mlw
SOLD: FS: Concert Fidelity ZL200 monoblocks Price reduced
Item: Concert Fidelity ZL200 monoblocks (price reduced)
Price: $8500
Item Condition: Excellent
8/10 on Audiogon scale
Reason for selling: Reconfiguration of system (for balanced operation)
Extra Info: purchased second hand around 5 years ago. Rarely used and always used with PS Audio conditioner. New price for these were $48,000 US ($70,000 AUD!) - very expensive (and heavy) mono blocks. You will not find any power amps of this quality near this price. This amp received the Absolute Sound 2012 Editor's Choice Award.
The unique sound of the ZL-200 is aptly described by Mr. Harry Pearson: "These monoblocks are the first solid-state amps I've heard that sound like a tubed unit, and by that I mean a very good tubed unit, on the order of say, the best conrad-johnson amp (vide, the ART III) but lacking the golden glow of the CJ sound, thus rather more uncolored than most, if not all, of the transistorized competition. It has the dynamics of good tubed unit, the focus on instruments and the sense of an ambient field that is characteristic of the old William Z. Johnson design for Audio Research.
Sale pending.
    • By MAXXX
      Item: HALCRO Logic MC20, power amplifier
      Price: $2000
      Item Condition: Excellent 9/10
      Reason for selling: Too many amps
      Purchased app. 4 months ago from Simply HIFI here in Perth.
      Power Output: 400W RMS continuous into 4 Ohms Distortion THD: <0.007% at 1kHz at all powers up to 400W into 4 Ohms, <0.03% at 7kHz at all powers up to 400W Unbalanced and Balanced Voltage Inputs Mains Voltage: 100 – 120VAC or 190 – 250VAC Remote trigger switch between On & Standby Command Functions: Switch between On & Standby Ability to inhibit individual amplifier modules Amplifier module will indicate Over Temperature condition Halcro Reliability Assurance Service Dimensions
      Weight: 49.8lb or 21.1 kg Height: 7 inches or 169mm Width: 17 inches or 438mm Depth: 16 inches or 410mm   Local sale preferred (demo, proper check-up etc.), but happy to send as well...Currently hooked on ProAc Studio 140.
      Lots of reviews on Net.
      Asking price is less than half of other Halcro MC20 advertised on Ebay...
      Note: No original box, comes with the manual. Minor imperfection on front  left corner as seen on the  photo.
    • By SoundGuy
      Price: $12,000 $10,500 $9300
      Main Features
      Gain 26.8dB
      Power Consumption 300W
      Width 17.75" (45.1cm)
      Depth 19.83" (50.4cm)
    • By MattyW
      Ok, now that I've had my Wavebourn Edelweiss-3 for a few months and it's nicely burned in it's time for me to prepare writing my review of it which I'll post here over the coming month. I'll post my impressions and experience purchasing this wonderful amp from Anatoliy Lisovskiy, who will be releasing the production series of the Edelweiss-3 power amp, an integrated amp and separate preamp over the course of this year.
      As I understand it the current production version of the power amp and integrated will all be EL34 though allow and pin compatible tube to be used right through to KT120, possibly even KT150. My own amp on the other hand uses WW2 vintage CV1127 radar sweep tubes.
      The reason I initially started looking into a lower powered amp was that 6 months ago I built my first pair of DIY speakers. A pair of shallow cabinet open back speakers which share the performance characteristics of U frame open baffles. Unfortunately the copy darTZeel NHB-108B power amp I was running at the time was far too powerful making my 101db sensitive speakers too loud for regular use so I started investigating lower powered tube amps.
      While looking into various solutions someone on AudioKarma pointed me in the direction of Anatoliy's Wavebourn amps and I got in touch via the Wavebourn facebook group. Over the next month or so I had an interesting discussion with Anatoliy about his amps, and their suitabillity to drive my DIY speakers (Lii Audio FAST-10 full range, Aurum Cantus G3Si ribbon, Skar Audio VX1ST bullet & Lii Audio W-15 woofer) and this led to discussions of his amps variable damping factors allowing suitabillity with a wide range of speakers. A feature which I believe may well be unique to the Wavebourn amps.
      Overall details of the amp are as follows:
      Input: 0 dB (0.775V) RCA, 50K stereo.
      Outputs: low ohm for 4-6 Ohm and high ohm, for 8-12 Ohm load.
      Power: at least 6W for <1% total harmonic distortions.
      Soft asymmetric saturation (inaudible clipping), negative output resistance for damping of woofers (servo-control of speakers).
      Bandwidth: 10 Hz-90 KHz -3 dB, from 20 Hz full power.
      Tubes:
      Raytheon VT127 (CV1127) radar sweep power tubes.
      8CB11 driver/preamp tube (twin video pentode – filament powered from rectified DC for zero audible hum.
      VR150 / Russian SG4S voltage regulator (purple glow).
      VR tube and solid state MOSFET voltage regulation.  The “Edelweiss” series derives it’s name from this. A beautiful flower which grows amongst hard mountain rocks.
      Selectable speaker damping
      In order to support different speaker design types such as open baffles, horns, closed and ported boxes, there’s a damping factor switch that controls output resistance of the amplifier.
       Position 1 is the first on the left.
      1.       High output resistance (like pentode output with no feedback), sometimes referred to as "Current driving mode".
      2.       Similar to SET with no feedback.
      3.       SET with some feedback.
      4.       Negative output resistance for active servo-damping of woofers.
      With a little experimentation I soon found that I prefer the negative output resistance setting, which is actually Anatoliy's own preference. Probably the least tube like sounding setting giving tight, accurate bass where other modes seem a bit looser. This is what I've continued to use since the first week I received the amp.
    • By vik74au
      Item: Emotiva XPA-5 Gen 1 Power Amplifier
      Price: $1,000
      Item Condition: Excellent, perfect working condition
      Reason for selling: Upgraded
      5 x 200w RMS @ 8 Ohms (all channels driven), see below photo for more specs
      Excellent working condition
      Sole owner since new
      Been nowhere near pets nor anybody smoking throughout its life.
      Although I still have the original box, it is for pick up only as this amp is very heavy.
    • By GroovyGuru
      Item:   AVM Ovation MA 8.2 Monobloc pwr amps
      Price:  $16,000
      Reason for selling:  Upgraded to valves.
      Payment Method: Pickup - Cash, Paypal, COD, Bank Cheque, electronic transfer.  If Paypal, buyer to pay all fees.
      These were Marc Rushton's power amps.  I bought them in Oct 2017.  I said I was never going to have valve power amps again but I changed my mind after I heard the AR Ref 160M which I bought.  But I would've happily stayed with the AVM MA 8.2.
      The AVM monobloc runs the AR pwr amp close.  At $16k the AVM MA 8.2 is an affordable end game power amp.  RRP was $44,000 for both ($22,000 each).  It is rated at 600 watts RMS.  It will drive anything with finesse.  It is a low noise, low distortion design.
      This is a very good price for these amps.  If you want to spend less, there is the Holton monobloc listed on this site for $15,000.
      It is Germanic black as you can see by the pictures.  It is so black even the white parts are black.
       If not pickup, buyer to arrange courier.  Gross shipping weigh each at about 45kg.  W58cm x H38cm x L57cm.  Shipped in haulage case as pictured.
