Ericcklau
Mono cartridge
Hi all
I would like to ask if I want to try out the Mono cartridge AT-MONO3LP, can it play with normal MM phono?
Thank you
ERIC
FREQUENCY RESPONSE    20 - 20,000Hz
VERTICAL TRACKING FORCE    1.5 to 2.5 g (standard 2.0 g)
RECOMMENDED LOAD IMPEDANCE    400 - 47,000 ohms
OUTPUT    1.2 mV (at 1 kHz, 5.0 cm/sec)
STYLUS SHAPE    Conical
CANTILEVER    Aluminum Pipe
MOUNT    Half-inch
Lp is high output MC so MM phono is fine.
14 hours ago, Ericcklau said:
Hi all
Thank you
ERIC
MOUNT    Half-inch
Actually, with only 1.2mV output, the AT-MONO3LP will not suit a few MM phono stages - those that have lower gain than normal.
The standard 40dB gain should be OK - although 42/43 dB would be better.  However, I have seen phono stages with only 38dB.
Also, seeing as the mfrs recommended load is given as:  400 - 47,000 ohms, you may find it sounds better when the load is less than the default 47K!  Not many MM phono stages allow you to change load easily.
What phono stage do you have, Eric?
Edited by andyr
Also, seeing as the mfrs recommended load is given as:  400 - 47,000 ohms, you may find it sounds better when the load is less than the default 47K!  Not many MM phono stages allow you to change lead easily.
Thank you Andy
My amplifier does have some selection on the phono options. Should I stay in MC?
2 hours ago, Ericcklau said:
Thank you Andy
It depends, Eric!  :(
Basically, the only load options you can use are:
  • 47K on 'Phono-2' (the MM input), or
  • 47K on 'Phono-1' (the MC input).
Do you have the specs of the sensitivity of these phono inputs.  For instance, it might say something like "Phono-2 accepts 4mV" - in which case, your 1.2mV may be too low.  Or if MM gain is specified as 42/43dB ... you should be fine.  :)
If Phono-1 "accepts 0.5mV" - then 1.2mV will probably not overload the MC input.  However if the MC input accepts 0.2mV ... then 1.2mV may be too high a signal for it.  :(
You need to try both inputs - if you hear distortion on MC (or it's simply not loud enough on MM and you get too much hiss when you turn up the volume control) ... then you have an incompatibility with your integrated.
Good luck!
Good luck!
Hi Andy
Just search my amp information below:
It seems that the max input for MC is 7.5mV so may be I can use MC to play it right?
Model Stereo integrated amplifier
Effective output (0.03%, Aux) 20Hz to 20kHz: 140W + 140W (4Ω, Class B)
         120W + 120W (8Ω, Class B)
         30W + 30W (8Ω, Class A)
1kHz: 180W + 180W (4Ω, Class B)
    130W + 130W (8Ω, Class B ) )
Total harmonic distortion (20Hz-20kHz) Phono1, 2 → Rec out (5V): 0.003% or less
Phono MC → Rec out (3V): 0.03% or less
Tuner, Aux → Pre out (3V): 0.005% or less
Main in → SP out (60W, Class B, 8Ω 😞 0.01% or less
           (15W, Class A, 8Ω): 0.005% or less
Tuner → SP out (60W, Class B, 8Ω): 0.01% or less
Power bandwidth (0.03%, 8Ω) Class B: 10Hz to 50kHz
Class A: 10Hz to 70kHz
Damping factor 45 or more (8Ω, 1kHz)
Frequency characteristic Phono 1, 2 MC (RIAA deviation):
30Hz
- 15kHz ± 0.2dB Tuner-Pre out: 5Hz-100kHz +0 -1dB Tuner-SP out (8Ω load): 5Hz-50kHz +0 -1dB
Input sensitivity (rated) / impedance Phono 1: 2mV / 47kΩ, 68kΩ, 100kΩ
Phono 2: 2mV / 47kΩ
Phono MC: 50μV / 10Ω
Tuner, Aux: 120mV / 50kΩ
Main in: 1V / 50kΩ
Maximum allowable input (1kHz, 0.02% distortion) Phono1, 2: 310mVr.ms
Phono MC: 7.5mVr.ms
Tuner, Aux: 20Vr.ms
Output level / impedance Rec out: 120mV / 600Ω
Pre out: 1V / 500Ω
Tone control characteristics Bass (125Hz⇔500Hz): ± 10dB (20Hz)
Treble (8kHz⇔2.5kHz): ± 10dB (20kHz)
Subsonic filter 15Hz, 12dB / oct
High filter 10Hz, 12dB / oct
Noise level / SNR (IHF-A Network) Phono1, 2: 82dB
Phono MC: 71dB (input 50Ω short)
       68dB (input 0Ω short)
Tuner, Aux, Tape: 100dB
Main: 118dB
Residual noise 0.07mV or less
<Meter part>
Instruction range -50dB to + 5dB
response speed 100μs
Return speed 0.95sec
<Others>
Power supply AC100V, 50Hz / 60Hz
Rated power consumption 300W
External dimensions Width 461x height 170x depth of 360mm
weight 20kg
Hi @Ericcklau,
The below specs are somewhat confusing to me!  :(
All, I can suggest is that you try it out in all 3 of your phono inputs - yes, you have 3:
  • Phono 1
  • Phono 2, and
  • MC.
The maximum allowable input for MC is an amazing 7.5mV - however, this comes (stupidly IMO) with a default loading of 10 ohms ... which is not in the recommended range for your mono cart.
The maximum allowable input for the 2 MM inputs is an amazing 310mV - however, the input sensitivity is 2mV ... so your 1.2mV may be too low?  :(
So you need to try it out; can you compensate for the low input on Phono 1 and Phono 2 by turning up the volume control?
Looks like it is a Yamaha amp, I used to have a 700 something.... MM was fine with my ex AT MONO3 LP.
39 minutes ago, andyr said:
Hi @Ericcklau,
  • Phono 1
  • Phono 2, and
  • MC.
Thank you guys
An MC output is with 5cm/s groove modulation. Peak groove modulations, I understand, can be as high as 15 to 20cm/s. So a 1.2mV cart, might put out 3.6 to 4.8mV, leaving only 4dB of headroom for your MC input, which might be a bit small. So  the phono 1&2 (MM) inputs would be a safer bet. However, your cartridge should still provide peaks from the 47K MM inputs to the line stage of 200 to 250mV to feed the 18dB line stage. A CD player with 2V output means max power out put from your amp is probably around -24dB +/-6dB.  Using your MM input, volume setting might be in the order of 10dB higher compared to CD.
So agree with Andy, suck it and see.
Grant
Grant
Thank you gnnett I will try it when the cartridge arrive. Thank you
