ExCaLiBur9
Help me choose atmos ceiling speakers
Hi guys. Another help me choose thread. I am currently building my house and planning to have a 5.2.2 setup in my theatre room. Room measurements are 4240mm X 3080mm, ground floor of a 2 storey home in Sydney North West. My current speakers are all Richter MK4 speakers. Have not decided on a AV Receiver yet as the build still have a few months to go but leaning towards a Sony STR-DN1080. Usage would be 80% movies and 20% music. I am looking to get a pair of ceiling speakers for atmos use. My budget is around $500 but can be stretched if necessary. Any suggestions on ceiling speakers that I should look into, which would be a match for my current setup?
Reading through some other forums, I am considering the below, but this is only based on my limited research.
1. https://www.selby.com.au/pair-of-8in-angled-glass-fibre-ceiling-speakers-xd8205b-x2.html
2. https://www.customht.com.au/products/ns-ic800?variant=14009024544820&currency=AUD&utm_source=google&utm_medium=cpc&utm_campaign=google+shopping&gclid=CjwKCAiAj-_xBRBjEiwAmRbqYqUTjJD_qtRPY4ljtjTx-S0A6j8l8A5j_XWP0sUXE43JjFZ6SquQbxoC5rYQAvD_BwE
Appreciate any help. Thank you.
Edited by ExCaLiBur9
I'll let others recommend the speakers, but you might want to reconsider the Sony STR-DN1080 - it has a maximum power consumption of 240W. After applying 70% typical class A/B amplifier efficiency that leaves 168W spread over 7 channels i.e. 24W per channel. That's before we consider power losses for the pre-amp section etc.
You really need highly efficient speakers and/or low listening levels to avoid clipping with this Mr Puniverse of receivers. Almost any other brand would be better.
Hey Quark. Thanks for the insight. Read a lot of good reviews on the Sony, could be misleading. What would you recommed? Trying not to spend more than 1k if possible. My current AVR is an old Marantz SR6008. Was also considering a Yammy RX-V685. Thoughts?
The 685 would be a much better option. :)
Consider the environment your atmos speakers are going in Excalibur ; its a good move to have an enclosed back so dust isn't a factor and the driver has a known displacement to interact with . The more frequency extension you can afford the better ;I have Krix ;  well known aussie pedigree :)
https://www.krix.com.au/in-ceiling/
Edited by cwt
If you spend $100 on second hand speakers than you can move remaining $400 toward new AVR.
BTW your old Marantz is better than that brand new Sony. You need to get Marantz SR6013 or better me think.
I may have a Pioneer VSX 1131 5.1.2 receiver up for sale soon - it was stop gap while I replaced my failed Yamaha RX-A3040 with a RX-V3079 and Rotel 5 channel amp.
I have only just installed the new gear so not fully set up but the new gear doesn't sound any different to the Pioneer !!
Those Tannoys I linked have a sealed back and you seriously cannot go wrong - buy 4 just in case you decide to upgrade to .4 Atmos later - although in your sized room .2 will be OK.
$100 for 2 Tannoys and $400 for my receiver - $500 for a (mild) killer setup 😁
Edited by niterida
What Richters?
I have the Yamy RXV685 running 5.1.2 - Richter Harlequin V (mains),  Jamo centre, Richter Merlins V (rear surr) and Dali Altico C1 (rear height/atmos) and an SVS SB2000 in a 4m x 5M (ish) room.
Amp doesn't have an issue running them (wife usually complains its too loud🙄)
2 hours ago, hometheatrebugbitten said:
What Richters?
I'm running the Richter Wizards IV for mains, Unicorn for center, Merlins IV for surround and an old harman kardon for sub.
Thank you for the offer @niterida but wanna get a brand new receiver.
Between the Yammy RX-V685 and Marantz SR6014, or even with the Onkyo TX-NR686 anyone had any experience with any of them? which would be recommended for my 5.2.1 setup?
The Marantz SR6014 would be the clear leader out of the three, but in a different price league too. It has the best room correction (Audyssey XT32).  Onkyo's room correction is pathetic and I have trouble recommending them after their many years of appalling reliability and repeated assurances that it was fixed with each new release only to find over time that it wasn't (I used to be an Onkyo/Integra fan when they were in their heyday).
Good point @Quark. The Marantz price looks like almost double that of the Onkyo 696 or yammy 685. Since I only plan to buy in the next 4-6 months and only need 5.2.1 setup, do you think the Marantz SR5013 would be an option too if i wanted to lower the cost?
The SR5013 and its replacement the SR5014, only have Audyssey XT room correction and its a big step backwards from XT32 (does minimal bass EQ, which is where you generally need it most).
Consider a Denon X3500 (on runout) or X3600. Denon is the sister brand of Marantz and shares a lot of tech. Still going to cost a lot more than your other options.
you really need to decide your avr budget
excel hifi have the 685 refurb on special under $560
https://www.excelhifi.com.au/yamaha-rx-v685-refurbished.html
    • By ajricho
      Item: Richter Wizard Mk II speakers
      Price: $190 negotiable
      Item Condition: Good. Tweeter and mid-range drivers replaced-details below
      Reason for selling: These were my parents speakers-selling on their behalf. They have moved into a retirement home and no room for them. Unfortunately also too big for my house
      Payment Method: PayPal, Cash - Pickup
      Extra Info: As mentioned, these were my parents speakers - they bought from new in 1996. They had problems with them in the early years of ownership, with the tweeter and mid-range drivers replaced on each by Richter under warranty. The original drivers may not have been available as they are different. The tweeter in each is a Vifa TC20TD05-06. Mid-range in each is a Vifa P17WJ-00-08. The Woofers weren't replaced and still original Audax HT170G2. The speakers are fully functional and the cabinets and covers are in very good original condition
    • By superaaaa
      Item: Denon AVC-X8500B
      Price: $4000 $3800 + shipping
      Item Condition: Excellent (1.5 years old – but has been boxed for last 5 months)
      Reason for selling: Moved house with no room for theatre ☹
      Payment Method: Pickup - Cash, Paypal, Bank Transfer
      Extra Info
      Denon’s flagship AVR with 13.2 channels. Allows for a very flexible arrangement with 9.2.4, 7.2.6 ATMOS, DTS-X or Auro layouts.
      The 13 channels are fully amplified, so an external amp is not required to fully use all channels.
      Comes with all documents and accessories. Have original box, so shipping is an option (fyi this thing is not light).
      If you search my name, you’ll see details of my previous system(s) so know that I am an enthusiast. Rest assured when I say this is a quality and very capable product. I was extremely happy with the Denon. If I still had my system, I would have happily kept it until it died (with the only reason to change out being going to a higher channel count).
    • By StereoInOz
      I have a set of vintage Excalibur's and they have spike holes pre-drilled and threaded, but I have no clue what the screw type is or dspecificaton so I can order the right spikes for them.  Anyone have any ideas?  Thanks in advance.
    • By Isaac Otaiza
      Item: Richter Harlequin mk2 speakers
      Price: $400
      Item Condition: good condition
      Extra Info: Had these in storage for quite a while.
      Recently connected  to them to my AVM60 / xpa 5 amps
      sound was fantastic. Totally forgot how great these sound. For small towers , they filled the room.
      A few marks and scuffs nothing serious. They perform perfectly for music or HT
    • By shazza6887
      Item:  Denon X4500H + Emotiva BasX A150,  7.2.4 Atmos / DTS-X  Capability
      Price:  $2700
      Item Condition: As new!
      Reason for selling: Upgrading to Pre/Pro Setup
      Items are as new, only used for a couple of months. As stated above wanting to upgrade to a Pre/Pro setup for my dedicated home theatre. Have all boxes, plastics etc - kept everything. Will be boxed up like they are brand new! Reciever has been cooled by a AC infinity from day 1, I ran my full 7.2.4 setup with these with no problems and it sounded great. Pm for further.
