Mat-with-one-t
Cartridge recommendations for Thorens TD-165
Hi all.  A friend broke his cart so I thought I’d help to find a good replacement.  He’s keeping budget to a few hundred, so I thought maybe a quality used MM is in order?
Details of his setup:
- MM phono stage only (so maybe a high output MC could possibly work?) however I have a spare Creek OBH9se mc phono stage to lend him, so open to other options.....
- Thorens TD-165 table, Thorens TP-11 arm, Thorens TP-60 headshell (effective mass 16.5)
A bit of a Google brought up maybe a Denon DL110, or something by Shure?
What do the brains trust reckon?
Mat
Edited by Mat-with-one-t
The DL110 is no longer in production and Shure have stopped all cartridge production.
Maybe look into something like a Garrott K2 or K3.
I actually suggested one of the Garrotts - great minds and all that!  Anyone here used one in this setup?  Once we narrow it down I’ll see if there might be a used one out on the classifieds....
There is  a high standard of performance  and value for money, to be gained from the Ortofon and the  Audio Technica range of cartridges. That is a safer option than a second hand cartridge with a worn diamond or fitted with a  generic replacement diamond  stylus. Look for  the AT VM95E or the OM 10 models as starters.
Edited by VanArn
additions
4 minutes ago, VanArn said:
There is  a high standard of performance  and value for money, to be gained from the Ortofon and the  Audio Technica range of cartridges. That is a safer option than a second hand cartridge with a worn diamond or fitted with a  generic replacement diamond  stylus. Look for   for the AT VM95E or the OM 10 models as starters.
I also thought about AT.  Where would the sweet spot lie?  Mat
It is down to the condition of the vinyl collection ;  if it is  from the '80,s and less than pristine then I would not fuss too much . Even so a  cartridge fitted with a  fine line diamond would be my starting point.
 Vinyl Revival in Fitzroy deal with both the  Ortofon and Audio Technica .
Edited by VanArn
Thanks Van.  Anyone had actual cart experiences on this setup, or have an educated guess re a particular model of cart?
The Tp 11  arm is designed for low mass high compliance cartridges and I would regard it as a good match for most current mm models. A listening session with the ability to compare different cartridges instantly ( using unworn recordings) would be a valid  test.  Alas this service in hi fi shops appears to be a thing of the past.
Yeah true!
So perhaps an AT30?  I found one discussion suggesting it was a good match.
What about a Sumiko blue point 2?
Garrott range?
The AT 30 is obsolete, although a replacement stylus is still available (VN31E). An up-to-date option would be the AT-OC9 series in the moving coil  range. Like the AT VM 95, there are options on the diamond type / cantilever material and unfortunately ,  significant price increases for the more exotic versions.
Thanks Van.  Still compiling a list if anyone has options, especially one to sell!  Mat
And the AT30e is a low output moving coil.  There is an high output model,  the AT30HE, which would work into a MM phono stage.  Though as VanArn says,  all these are now obsolete,  so you are chasing new old stock parts.
If you have a few hundred to spend,  then you could stretch to the AT VM95ML, which has a microline stylus,  though as VanArn suggests,  the condition of the vinyl will determine whether it is worth using such an advanced stylus profile.
I have a AT VM540ML , a little more expensive than the AT95, and is perhaps even better suited as a high compliance cartridge.  In my opinion,  the AT VM540ML sounds fantastic.  I can also say that the AT VM540ML comfortably exceeds the old AT30e in almost every aspect - I used to have an AT30e in my collection.
