wen
STATIC PROBLEM REGA PLANAR 2
I have an old Rega Planar 2, slate with a silicone barrier added to plinth, squash balls for feet, fitted a moth oem202 arm with an ortofon quintet blue MC cartridge, has a project cork mat. I purchased and fitted a Tangospinner subplatter, never had an issue with static, but with the Tangospinner the cork mat lifted off with the record, usually change records with the platter spinning, when i went to take the cork mat off record you could hear the crackling of static, i tried a new anti-static brush, but no change. The wiring for the Moth arm has no seperate earth, so i made up a lead and connected it to my NAD PP2e earth tap and the other end left bare, spread the strands, obtained a nut to fit over the bearing housing thread under the turntable, this was a loose fit, managed to get the wire between the nut and thread, could only tighten the nut so far, no more issues with static
Edited by wen
Try this (it works for me) if you get any further issues:
On your last pass of the brush, go slowly out to in, trailing off over the centre pin.
Edited by furtherpale
