Peter-E
Anti Skate
2 minutes ago, Peter-E said:
This is now how it's connected but I originally connected as per the note.
This does not explain why I had channels dropout though.
Yes, using the incorrect input would either cause very low volume or distortion in both channels.  Not related to the dropout problem, unless, by moving the connectors , a dirty contact got corrected.
35 minutes ago, Peter-E said:
From my receiver manual
So you now have your TT plugged into the "phono in" RCA sockets - as the diagram shows?
The text which you highlighted in yellow refers to the situation (rare, IME) where your TT has a built-in phono stage.  In this case, you don't use your receiver's phono stage - simply a line input like for CD.
The at-lp120XUSB has a Phono Pre-amp gain 36 dB nominal, RIAA equalized.
Hence as per the highlighted NOTE I connected to the CD input.  The CD input was changed from digital to analog.
That instruction is for connecting a TT to my receiver. Pioneer SC-LX76
