timelord9 Posted February 13, 2020 Share Posted February 13, 2020 (edited) Item: Vincent Audio SV237. Black. Location: Melbourne Price: 1300 dollarydoos. Item Condition: Excellent Reason for selling: Raising capital for domestic transducer development. Payment Method: Pickup - Cash, COD Only Extra Info: Purchased 2nd hand last year, this amp has seen very little use. I have the original box, but its super heavy and (at this stage) would prefer not to post. The amp is in perfect working order and buyers can demo with my Focals. Pick up from Thornbury or Abbotsford. Specs: Frequency Response: 20 Hz - 20 kHz +/- 0.5 dB, 20 Hz - 50 kHz +/-2 dB Nominal Output Power RMS / 8 Ohm: 2 x 150 Watt Nominal Output Power RMS / 4 Ohm: 2 x 250 Watt Nominal Output Power Class A / 8 Ohm: 2 x 10 Watt Harmonic Distortion: < 0.1 % (1 kHz, 1 Watt) Input Sensitivity: 300 mV Signal-Noise Ratio: > 90 dB Input Impedance: 47 kOhm Inputs: 4 x Stereo RCA, 1 USB Outputs: 1 x Stereo RCA Pre Out, 1 x Stereo RCA Rec Out, 4 x 2 Speaker Terminal, 2 x 3.5 mm Jack (Power Control) Tubes: 1 x 12AX7; 2 x 6N1P-EV Colour: Black Weight: 20.4 kg Dimensions (WxHxD): 430 x 152 x 435 mm Comes with remote. Note: This is the original SV237. The link below is with the updated digital input. https://www.vincent-tac.de/en/product-lines/tubeline/sv-237mk.html Photos: Edited February 14, 2020 by timelord9 updating model details 1 Link to comment Share on other sites More sharing options...
Steffen Posted February 13, 2020 Share Posted February 13, 2020 Going by the picture of the amplifier's back, this appears to be the SV237, rather than SV237MK (USB input instead of SPDIF/Toslink). Can you confirm? Assuming that's the case, does anybody know the digital formats the USB DAC can digest? The manual (https://www.vincent-tac.de/fileadmin/pdf/BDA/Vollverstaerker/BDA_SV-237_DE_EN_FR.pdf) keeps quiet about that. Link to comment Share on other sites More sharing options...
shovel Posted February 13, 2020 Share Posted February 13, 2020 Whats the conversion rate of dollarydoos to Australian dollars? 1 3 Link to comment Share on other sites More sharing options...
timelord9 Posted February 13, 2020 Author Share Posted February 13, 2020 1 hour ago, Steffen said: Going by the picture of the amplifier's back, this appears to be the SV237, rather than SV237MK (USB input instead of SPDIF/Toslink). Can you confirm? Assuming that's the case, does anybody know the digital formats the USB DAC can digest? The manual (https://www.vincent-tac.de/fileadmin/pdf/BDA/Vollverstaerker/BDA_SV-237_DE_EN_FR.pdf) keeps quiet about that. Hi Steffen My apologies, I thought the nomenclature was Mk 1 and Mk 2. Mine is the original SV237 with USB rather than toslink. 1 Link to comment Share on other sites More sharing options...
timelord9 Posted February 13, 2020 Author Share Posted February 13, 2020 (edited) 21 minutes ago, shovel said: Whats the conversion rate of dollarydoos to Australian dollars? Xe.com has it at parity right now. I'd get in quick before the AUD drops any further though. Edited February 13, 2020 by timelord9 5 3 Link to comment Share on other sites More sharing options...
