HiFi Collector Adelaide
SOLD: FS: Harbeth 30.2 Anniversary Loudspeakers Silver Eucalyptus with TonTräger Speaker Stands (One Pair)
Item:
Harbeth 30.2 Anniversary Loudspeakers Silver Eucalyptus (One Pair)
TonTräger Speaker stands for Harbeth M30 in Beech Black 60cm
Price: $6,200 (RRP was $9,340)
[RRP was $7,550 for 30.2 Anniversary, $1,790 TonTrager stands]
Please PM us for shipping quote.
Item Condition: As new condition.
Reason for selling: These were ordered in for a customer who instead decided to go with Harbeth 40.2s! Barely run in.
Payment Method: Direct deposit, credit/debit card, cash (pickup), PayPal
The next generation of Harbeth's M30.1 model; the M30.2, is now available in a limited edition silver eucalyptus veneer. The M30.2 anniversary model features the latest WBT-nextgen binding posts, a new-look tweeter with silver hex grill, British-made audio grade poly capacitors, and Harbeth's 40th anniversary ultra-pure OFC internal cable.
"The best compact two-way speaker system I have ever heard, regardless of design type, cost, or complexity." ‐ Paul Seydor
The Monitor 30.2 - 40th Anniversary Edition is available in Silver Eucalyptus
Specifications:
Drivers:    2-way vented: 200mm (8") Harbeth RADIAL2™ bass/mid; 25mm Ferro-cooled soft-dome tweeter with Hex Grille
Freq Response:     50Hz-20kHz (+/-3dB free space, grille on, smooth off-axis response)
Impedance:    6 ohms - easy to drive
Sensitivity:    85dB (@1watt/1m)
Amplification:    Works with a wide variety of amplifiers, ideally from 25w
Dimensions:    460 x 277 x 275mm (HxWxD, +12mm for grille and binding posts)
Weight:    11.6kg each (without packing)
TonTrager Speaker stands for Harbeth M30 Beech Black
60cm height
Handcrafted production
TonTräger.audio stands are manufactured to the highest precision.
All products are planned, developed and tested in our workshop.
Resonance dissipation and decoupling
Extended tenons allow direct absorption of cabinet resonances and decouple the speaker from the ground.
Materials
We use specially selected high quality raw materials for our sound furniture.
Solid wood
We only use wood from FSC-certified local forests.
Multilayer surface coating
Surfaces are coated with natural oils and pigments in several processing steps. [MORE]
Plastic and metal free
TonTräger.audio deliberately avoids the use of metal or plastic elements.
Installation-friendly
TonTräger.audio stands come ready assembled
IMG_7170.thumb.JPG.65f319cf147c150e96f434f4462498a8.JPGIMG_0539.thumb.JPG.f57a36b8ffb0b1a0c5767dae15904e30.JPGIMG_8093.thumb.JPG.577bbfa0d9e5e9fbd5900f14252e60d4.JPGIMG_8094.thumb.JPG.2aaff0100b4eed0e650845c1d5f1d5fa.JPGIMG_8095.thumb.JPG.8049929ef189bc70e6915f91b041811f.JPGIMG_8096.thumb.JPG.c3f58a71225fb7a6d945f10115d235e8.JPGIMG_8099.thumb.JPG.6efe906263e1e909a8cd780d09d2d0b5.JPGIMG_8098.thumb.JPG.a5d3109a0eba3f99eaf55d447ec70d07.JPGIMG_8097.thumb.JPG.acc462f0ba1879984acaa0cb6a46c424.JPG
Edited by HiFi Collector Adelaide
Greetings Hi Fi Collector,
I would love these, pity there outside my current budget, as I have been looking to purchase a pair of Harbeth P3ESRs, which of course are decidedly cheaper in price.
Maybe one day I can trade up to these, I would be interested how these sound compared to the P3ESRs.
Good luck with your sale, someone is going to very happy.
Alan
6 ohm at 85 db easy load to drive?
If anyone is new to audio, those specs are certainly not easy.
Some top notch amplification required for good results.
Looking at how much of the impedance plot is above 8ohm (min 5.8) and no nasty capacitive phase angles, the 30.2 should be well suited to a reasonably powerful valve amp. SS amps don't put out as much wattage into a speaker at higher impedances so I can see why you'd need to use a pretty powerful ss amp. A fair chunk of midrange frequency is 10-24ohms.
Such beautiful finish the eucalyptus.. GLWTS
    • By Harbord
      Item: ViaBlue T6s Banana Plugs - 4 pieces including hex tool
      Price: $70 including postage Australia wide
      Item Condition: Open box, unused
      Reason for selling: Not Suitable for my cabling
      Payment Method: Bank Transfer
      MAX. OUTER DIAMETER: ‧ 13.5 MM
      CONTACT: ‧ 4 MM TUBE
      FINISHING: ‧ 24 KARAT GOLD PLATED
      TOTAL LENGTH: ‧ 49.1 MM
      MAX. CABLE INPUT: ‧ FOR CABLES WITH O 3-9.5 MM
      MARKING: ‧ BLACK / RED
      SCREWS ‧ 1.5 MM HEXAGON
      For the assembly the stripped cable ends are soldered at the contact parts of the T6s plugs. The contact part can be removed completely from the plug's shell. The M4 screw serves as strain relief. The shell for all plugs (exception: XLR plugs) of the ViaBlue™ T6s series is identical. Only the contact parts change.
      Each T6s plug contains two diameter decreasers which serve for a firm strain relief and centric adjustment of the cables.
      The small diameter decreaser has an outter diameter of 7.5 mm and an inner diameter of 4.5 mm. Thus cables with an outter diameter of 3 mm up to 4.5 mm can be fixed firmly.  The big diameter decreaser has an outter diameter of 9.5 mm and an inner diameter of 7.5 mm. Thus cables with an outter diameter from 5 mm to 7.5 mm can be fixed firmly.  Without using any diameter decreaser cables with diameters from 7.5 mm to 9.5 mm can be installed.
    • By DrCircus
      Item: ALO AUDIO PURE SILVER LITZ REPLACEMENT IEM CABLE MMCX - BALANCE 2.5MM
      Price: 250$ incl paypal fee
      Item Condition: Mint, little used
      Reason for selling: I got a Ref8 cable instead
      Extra Info: bought this from Addicted To Audio, but upgraded to a Ref8 shortly after so no use for it now. RRP is 379$. Perfect condition, box and soft bag included. Postage $10 to Aus
    • By Willmax
      Item: KEF 104/2 Reference Speakers
      Price: $1100 - free shipping in Australia
      Item Condition: Very good for age, gorgeous sound.
      Reason for selling: thinning the heard
      Payment Method: Pickup - Cash, EFT, PPF
      Extra Info: See original listing below, gorgeous sound for very reasonable money.
      Original tweeters, recapped Falcon Acoustics Crossovers, replaced donuts, redone grills cloths, all works done by previous owner.
      Happy to deliver to nearest P&S for interstate parties.
      Recent Videos:
    • By Baz W
      Item: Jazz Vinyl Collection x 8
      Price: $70.00 plus postage for all 8 lps or priced as below plus postage ( minimum purchase of three lps)
      Item Condition: Covers vg++ Vinyl nm
      Reason for selling: NLR
      Titles:
      Chuck Mangione : Fun Games $10
      David Sanborn : Backstreet $10
      Red Rodney & Ira Sullivan : Spirit Within $10
      Roy Ayers : A Stranger To Love $15
      Jim Hall : Commitment $15
      Spyro Gyra : Fast Forward  $10
      George Benson : Breezin $10
      Grover Washington : Winelight $10
    • By Gambit 1870
      Item: Focal Aria 936 Floor Standing Speakers (Pair)- Piano Gloss Black
      Price: $3750 $3300
      Item Condition: Excellent
      Reason for selling: Have upgraded
      Payment Method: Pickup - Cash, Bank Transfer
      Price drop to move these along as they should be in someones system, not in my office 😁
      These pair of speakers look like they have just come out of the box, they are a tad over 2 1/2 years old and have only been run for half that time.
      They have spent their life in a smoke and pet free environment and have not been to subject to curiuos or sticky young fingers.
      I have the orignial boxes so shipping can be arranged at buyers expense, I will provide extra internal packing to help protect them in transit.
      System type 3-way Enclosure type Bass-reflex Frequency response ± 3dB 39 - 28000 Hz Nominal impedance 8 Ohm Amplifier Requirements 50 - 300 W Sensitivity (2.83V/1m) 92 dB Tweeter 25mm (1 in.) Midrange 165mm (6.5 in.) Woofer 3 x 165mm (6.5 in.) Dimensions (H x W x D) 1150x294x371mm (45.25x11.56x14.62) Weight 29 kg (64 lbs)
