Item: E.A.T. Forte Turntable
Price:
$7995 without arm
$8995 with New Zealand made Design Build Listen - The Wand Plus 12" silver carbon fibre unipivot tonearm
Contact us for a shipping quote (it ships in its original wooden crate)
Item Condition: Excellent condition
Reason for selling: No longer needed.
Payment Method: PayPal, Credit Card, Cash, Bank Transfer
A massive machine that gets the best out of your vinyl. Separate Sub Chassis and a mass loaded turntable gives us the best of both worlds.
The design of the E.A.T. Forte turntable is based on a combination of two basic principles:
Separate Sub Chassis and a mass loaded turntable This gives us the best of both worlds. The chassis of the table is very heavy and mass-loaded using metal-fi lled sand. The feet are magnetic and act as a sub chassis to support the table.
Platter
The platter consists of two parts. The first part uses a soft alloy, the second part, a harder one. This reduces energy flow. The first part also incorporates the neodymium magnets. The platter weighs more than 20 kg (44 lbs). The diameter of the platter is 400 mm (15.75 1/2) (not the usual 300 mm [11.8 1/2]). Kinetic energy stored in such big platter turning at 33 RPM is an incredible 2460 Joules! This means that with the same weight you gain more moving mass on the platter. The platter also incorporates sorbothane damping to make it resonance free.
Vinyl matt
The vinyl matt is made from recycled vinyl records crating a perfect interface for the record. A clamp holds the record on the vinyl matt.
Bearing construction
The bearing is not standard but inverted with an oversized polished shaft. A ceramic ball is used on the top because it is very hard and inert. This, in combination with a Teflon plate as a bearing mirror, is also a good damping device. Teflon's accurate satin surface produces perfectly smooth movement without any rumble. The platter has a magnetic suspension using neodymium magnets. By increasing the distance from the bearing to the cartridge, the small neodymium magnets eliminate magnetic infl uence on the cartridge. Due to the magnets we can still move a large mass allowing the bearing to see virtually no pressure. This avoids rumble. (A mass loaded platter usually causes high levels of rumble.) The pressure of the bearing is adjustable. There are existing different philosophies about bearing pressure. With the Forte turntable you can adjust it according your preferences and taste.
Magnetic Feet
The table has large magnetic feet with a bearing and stabilization system. It guaranties close to 100% isolation from the floor and from airborne resonances. The magnetic bearing system allows us to use the extra silent Tefl on-ceramic combination. Usually high pressure would cause the bearing to wear out over the time. This does not happen because of the very low pressure created by the use of the magnetic system.
Motor
The motor is a stand-alone, decoupled AC unit. It uses a sophisticated electronic circuit to create 100% clean AC. It is very heavy motor with lot of mass to reduce all the existing vibrations. Motor energy is absorbed by using a sandwich system of metal and MDF. We decided to use a "dual motor design" to eliminate noise in the motor. By using two relatively weak, but silent running motors, we achieve perfect torque.
Belt
Long belts usually have some amount of wobble. To avoid this we use a special silicon string. This movement is also absorbed by the bearing block and by the huge mass of the platter itself.
E.A.T. the Energy
The E.A.T. Forte turntable is all about eating energy.
   - Energy from the ground is decoupled by magnetic feet.
   - Energy from the air is decoupled from the heavy chassis that is made from MDF and fi lled metal sand.
   - Energy from tone arm and cartridge is absorbed by using a heavy metal tone arm base isolated by sorbothane.
   - Energy from the belt is captured by the mass of the platter and by the string itself.
   - Energy from the motor is captured by the dual-motor design, the decoupled motor unit and the mass-loaded motor chassis.
   - Energy of the bearing is catch by the ceramic ball, the Tefl on plate and the magnetic bearing construction.
Technical specifications E.A.T. Forte:
Electronic speed change * 33.33/* 45.11
Speed variance ± 0.09%
Wow and flutter ± 0.008%
Signal-to-noise ratio -73dB
Power consumption 2W
Outboard power supply 18V/1.33A AC, suitable for your country's mains supply
Dimensions (WxHxD) 700x250x440mm
Weight 65kg
Edited by HiFi Collector Adelaide
Wow beautiful.
Hi All
The only thing the same as on my EAT TT is the Record Clamp, but it is tempting 💖
JJ
Edited by Janjuc
Bloody tempting @Janjuc. And I don't have any vinyl! Or money.
Hi @deanB
I might have an EAT 'C' Sharp up for sale ?????
JJ
3 minutes ago, Janjuc said:
Hi @deanB
JJ
I'll have to redirect you to the final 3 words of my previous post. 😪
    • By pdcoo7
      Item: Popcorn Hour C200
      Price: 125
      Item Condition: used
      Reason for selling:NLR
      Payment Method: Pickup - Cash, Paypal +3% or as friend, COD Only
      Extra Info: Definitely one of the best media streamers in its day, and it's big plus is that it can stream virtually any media you can throw at it.
      Includes a 1TB Seagate HDD
    • By trystar
      Item: Primare R32 MC MM phono pre
      Price: $750
      Item Condition: Very Good.
      Reason for selling: Upgrade, I think.
      Payment Method: Pickup - Cash or PayPal
      Extra Info: This phono preamplifier needs no introduction. Excellent performance, build quality and adjustment options. Lots of info available online.
      Purchased locally and was used sparingly as part of a second system. The only cosmetic issue, if it is that, is a minor mark on the of the face plate.
      No box, so local pickup please.
    • By pdcoo7
      Item: iFi iDefender 3
      Price: 45
      Reason for selling: NLR
      Extra Info: Used this little gizmo between a small SBC streamer and USB DAC. Best part is that you can isolate power from the devices' USB power source which is what I did to get the best results.
    • By Zoet
      Item: Linn Katan Maple
      Price: $850 + postage
      Item Condition: The speakers have been well looked after so given their age 8/10
      Extra Info: I’ve got the original boxes so they will be well packed. They sound superb especially when Aktiv which I’ve been doing I’ve also got the cards for normal operation and the spanner
       See other ad for Linn MAJIK 4100 power amp
    • By pdcoo7
      Item: B&K AVP1030 Processor
      Price: $220   $150
      Extra Info: Great condition, built like a tank, but  where the AVP1030 really shines is in 2-channel playback. "Direct" mode gives the best unadulterated audio playback. So this will really appeal to someone who would like the convenience of an HT set up but really wants audio performance. Display segments are all good and all buttons both on remote and front panel are working.
      Can pack well for interested interstate buyers but preference naturally to anyone that can pick up.
