LWA Staff
Audiolab M-DAC D/A Converter
Item: Audiolab M-DAC D/A Converter
Price:  Was $740 StereoNET Member Special $640
Item Condition: Excellent Secondhand Condition
Payment Method: Credit Cards, Cash, Bank Transfer, Paypal, ZipPay with upt o six months interest free!
Shipping: Anywhere in Australia, POA
Extra Info:  The M-DAC offers a solid build and ample connectivity. Alongside the USB input with Asynchronous data processing, there are two each of coaxial and optical digital inputs, and one each of coaxial and optical digital outputs. Audio signal is provided via RCA single-ended and XLR balanced audio outputs. While the large clear screen allows you to see what input is being used and the sample rate being received. High-res 24-bit/192kHz music files can be played on the M-DAC via the coaxial input, while optical and USB inputs support 24-bit/96kHz data.
Specifications:
DAC: ESS Sabre32 9018 chip
Resolution: 32 bits
Maximum Sampling Frequency: 84.672MHz
Digital input: 2 x 24-bit/192kHz coaxial ,2 x 24-bit/96kHz Toslink optical, 1 x 24-bit/96kHz USB
Digital output: 1 x coaxial, 1x Toslink optical
Output voltageRCA: 2.25V RMS,XLR: 4.5V RMS
Total Harmonic Distortion RCA: <0.002%; XLR: <0.0008%
Frequency response: 20Hz - 20kHz (± 0.2dB)
Dynamic range RCA: >115dB;XLR: >122dB
Crosstalk RCA: <-120dB;  XLR: <-130dB
Dimensions (H x W x D)59 x 250 x252 mm
