alexb
SOLD: FS: Little Dot Mk II Headphone Amplifier (HEAD-FI)
Item: Little Dot Mk II Headphone Amplifier
Price: $SOLD
Item Condition: Mint
Reason for selling: Selling head-fi rig
Payment Method: Pickup, EFT, Cash, Paypal (buyer pays all transaction fees & postage)
Great condition and one of the best value headphone amplifiers available. Australian variant with 220v power supply. Upgraded Value Electronic CV4010 KQDD/K and 6H6 VIII tubes.
The device has a single volume knob on the front along with a blue LED and of course, the 6.3mm port. At the back you can find the input and output RCA pots as well as the power button. The specifications of the amp are as follows:
  • Input: Gold-Plated Unbalanced Phono (RCA) Jacks
  • Output: 1/4" Gold-Plated Stereo Headphone out
  • Driver Tubes: 6JI
  • Power Tubes: 6N6
  • Frequency Response: 20HZ - 50KHz (-1dB)
  • THD+N: 0.1% (50mW into 300 ohms)
  • Suitable Headphone Impedance: 32 - 600 ohms
  • Pre-Amplifier Output Impedance: 10K ohms
  • Power Output:
    • 300mW into 300 ohms
    • 200mW into 120 ohms
    • 100mW into 32 ohms
  • Average Power Usage: 28 watts
  • Dimensions: 210mm (length) by 110mm (width) by 130mm (height)
  • Weight: 2.5 kg or 5.5 lbs.
The Little Dot MK II boasts a SEPP (single ended push pull) circuit (in similar vein to the rest of the MK-series tube amplifiers) greatly increases sound quality, dynamic range, output impedance, and harmonic distortion. The Little Dot MK II also provides gain control of 3, 5, and 10 via internal DIP switches for fine-tuning so you can maximize synergy with almost any headphone you have, whether it be 32 ohms or 600.
Some cheap tube amps have what is called a hybrid design, where the power is provided by a transistor based circuit and the driver circuitry is tube based. Examples of these designs are the headphone amps with only a single vacuum tube (the driver tube). Not only does the Little Dot MK II have a fully tube based design (both power and driver elements are tube based) it actually has independent circuitry for the left and right channels.
So essentially, you have 1 power tube and 1 driver tube for the left channel and 1 power tube and 1 driver tube for the right channel. This is called an SEPP design (think of it as 2 + 2 design).
Edited by alexb
    • By dles1972
      Item: FS: Elemental Watson Gen 2 Hybrid Tube Mosfet Headphone Amp
      Price: $150
      Item Condition: mint (besides dust)
      Reason for selling: no longer needed
      Extra Info: very nice sounding headphone amp. This replaced my Nuforce HDP headphone amp, it just walked all over it when I was A/Bing them which is no small feat if you take 6moon's opinion of the Nuforce's headphone amp being very good indeed. I have barely listened to headphones in a stationery set up in last few years so it's just not being used. Would be lucky to have put 30 hours on it. Purchased new from Jaben for $320 odd......
      Can ship......
      By trimming down on unnecessary luxuries and focusing on core performance, the Watson is able to operate in a dual mono configuration, with a military grade NOS 6AK5 tubes being the center piece of each channel™'s gain stage. Not only does this deliver rich harmonics typical of single ended class-A valve amps but also reduces warm up time of the valves significantly whilst extending the life of each valve to operate at their peak performance for more than 1000 hours per channel.
      Class A Valve/MOSFET hybrid tube desktop headphone amplifier Supports 30- 600 Ohm impedance headphones. Dual Mono Construction Delivers rich harmonics in single-ended topology. Western Electric Triodes Uses two Bell Lab/Western Electric 6AK5 valve tubes yields and produces excellent high-frequency performance. Smart Power Design Eliminates any 'Pop' sound when switching power on/off. Thus, no concern for pulse energy damage to your headphones. Compact and light-weight Easy handling size and small footprint. Portable.
    • By CAVL
      Item: JDS EL DAC, ATOM, HIFIMAN HE-4XX, AUDIOQUEST DRAGONGLY RED.
      Price: EL DAC $220 AUD, ATOM Sold, HIFIMAN HE-4XX Sold, DRAGONFLY RED Sold + Shipping.
      Item Condition: JDS EL DAC and ATOM bought on Jun 2019 with 2 years transferable warranty, they have been on my bedside table and are in very good condition, covered when not in use, HE-4XX bought on July from Drop.com has had very little use, I chose another headphones and put this ones in the box, Dragonfly red came in a bundle and box still sealed.
      Reason for selling: Downsizing.
      Payment Method: Pickup - Cash, Paypal, Bank Transfer.
      Extra Info: Equipment will be sent on original boxes once the payment is done.
    • By Vladas
      Item:
      MASTERSOUND INTEGRATED BOX R
      Parallel Single Ended in "Class A" Integrated - Made in Italy
      Power: 2 x 35 Watt
      Tubes complement: 2 x ECC802 - 6 x EL34
      Input: 3 line + Phono MM
      Output: 1 line
      Load imped.: 4-8 ohm
      Bandwidth: 18 hz / 25 khz 0 db
      Output Transformer: MastersounD
      Automatic Bias
      Supplied with remote control - R version
      Negative feedback: 0 db
      Dimensions: 43,6 x 40,9 x 18,5 cm
      Weight: 24 Kg
      Made in Italy
      Price:  $3000 (RRP - $5200)
      Item Condition: Brand New - still in the box
      Reason for selling: Change of financial situation
      Pure Class A  2x35 Watt PSET (Parallel Set) which is used in the very high end tube
      amplifiers like Aries Cerat $30K USD. This gives you uncompromising power to run in pure class A almost any 89+ db speakers.  Lack of power is Achilles weak spot of most tube amplifiers and I believe PSET is the best solution used by the very high end manufacturers. Legendary Mastersound brand - makes PF100 tube amplifier $50K USD. Fabulous musical EL34 tubes. To my knowledge, this model is absolutely the best value for integrated tube amplifier in that price range; made in Italy but priced similarly to comparable Chinese models. Includes very good phono pre-amplifier - same as in the flagship models.  This is Box R version with remote control (cost $330 AUD extra).
      Links below shows additional information about The Box and Mastersound brand in general:
      http://www.mastersoundsas.it/1/reviews_4451773.html
      https://soundapproach.com/mastersound-box-r-integrated-amplifier-class-a.html
      https://www.technologyfactory.eu/en/mastersound/integrated-amplifiers/mastersound-box/a-5384-10000401
      https://forum.audiogon.com/discussions/axpona-2018-integrated-mastersond-box
    • By muzzworld
      Item: Yamamoto HA-02
      Price: $690
      Item Condition: Excellent
      Reason for selling: Not used
      Extra Info: For sale is my gorgeous headphone amplifier hand crafted in Japan. It just doesn't get the use it deserves.
      It is in wonderful condition, and has heaps of glowing praise bestowed upon it by the doyens of the internet. Look it up!
      Happy to demo or answer any questions. Its probably easiest to sell it locally with pickup but could quite easily be well packed for shipping.
      Happy listening.
