2Brix
What is correct way to earth a 100V turntable when using a stepdown transformer ?
Hi folks,
I'd like to know how a 100V Japanese turntable should be earthed/grounded within a 240V system, i.e. with a system where.........
240V wall outlet powers --> stepdown transformer powers --> 100V turntable
240V wall outlet powers --> 240V phonostage
.........should the earth wire be
a) hooked up from turntable 'ground terminal' to a ground terminal on the transformer outlet side (100V side).  Note: i haven;t seen this transformer so i don;t know whether they actually have grounding terminals ??
b) hooked up from turntable ground terminal to the transformer inlet side (240V side) ?
c) hooked up from the turntable ground terminal to the phonostage
d) all of the above
Just kidding about d)......
Ed
Pretty sure I had option C in the situation you describe.
Are we talking about the earth wire from the tonearm, or the earth wire from the power supply cord, or both?
Completely different answers for each.
I have a Technics SP10 that is Japanese, so no mains earth in the power lead from the TT power supply. If your TT is not double insulated like mine you can use a 3pin mains plug and just connect earth wire to TT and earth pin in plug and plug into power point.
BE VERY CAREFUL IF YOU DO THIS NOT TO CONNECT EARTH TO EITHER ACTIVE OT NEUTRAL.
Edited by Warren Jones
If your step up tranny is 3 pin then all should be good.
If you are talking about the earth on the Tonearm cable then C is the way to go.
Thanks all for the replies.
Yes i'm asking about the earth wire on the tonearm cable.  If i have a 240V turntable and 240V phonostage i would naturally use option c)
However i was bit unsure whether #exactly the same would be correct for a 100V turntable paired with a 240V phonostage.  I'm a nervous nellie and rather like Catweazel when it comes to electrickery 😄
I'll double/triple check the earthing (grounding) arrangements when i get to see the actual turntable and transformer.
Guest Muon N'
'C'
Yep, 'c' for me.
Why do you think that mains voltage should define grounding for any device?
Even if the transformer has a 3pin plug the TT will not so the TT chassis is NOT grounded.
If the TT is not double insulated (indicated by a box in a box on the power label) the chassis must be grounded to mains ground, otherwise if you have a fault in the TT the mains breaker most likely WILL NOT TRIP, eg the active shorts to the chassis and you touch the chassis you might not get  second chance. All Japanese gear I have seen does not have an earth wire.  When I worked at Marantz they bought a heap of old Jap stock and I had to replace all the power cords with 3 wire and earth the chassis these were all amps.
For TA ground yes C
