Ben, were starting a business around turntable setup, maintenance and upgrades, and the plinths were part of that. No they weren't yet for sale, as they were needed to show some shops. I put thoughts of immediate purchases out of my mind, and thought about other things. Now that the opportunity came to purchase one, got into contact with Ben, through the website www.hifiguru.com.au . I checked out a few of the models they had on offer on the still pretty rudiimentary website, and really had my heart set on a red gum plinth with a fantastic wavy grain. Ben got back to me via email, and we messaged about what was available, and agreed that I would get the Red gum, along with a new Linn top plate. The cost of the plinth was about $1500, which is a little more than a stock Linn plinth, but much cheaper than importing a Woodsong plinth or Booplinth, which were crazy prices. It may seem a bit silly paying this much for the wood surround of a record player, but I reasoned that when I play a record, I listen, let my thoughts wander, and spend quite a lot of time looking at the turntable itself, so getting one that is just beautiful was not so silly. It took the better part of a month to go from agreeing to purchase to getting the plinth itself, due to christmas and holidays, and during that time, I took advantage of a sale at Tivoli hifi to pick up a lingo 4 at a good price. It just seemed that if I was going to update the plinth, the motor had to be done too.
Come the end of January, and it was all coming together. I met Ben to pick up the plinth, and despite his offer to build up the player as part of the purchase, I really wanted to do it myself. The plinth looked even better in the flesh than I remembered, and certainly than in photos. The top plate was well set and the bolts were vertical. It was time to build. I had borrowed a set up jig and some tools, which make the whole shebang much easier.
First up was removing the subplatter, bearing and tonearm from the old table, which was no problem at all. Then was the process of fitting the Lingo 4 into the new plinth, along with the aforementioned bits. All went fairly well, with no issues. Soon I had a table which was fully stocked with parts, just needing tuning.
If any of you have set up the suspension of an LP12, it is not magic, but it does require a bit of futzing around after you have set the platter to level, at about the height of the plinth edge. After the requisite twisting of the spring grommets, and bouncing of the platter, I had achieved a good bounce with no side to side movement. After that I attached and dressed the tonearm cable, which took a little longer, with a bit more twisting and bouncing for good measure. It was ready for the base to be reinstalled (a tight fit) and to be placed on the wall shelf (essential for any turntable in a house with floorboards, in my opinion).
The finished product looks fantastic- a definite step up from the old girl who has travelled so far with me. It sounds fantastic, retaining that rhythmic coherence that LP12's are famous for, but what the Plinth/Lingo 4 add is a little more air in the upper frequencies- cymbals sound a bit more like they should, with less tizz, and a bit more separation of instruments. The biggest change to my ears has been the increased definition of bass guitar, bass drum, and the bottom end in general. It comes across as stronger, but without the kind of amiable boominess that the older versions of the deck have had. I have found that the change has been for the better with all the styles of music that I play, from rock/pop/metal, to jazz and classical. Overall this renovation of my LP12 has been just what I wanted- bringing a bit more audiophile into the musical fun of the original, without losing any of it.
For the moment I am just enjoying it, currently listening regularly, with no thoughts of what comes next.
Justin
Edited by Juzbear
fixing autocorrect mistakes
well done Justin, nothing better than looking at something you have done and achieved, looks great ( from an ex-Linn owner)
That is a pretty plinth.
If you get the opportunity to get a Tiger Paw Tranquillity I found it to be a nice improvement.
Like you I've gone from a mid 80's LP12 which consequentially I have just put back together to its original form with all the old parts that were upgraded.  For the upgraded deck I have stuck with the fluted linn plinth though, but, is a late large corner braced one.  It has an Ekos1 with akiva, Linn T kable and Pclip, Edmunds Chans SS outer platter and his composite inner platter (later version with the ball at the end) , Tiger Paw Tranquillity, cirkus bearing, kore, new motor and Lingo3, Tangerine Audio Karmen black top plate.
People poo poo Linns continual upgrades.  But for me I have got to a high spec table over time that I would never be able to do in one go.
Food for thought for future upgrades!
I agree with you about the LP12  upgrade path- whilst I am sure you could spend the same amount of money in one go and get a deck that is at least as good, I really enjoy the process, along with the fact that it is not just set and forget.
    • By hugo_wilco
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available. Suburb or Town: Melbourne State: Victoria Payment Method: Paypal EFT cash on pickup Reason for selling: Funds required Further information: This is the latest version and one of the first in the country. It is less then 2 months old.
      One thing I have learnt is that it doesn’t matter how good your arm TT or cartridge is, if you’re phono stage isn’t up to the task you are wasting money and forever chopping and changing.
      This was already a great phono stage but this version has a much more natural and warm presentation. It bested my valve phono stages by a considerable amount.
      It has XLR out too!
      I am actually really reluctant to sell this out of all the items I listed. It can get the most out of ANY cartridge hooked up to it.
      I have all boxes etc.
      https://sonicpurity.com.au/store/phono-stages/rcm-sensor-2-mkii
    • By hugo_wilco
      Item Condition: Excellent just a bit of dust Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: Victoria Payment Method: Eft Paypal Cash on pickup Reason for selling: Funds required Further information:
      Unfortunately due to Pandemic I am forced to sell my gear. This is my favourite TT and has been the longest I’ve had. This TT is phenomenal and I don’t  I want to let this go but don’t have a choice.
      The Ref2 is the latest with the updated power supply.
      Purchased from the wonderful guys at Sonic Purity.
      Will be selling  Phono stage separately
      Your chance to get an endgame TT package at nearly Half  price!!!!
      RRP: $14,900
      Buyer to pay out of pocket Paypal fees.
      Will be boxed so can arrange freight to interstate.
      TURNTABLE ONLY FOR SALE
      Have all boxes and packaging. Will be boxing them in the next few days Nd will post photos.
    • By hugo_wilco
      Item Condition: VG+ Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: Victoria Payment Method: Paypal EFT Cash on pickup Reason for selling: NLR Further information: selling albums I don’t play or haven’t even played.
    • By hugo_wilco
      Item Condition: VG+ Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: Victoria Payment Method: Paypal EFT Cash Reason for selling: NLR Further information: moving on some albums I never played or have played.
    • By don76
      Item Condition: Sealed Mint condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: St Kilda State: Victoria Payment Method: Paypal, Cash on Pickup Reason for selling: Further information:
      Miles Davis - Sketches of Spain.
      Mobile Fidelity 2013 Audiophile Reissue.
      180g Numbered limited edition pressing.
      Half-speed All Analogue mastered.
      Perfect sealed mint condition - crisp corners / clean edges / perfect shrink.
      As featured in "Michael Fremer's top 100 All Analogue reissues".
      These are OUT OF PRINT now and heading towards two hundred $$ on ebay.
      If you're familiar with what happened to the Mofi "******* Brew" prices,  you'll grab this now.
      Experienced seller will provide protective packaging and ship with extra cover and signature for $10.
      Paypal, or if you want to pick up in St kilda - cash only.
      PLEASE READ
