Luke97
Buying my first AV receiver
Hello,
Long story short, i've got my hands on two large front speakers, two smaller rear speakers and a center speaker, but i need an AV receiver to power them. Problem however is that i'm not sure what to look for in terms of AV receiver. I'm mainly looking for an AV receiver that can not just power the speakers i already got but that's also somewhat "futureproof" and will last for a decent amount of time.
The front speakers are rated at 8 ohm 25 to 120W
The rear speakers are rated at 8 ohm 25 to 100W
The center speaker is rated at 8 ohm 25 to 100W
(I currently don't have any subwoofer, i'm currently doing some research and looking at buying a new one later. What i'm looking at is a 5.1 setup)
The ones i've checked out so far are Denon AVR-X2600H and Denon AVR-S650H, could perhaps any of these two do the trick?
Edited by Luke97
What brand and model of speakers are you using? Plenty of brands take extreme liberties with their claimed impedance (ohms) while actually being hard to drive.
I don’t know models but it’s pretty hard to go wrong with a Marantz, Denon or a Yamaha (in that descending order, imho but many would disagree). Good to know a bit more about the speakers but also budget, sources and what you want to do with it.
I maintain you can get pretty spectacular value out of a 2nd hand av receiver if you’re willing to forego some of the latest bells/whistles.
are you in Oslo, Norway? Because that would probably rule out the classifieds
Some major challenges there. Sorry, but AVRs tend to be under powered, loose their value quickly because they do not have latest audio formats, bells and whistles etc.
Firstly on power. Please ignore the marketing BS on the power per channel. NAD, Arcam give the real power per channel when driven simultaneously. But others fudge. To get a better idea of the real power, use the total power consumption divided by number of channels at 50 % efficiency. For e.g
 Denon X2600h with 500W power consumption will give about 35W for each channel.
If you want future proofing, get a multi channel power amp, which does not go out of date and pair with a lower mid range AVR which has preouts. Then, it is cheaper to just replace the AVR.
If you do not want the latest audio formats, then probably can get away with older models. Or buy last year's model when new one comes out.
Lastly, consider room correction software. This is old, but still relevant.
All of them are from the old B&W 300 series speakers
My budget is around 800$. I will mainly be using it for movies and some music.
Yes, i would consider buying something 2nd hand, but my options are limited, it's difficult to find good deals around here unless you go and search overseas.
I see, thanks for the input. I don't know much about audio formats etc, i don't think it matters much, i just want something that's solid with good sound.
Please have a look at this for audio formats
https://www.lifewire.com/what-is-surround-sound-1846802
The biggest change a few years ago is Atmos and there is an article to read.
Solid with good sound could be an older high end model (without Atmos) which has larger power consumption. You did not mention whether you would be using the setup for music. If so, then some brands are better with music e.g. Marantz, Anthem, NAD, Arcam, Cambridge Audio.  The better room correction software will give better sound.
Edited by Snoopy8
Missed earlier post about music
While I can't find any reviews with impedance measurements for your speakers, B&W are one of the prime culprits for claiming innocuous impedance, while often having some very nasty impedance dips in bass frequencies.
As Snoopy8 suggested, consider a gruntier AVR like the recent NADs, that are more likely to cope with such dips. Also, make sure you get a sub, set all your speakers to "small" and crossover to 80Hz or thereabouts - this will take the bass load off your AVR and avoid some of those impedance dips.
Thank you all
I decided to go with a Marantz 6013 that i managed to find with a 20% discount. I mainly choosed this one for the Audyssey XT32.
I think it should be decent enough with it's 680 watts especially since i only run 5 speakers.
Edited by Luke97
5 hours ago, Luke97 said:
Thank you all
Probably better if you disable Audyssey with music, but do compare playing music with and without.
The Marantz will give about 40W (690/9 @50% efficiency).  There may be a slight increase because you are using 5 channels. If you need more power, then get a multi channel power amp.
Enjoy...
