KRSDarwin
Help sought for sub-weight on Acos-Lustre GST Soundtracer Tonearm
Hi all, I recently acquired a fantastic Technics DD SL-1100AC turntable with Acos-Lustre GST Soundtracer arm in an excellent SNA transaction.  I would like to install a Jelco HS-30 headshell on my Acos-Lustre GST Soundtracer tonearm.  However at 16.7 grams the Jelco is too  heavy for the standard weight (I strongly suspected this when acquiring the TT so have my Garrott K1 installed in the existing headshell and works beautifully).  However, I believe the Acos-Lustre does have the option of a sub-weight (photos attached) and I am looking to acquire one.
I have read the Rega RB-200 sub-weight will also work but am unsure if this is correct.
The photos below with part of the tonearm and yellow vinyl is my setup and the whole of TT picture.
Any assistance or ideas most appreciated. I have posted in WTB but thought it worth sharing here, on the basis that a problem shared is a problem halved and other options and ideas may be advanced.
Just bought a Jelco HS-30, which is perfect for my setups as most work well replacing the existing 16.8 gm Ortofon headshell I have.
On the arms that needed more weight, I've successfully used blutak on the counterweight. Not very elegant looking but quite successful sonically!
Edited by Citroen
I like the Acos-Lustre GST Soundtracer tonearm and have one fitted to my Rega Planner 2.
It did come with the sub weight but I would not want to separate it ,in case I need it in the future. And I would imagine you will struggle to  obtain the two parts of the sub weight , with out purchasing the entire arm.
But to add extra weight you could get some washers from Bunning's  with a 12 mm hole. Add as many as required glue them together with supper glue and then fix them to the end of the original weight with Blue tac. This is then easily reversible.
Thanks EV Cali, I’ve purchased some bolts and washers From Bunnings but am yet to try that out as ideally I would like to preserve the aesthetics of the tonearm given the effort on the headshell.
Totally understand not wanting to separate sub-weights from operational units and the difficulty I may have in locatingthem alone. I am aiming for tonearm not functioning or left-overs from a tonearm disposed of with a TT.
I will post a pic if I go with the washer/bolt solution.
Thanks Telecine.  I believe it may be heavy enough but the diameter of the inner sleeve is not great enough.
I guess that does mean I could seek out a metal fabrication workshop to prepare one on a lathe from a billet of suitably heavy material.
Ok, so I have my first solution.  A little agricultural I admit, but it works.  Will now look for a shorter bolt.
Best sonics will be obtained by having as much weight close to the pivot as possible, so yes, a shorter bolt!
Good that you've managed to at least improvise something.
I needed an extension rod to mount an arm rest in a plinth, was able to get a Honda gearshift extension rod to do the trick.  Amazing how research and persistence can provide elegant improvised solutions.
Regarding the washer solution, you may be able to find a plastic container that has the same inner diameter as the washer's outer diameter, so you can make a nice covering for them.  Some black (or maybe silver chrome) spray paint will make it look good on the arm.  It only has to look good when viewed from the front, as you won't be looking at it from behind unless you are moving the TT.
Good luck.
Hi! Can you please tell me the size of the bolt? Is it M8?
I have the same problem - the counterweight on my Lustre Soundtracer is not heavy enough to balance my headshell/cartridge combination on its own. I tried a couple of machine screws I have lying around but none fit the sub weight thread (M7 is too small and M9 is too large, unfortunately I don't have any M8 bolts to test it).
Hi Pavel,  From memory a M8 with a special thread.  I’m not at work tomorrow but will follow up
Thanks a mil! I thought it could be something with nonstandard pitch...
Yes, you should take the main weight to a metal shop and ask them to make one with a slightly wider diameter - which will be heavier than the standard weight.  This will deliver a better solution as you won't have some weight sticking out the back of the main weight - and thus a long way from the pivot point.
Dear Pavel,
I am pretty sure the bolt is a:
M8 - 1.0p x 25 Zinc High Tensile Hex Bolt (Boltmaster code EMFH025Z)
with 2 nuts as follows:
M8 - 1.0p x 25 Zinc Class 8 Fine Hx Nut (Boltmaster code ENHIZ)
I got them from Boltmaster Cairns (ordered over the phone and by e-mail), they were very helpful.
I have been told that the thread of the tonearm is a very strange one and is a 5 / 16th , 24 TPI which approximates a BSF thread. and definitely not what you get at the local hardware store.
I am going to try and implement Andy's suggestion and will let you know if that works.
Dear Kevin, thank you very much for this information.
A quick follow up: I ordered both M8 1.0 TP and 5/16 24 TPI bolts and the latter definitely doesn't fit the counterweight stub. The M8 1.0 TP bolt fits perfectly, thank you very much!
Edited by Shovel_Knight
