ShrimpDuck 0 Posted January 19, 2020 Share Posted January 19, 2020 (edited) Hello! I have been having an issue with my Yamaha RX-V573 receiver for some time now. It has developed a problem of the right channel playing little to no volume when the receiver is first turned on until the volume is turned up. My receiver is set to start at -50.0dB and at this level the left channel is very noticeably louder and it sounds as if the right is dead silent. As I turn the volume up to -20.0dB I can hear the sound shift back into the centre as the right channel starts playing at a normal volume now. After I have turned the receiver up, I am able to lower the volume back down to -50.0dB where both channels play at their appropriate volumes but if the content is very quiet or nothing is playing the right channel can cut out again and I have to turn the volume back up. Now, I have done some trouble shooting myself to try and isolate the problem. I have switched the left and right speaker outputs and the problem still persists on the right output channel from the receiver so the speaker wire and the speakers aren't to blame. I am currently using optical as my source from a PC however I have used HDMI and AirPlay, all presenting the same issues. The issue is prevalent on both Zone A and Zone B of my receiver in the right channel of these. I have also blown out dust from inside the receiver with some compressed air and I desoldered and switched the relay from Zone A (RY203) with the relay from Zone B (RY202) as relays seem to be the culprit found on other posts however this did not fix the issue. The relays themselves are sealed so I am unable to clean the contacts out with de-oxit but seeing as they are completely sealed and this is a 2012 model it seems unlikely that they are to blame. As a temporary fix, I am able to plug my right speaker into the Surround Right output of the receiver and put the receiver into 7 channel stereo mode (This is the DSP mode, not true 7 channel audio). This takes a stereo source and plays the same input on the surround channels. Interestingly this channel works perfectly and suffers no volume issues even though it is just a stereo source being duplicated onto the surround channels. If anyone has any inklings or ideas about what the issue may be it would be greatly appreciated as this is a very befuddling issue! Receiver: Yamaha Rx-V573 Speakers: Wharfedale Diamond 8.3 Source: Windows PC onboard soundcard via optical Edited January 19, 2020 by ShrimpDuck Link to post Share on other sites
stereo coffee 359 Posted January 19, 2020 Share Posted January 19, 2020 10 hours ago, ShrimpDuck said: Hello! I have been having an issue with my Yamaha RX-V573 receiver for some time now. It has developed a problem of the right channel playing little to no volume when the receiver is first turned on until the volume is turned up. My receiver is set to start at -50.0dB and at this level the left channel is very noticeably louder and it sounds as if the right is dead silent. As I turn the volume up to -20.0dB I can hear the sound shift back into the centre as the right channel starts playing at a normal volume now. After I have turned the receiver up, I am able to lower the volume back down to -50.0dB where both channels play at their appropriate volumes but if the content is very quiet or nothing is playing the right channel can cut out again and I have to turn the volume back up. Now, I have done some trouble shooting myself to try and isolate the problem. I have switched the left and right speaker outputs and the problem still persists on the right output channel from the receiver so the speaker wire and the speakers aren't to blame. I am currently using optical as my source from a PC however I have used HDMI and AirPlay, all presenting the same issues. The issue is prevalent on both Zone A and Zone B of my receiver in the right channel of these. I have also blown out dust from inside the receiver with some compressed air and I desoldered and switched the relay from Zone A (RY203) with the relay from Zone B (RY202) as relays seem to be the culprit found on other posts however this did not fix the issue. The relays themselves are sealed so I am unable to clean the contacts out with de-oxit but seeing as they are completely sealed and this is a 2012 model it seems unlikely that they are to blame. As a temporary fix, I am able to plug my right speaker into the Surround Right output of the receiver and put the receiver into 7 channel stereo mode (This is the DSP mode, not true 7 channel audio). This takes a stereo source and plays the same input on the surround channels. Interestingly this channel works perfectly and suffers no volume issues even though it is just a stereo source being duplicated onto the surround channels. If anyone has any inklings or ideas about what the issue may be it would be greatly appreciated as this is a very befuddling issue! Receiver: Yamaha Rx-V573 Speakers: Wharfedale Diamond 8.3 Source: Windows PC onboard soundcard via optical It suggests a worn potentiometer that is passing audio signals reasonably on one channel but not the other. Annoyingly too at different levels of your listening. It will need replacing. A service manual is here: https://www.hifiengine.com/manual_library/yamaha/rx-v573.shtml which requires free membership of HiFi engine. A brief look shows the potentiometer to be part of a pcb assembly on page 114 of the manual. I would strongly suggest you take it to Yamaha to service, as the original part being part of a pcb looks to me only capable of being changed with another pcb. Part ZA572300- ZA573100 https://au.yamaha.com/en/support/contacts/index.html despite being a simple potentiometer Alternatively it could be desoldered and another equivalent fitted, but there is likely better result with replacing the pcb part as a complete assembly. Link to post Share on other sites
ShrimpDuck 0 Posted January 21, 2020 Author Share Posted January 21, 2020 (edited) On 20/01/2020 at 8:54 AM, stereo coffee said: It suggests a worn potentiometer that is passing audio signals reasonably on one channel but not the other. Annoyingly too at different levels of your listening. It will need replacing. A service manual is here: https://www.hifiengine.com/manual_library/yamaha/rx-v573.shtml which requires free membership of HiFi engine. A brief look shows the potentiometer to be part of a pcb assembly on page 114 of the manual. I would strongly suggest you take it to Yamaha to service, as the original part being part of a pcb looks to me only capable of being changed with another pcb. Part ZA572300- ZA573100 https://au.yamaha.com/en/support/contacts/index.html despite being a simple potentiometer Alternatively it could be desoldered and another equivalent fitted, but there is likely better result with replacing the pcb part as a complete assembly. Is a worn pot the same thing as an oxidized or dirty pot as in I just need to clean it out to restore it or are you saying it is physically worn out? If I plug headphones in the sound works perfectly and don't the speaker line outputs use the same pot as the headphones as it is a digital receiver? Edited January 21, 2020 by ShrimpDuck Link to post Share on other sites
stereo coffee 359 Posted January 21, 2020 Share Posted January 21, 2020 8 hours ago, ShrimpDuck said: Is a worn pot the same thing as an oxidized or dirty pot as in I just need to clean it out to restore it or are you saying it is physically worn out? If I plug headphones in the sound works perfectly and don't the speaker line outputs use the same pot as the headphones as it is a digital receiver? The Yamaha is an extremely complex receiver, with a service manual with 134 pages. Can you let me know if the volume control you use is a continuous rotation type- ie it has small notched increments but continuously turns, and a display then tells you the volume readout ? It looks like it uses a digital volume control rather than a conventional potentiometer. Hence you would need to look at all the audio paths and connection blocks to ascertain why you are getting the fault you presently have. The Yamaha has a volume control up and down buttons also on its remote handset does this function OK ? If so it might prove as ability to adjust volume until you can get the Yamaha service centre to look at it for you. There are usually one of two methods adjusting volume where we also see vol up vol down on a handset - it either uses a motorised potentiometer, or a digital potentiometer The speaker line outputs are at a much greater level via individual amplifiers for its many catered outputs, and do not look to be associated directly with the headphone output. if you download the service manual, you will begin to appreciate the complexity, and why booking it into the yamaha service centre is really the best destination to sort this problem out. https://www.hifiengine.com/manual_library/yamaha/rx-v573.shtml But let me know if I can help further. Link to post Share on other sites
bob_m_54 1,498 Posted January 22, 2020 Share Posted January 22, 2020 As alluded to by @stereo coffee the receiver uses a rotary encoder, instead of a potentiometer. That may be the fault, but it might also be something else. If the volume control works OK using the remote, then it is likely that the encoder is at fault. Link to post Share on other sites
bob_m_54 1,498 Posted January 22, 2020 Share Posted January 22, 2020 (edited) On 19/01/2020 at 9:40 PM, ShrimpDuck said: I have been having an issue with my Yamaha RX-V573 receiver for some time now. It has developed a problem of the right channel playing little to no volume when the receiver is first turned on until the volume is turned up. My receiver is set to start at -50.0dB and at this level the left channel is very noticeably louder and it sounds as if the right is dead silent. As I turn the volume up to -20.0dB I can hear the sound shift back into the centre as the right channel starts playing at a normal volume now. After I have turned the receiver up, I am able to lower the volume back down to -50.0dB where both channels play at their appropriate volumes but if the content is very quiet or nothing is playing the right channel can cut out again and I have to turn the volume back up. Actually, this bit would suggest it isn't the rotary encoder. At start up, both channels should be the same level, and won't change till the control microprocessor receives pulses. As yours are at different levels on start up, it is most likely something else. You could download the manual, and run the "Self-Diagnostic Mode" but it looks like a trip to the service tech anyway. Edited January 22, 2020 by bob_m_54 more info Link to post Share on other sites
ShrimpDuck 0 Posted January 23, 2020 Author Share Posted January 23, 2020 Yeah so it is a continuously rotating volume control and it all works fine, same with the remote. Had a look at all the self diagnose modes, none were out of the ordinary. I dig some more digging and both Zone A and Zone B use the same front Left and right channel amplifier when the receiver is put into that mode. When in this mode, both zone b and zone a exhibit the quiet right channel. This suggests that there is something wrong with the right channel amplification section possibly the transistor for the right channel? I could try transplanting a resistor from one of the channels that I don't use to fix the channel. Unfortunately a repair tech would be too expensive so may as well just buy a replacement receiver. Link to post Share on other sites
bob_m_54 1,498 Posted January 23, 2020 Share Posted January 23, 2020 I wouldn't go swapping parts unless you know what you're doing. It's hard to say where the problem is though, you'd have to do a bit of fault tracing with a multimeter, and ideally with a cro and sig gen. Anyway, lots of luck with it mate, I do hope you get it sorted. Link to post Share on other sites
fakejameswood 2 Posted May 20, 2020 Share Posted May 20, 2020 On 23/01/2020 at 2:20 PM, ShrimpDuck said: Yeah so it is a continuously rotating volume control and it all works fine, same with the remote. Had a look at all the self diagnose modes, none were out of the ordinary. I dig some more digging and both Zone A and Zone B use the same front Left and right channel amplifier when the receiver is put into that mode. When in this mode, both zone b and zone a exhibit the quiet right channel. This suggests that there is something wrong with the right channel amplification section possibly the transistor for the right channel? I could try transplanting a resistor from one of the channels that I don't use to fix the channel. Unfortunately a repair tech would be too expensive so may as well just buy a replacement receiver. Did you ever get to the bottom of this? I am having the same problem with a Yamaha RX-V495. It is silent until the volume is turned up, but then it works fine at lower volumes. Somewhere online, I have forgotten where, someone suggested that it might be bad coupling capacitors somewhere. Sigh. Link to post Share on other sites
fakejameswood 2 Posted May 25, 2020 Share Posted May 25, 2020 (edited) On 20/05/2020 at 9:49 PM, fakejameswood said: Did you ever get to the bottom of this? I am having the same problem with a Yamaha RX-V495. It is silent until the volume is turned up, but then it works fine at lower volumes. Somewhere online, I have forgotten where, someone suggested that it might be bad coupling capacitors somewhere. Sigh. A followup in case it's helpful to others. In my case the problem appears to have been dirty relay contacts in the speaker protection circuit. I took the relay out to measure it so that I could order a replacement, and realised the cover pops off. So I opened the relay up and gently cleaned the contacts inside with an emery board (I don't have any spray contact cleaner). This appears to have solved the problem! (The exact problem was that I was getting no speaker output until the volume was cranked up, at which point returning to low volume worked just fine. I ruled out the volume pot as the source of the issue because I could perform this volume-up-down manoeuvre from the input device (computer) OR the amp itself.) Edited June 9, 2020 by fakejameswood 2 Link to post Share on other sites
Sebastian Long 2 Posted May 31, 2020 Share Posted May 31, 2020 I know this is quite an old topic but the Speaker Hospital have great repair reviews. Check them out for future issues https://www.speakerhospital.com.au/ Link to post Share on other sites
mistamuzo 12 Posted June 6, 2020 Share Posted June 6, 2020 Interestingly I have the same problem with my Yamaha AVR (also right channel), only it crackled a bit as well and it's volume would fluctuate as the unit heated up during use. Using the Zone 2 amps set up in Bi-Amp mode worked for a while, then that started having issues too. I don't have much budget, so in the end I bought a cheaper second-hand amp from Cash Converters, set it up in Analog Direct mode and fed it with the pre-out from the Yamaha for the front left and right channels. This worked a charm. I still use the Yamaha power amps for surround & centre channels. Link to post Share on other sites
Faust 5 Posted June 9, 2020 Share Posted June 9, 2020 Seems like a common problem. So is it the terminal that gets dirty or something inside the amp? Link to post Share on other sites
Sebastian Long 2 Posted June 10, 2020 Share Posted June 10, 2020 dry joint maybe? Link to post Share on other sites
pwstereo 649 Posted June 10, 2020 Share Posted June 10, 2020 Wasn't it a dirty contact in the speaker mute relay? Link to post Share on other sites
Faust 5 Posted June 10, 2020 Share Posted June 10, 2020 Where is that? Someone should take some pics. I'm keen to open it up and clean it myself but I'll need some guidance. Link to post Share on other sites
fakejameswood 2 Posted June 10, 2020 Share Posted June 10, 2020 (edited) 10 hours ago, pwstereo said: Wasn't it a dirty contact in the speaker mute relay? That's what the problem was for me, yes. On 09/06/2020 at 10:34 PM, Faust said: Seems like a common problem. So is it the terminal that gets dirty or something inside the amp? For mine it was the contacts inside the relay that needed cleaning. It probably would have made sense to replace the whole relay but I had nothing to lose by trying to clean it, and it worked. The relays are the black boxes on the main PCB. From memory the main amp is the one closest to the front (on the RX-V495 anyway), and the areas on the PCB are labeled so it was pretty easy to find. I removed mine from the PCB, intending to replace it, then realised the plastic cover can pop off the relay. So I popped it off and sanded the contacts. Edited June 10, 2020 by fakejameswood relay cover clarity Link to post Share on other sites
Faust 5 Posted June 10, 2020 Share Posted June 10, 2020 Did anything else besides the cover have to be removed to get to it? Link to post Share on other sites
fakejameswood 2 Posted June 10, 2020 Share Posted June 10, 2020 1 minute ago, Faust said: Did anything else besides the cover have to be removed to get to it? Yes, I removed the main PCB, and to get to that I had to remove some other boards and unplug a bunch of connectors. It wasn't super-difficult, but it is a mains-powered device so there is some element of risk (both to the device and to you). I went into it knowing I might lose the whole amp, but was able to get it reassembled. You can see the relays just by removing the top of the amp, so you could always have an explore before you decide what you want to do. Also note that in my previous post I sort of implied that I could have cleaned the relay contacts without removing the relay from the board - in hindsight I think it was necessary to remove it from the board, because you need to lift the relay's cover over two tabs and I'm not sure that would be possible without access from the bottom side. Link to post Share on other sites
Faust 5 Posted June 10, 2020 Share Posted June 10, 2020 Is there a risk of electric shock even if it's unplugged? If I lose the amp then I'm in the same position as when I started so nothing really lost. Link to post Share on other sites
fakejameswood 2 Posted June 10, 2020 Share Posted June 10, 2020 13 minutes ago, Faust said: Is there a risk of electric shock even if it's unplugged? If I lose the amp then I'm in the same position as when I started so nothing really lost. I am not an expert by any means, but my understanding is that yes, the large capacitors can give you a nasty shock. I believe they're supposed to self-discharge but I'm not certain. I unplugged from the wall with the amp on, the theory being that the amp would use up the power in the capacitors. I also tried not to touch the capacitor contacts! I think this was all unnecessary but I've been zapped by capacitors before and it is Not Fun 😆 Link to post Share on other sites
ShrimpDuck 0 Posted November 9, 2020 Author Share Posted November 9, 2020 (edited) Sorry everyone I did not receive any alerts to the comments posted here. Unfortunately I did not manage to solve my issue. Fakejameswood great news that you managed to fix your issue! You said the mute relay switch was the issue for you? Attached is the diagram of my receiver, you can see the main speaker relays (RY203 etc.) but there are also the large MUTE boxes. I'm not sure if those are the mute relays you are talking about. Would you mind letting me know if it was just a regular speaker relay that you ended up cleaning in your unit? Unfortunately my relays are sealed so to clean them I would have to destroy the enclosure so I am stuck to replacing them for now. Some alternative information if it manages to narrow down is that regularly the right channel has the issue, however, when testing the unit in Zone B mode (where the Left and Right outputs are mirrored to the Surround back speaker terminals) the Surround back Right, now the Zone B right channel, has the same issue. And this occurs again when putting the unit into Bi-amp mode so that Left and Right is mirrored to Bi Amp Left and Right where Bi Amp Right has the issue. I'm not quite sure of the power train in regards to these Zone B and Bi-amp modes but it would either suggest that both the Right and Surround Back Right relays were shot or something to do with the power amplifier itself for the right channel. I don't believe the issue is before power amplification since the headphone out works fine as do the regular Surround Right when using faked 7.1 mode (playing the Front R to Surround R) Cheers guys! EDIT: I just realized, according to the diagram that the headphone power comes from the same power that goes to the Front left and Right. This would mean that the only component difference is the use of the headphone relay (HPRY) instead of the speaker relay (RY203). Going off that I assume that it is definitely down to the relay. When I have some spare time I will tear apart the unit and switch one of the working relays, such as the surround Left, with the 'broken' relay from Front Right and see if that fixes it. If my logic is correct it should. Here's hoping Edited November 9, 2020 by ShrimpDuck Link to post Share on other sites
