arthurp
PRO-JECT DEBUT CARBON RECORDMASTER HIRES
Howdy Folks
I have a strong desire to record my vinyl albums in an easy way. I dont want to disassemble my RP 10 from my primary stereo system and link it up to my PC. Instead I was hoping to buy a new TT that can record and operate as a second TT for my study. I have in my study Axis Voicebox-S Bookshelf Speakers, a Bryston 4B3 amp and a Tron preamp with a Cary CD player and an old Eumig Tuner. I mostly listen to my Astell & Kern and the Tuner. Most of the music on my portable music player are CD's I've ripped. So I was looking for a TT with a dual function. Firstly to rip my vinyl simply, and secondly when working in my study listen to Albums. I note there is a PRO-JECT DEBUT CARBON RECORDMASTER HIRES TT that may suit this function. I have no experience of it. Anybody out there in Stereonet land that has any feedback on this recording TT and /or my approach and alternatives would be much appreciated.
I have the Carbon Recordmaster Hires and am very happy with it.  It does what you outline.
I am mainly digital and don't listen to a lot of vinyl direct - so mainly use it for ripping, and every now and then to listen to an album.  It makes that very easy.  Flexible in its connections and sounds as I would expect a $1k Pro-Ject turntable to - which is pretty good.
Note its analogue output is line level and it has a level adjustment on board to adjust that, and digital signal out level.
 I did consider separates as I have had before but I am also into simplification!  When I looked it was the best of the available turntables with pre-amp and A/D built in and I think it still fits that bill.  It is quite a small footprint as well.
Its only quirk is that if you use its analogue input to digital output (which I do for the good old cassette deck) you need the platter turning for the A/D to be available.
Gibbo
Appreciate the options guys. Ill check out both.
Good luck with the decision - both good outcomes at different 'budget' points.  Note the Hires is often on special with new price <$800
I have a local provider who will sell for just under $800. Will check it out.
