Ethernet switches for audio - Part B: why a regular switch will suffice.
10 hours ago, dbastin said:
As those Ubiquiti switches need 24v DC input, here's an option for LPS ...
https://www.sbooster.com/botw-pp-eco-24v/
The US‑8‑150W model doesn't, it's IEC C-13 so built in power supply. I haven't looked at any of the other models with more ports than this so not sure if they do too.
My modem benefited quite a bit from LPS and Akiko tuning stick (plugged into a usb port).
I don't see how it would, but okay.
  • Replies 256
Popular Posts
Firstly, a preamble.  My system is definitely serious.  It is now significantly reliant on Ethernet for connectivity for the 2 X NASs, Roon Core, DSP Box and a network player before anything reaches t
I’m just baffled at how many people really don’t get that a switch is typically sending audio to a device with a significant buffer for playback. The traffic traversing the switch is not “real time” a
I don't think they have the right knowledge in what they are trying to apply to because anybody who knows how network and switching works will know that no matter how fancy the ethernet cable is, it w
Any suggestions how to ground them? There's the Synergistic Research grounding cables
As for vacant ethernet ports, read this  ... http://www.acoustic-revive.com/english/pcaudio/lan_terminator.html
Your first comment is wrong. It’s a 240V AC switch with an IEC plug in the back. They can serve 24V DC out a port for PoE purposes.
your product link reads as gibberish. Vibrations from networking equipment? That product is nothing but what we in the industry call a “solution in search of a problem”.
this thread is about will a regular switch will suffice and why. If you want to start playing with nonsense products like this, post it in one of the other Ethernet related threads you’ve made.
Umm, correct, sorry, I was partly wrong.  Most Ubiquiti switches with 8 or less ports need 24vDC input, the rest have inbuilt power supplies.  I was looking at switches that provide the option to use a different/linear psu.
Are the switches with inbuilt psu's better in any way?
I think its relevant to cover enhancements to regular switches in this thread.  My openning post did state ...
" ... discuss pro/cons of upgraded power supplies, power cables, grounding, etc".
As I"ve said in Part A ... This stuff sometimes makes no sense but does improve sound quality ... and that's all I need to understand.
So, approach with an open mind and spirit of experiment and adventure to hear what there is to be discovered.
On 06/01/2020 at 2:05 PM, rmpfyf said:
An 'audiophile' switch is at best a band aid.
Firstly, a preamble.  My system is definitely serious.  It is now significantly reliant on Ethernet for connectivity for the 2 X NASs, Roon Core, DSP Box and a network player before anything reaches the DAC.  All are connected with a mix of Audioquest Diamond Cat 7 and or some CAT 8 cables.  As well there are two optical converters in the mix plus 3 Acoustic Revive filters.  As a next step I have become interested in whether a network switch would be a benefit.  There are many things that I do not understand about this topic.
Today I had the opportunity to try both the two levels of Paul Pang switches.  First the less expensive 8 port D link based switch with TCXO and a serious additional power supply.  A very very impressive benefit.  Far exceeded my expectations.  Then it was the turn of the 16 port OCXO dual switch.  No power supply need as it was IEC in.  It was just gobbing smacking absolutely bloody amazing.  I was stunned.  How come?  The owner of the switches was even surprised.  His take on the switches was that with Tidal there may be benefit but not what we experienced this afternoon.  I do not use Tidal as everything for me comes off the NASs.
Up until this stage the Optical converters were not being used.  We put them in.  Another step up.  Noticeably more so than my system with out either of the two switches.  I do not know the whys or wherefores but for me these two audio switches were a total surprise.  The one thing we did not try was using the two switches in tandem which is supposed to be even better than just one on its own.
I now know three things.
Audio quality Ethernet switches do provide a benefit and it was significantly serious for my system.
I don’t just want one I need one!
There are a number of different makes and models out there and I have to make choice.  It will be interesting
John
Edited by Assisi
word
  • Like 6
I should have said in the post above that I am now listening to my system with just my low level Netgear Switch.  I am sure that most people would say you do not need anything more.  as the owner of the two switches said this is a great system.   I know what I heard this afternoon and I will not stop until I have it again.  It will be like a big itch that needs to be scratched.
John
Great news, thanks for sharing. Sorry to hear you now have a serious itch for a serious switch.
I think the 2nd switch you tried is in fact the dual switch approach, in one box.
In case you havent seen this, go here.  If I missed a switch in the list, let me know.
From what I've read, the upgraded SOtM is hard to beat, except if you connect 2 with optical link. But of  course M12s are better for higher price.
Edited by dbastin
@Assisi
I have no doubt what you're hearing is legitimate. None whatsoever. I run some Ethernet conditioning myself, and for the tweakers out there I have some nice good Rakon 25MHz OXCOs that could work a treat for many switches.
All I'm suggesting is to consider what they're actually doing and whether there are more direct means.
Lower noise - conducted from source and EMI - and better packet timing. That's it. If I've missed any other mechanisms of operation it'd be a great discussion point.
The noise bit - nothing is going to beat optical. Ever. Physically not possible. There may be bits to optimise at the device ends (what it plugs into) and some people just can't do it as they've devices that simply won't accommodate it. But I can't in good conscience spend megadollars on Ethernet cabling when a solution exists for this. It's a super bandaid. Most of us use CAT8 and other STP forms poorly for this.
The timing part sure, I get it. It's the same fundamental mechanism that drives audiophile software builds - jitter. Others eg @recur suggest industrial grade switches with separate PHY per port and dedicated ASICs are the way. They are not wrong - similar principles are used on audiophile USB transports, and on the etherREGEN. You could crack one open and go for better clocks or linear supplies I guess, but the Paul Pang method - putting the same on consumer grade hardware - whilst directionally correct is simply akin to putting lipstick on a pig. Not bad but there's better.
The etherREGEN is designed so as not to be perfect but to reflect the usual compromises associated with a home system. I'd go optical into it simply as to resist any temptation to spend silly money in that cable, and then as short a run as possible into whatever streams. A quarter metre, literally.
If you're going into a customisable PC it's optical all the way! But most of us... Aren't.
I take it you dropped speed to 100Mbps for your tests?
I’m just baffled at how many people really don’t get that a switch is typically sending audio to a device with a significant buffer for playback. The traffic traversing the switch is not “real time” and as a result, anything these audiophile switches are doing, it’s not on the data stream.
There are error correction capabilities in everything from the Ethernet frame up through the transmission layer (tcp/IP) and often at the application layer. If there was anything amiss in any of these communications, you’d be able to see it in a simple promiscuous port capture using open source software like wireshark.
if audio was being streamed and real time performance was needed (in the rare and extreme case that there were no buffers on the streaming devices), you wouldn’t use tcp to transmit it, you’d be using udp (much like we do when transmitting telephone calls over IP).
Networks were built to reliably send data from one point to another. I’ve yet to see anything in the audio world that hasn’t already been solved to send real time video, telephony or super low latency transactions (go read Flash Boys by Michael Lewis to get an appreciation of the speed and $ involved) without impact.
Worrying about what’s happening on a hardware switch within 2 feet of your streamer, with a very low amount of local network traffic is definitely NOT where I’d start or even end my audio optimisation journey.
I’ve worked in networking and security for well over 20 years and the common refrain for poor application performance is “it’s the network”.
The most complicated part of any application is the actual application. Networks are often set and forget and run for years without tinkering.
These manufacturers are making Ethernet the boogey man as so few lay people have a good, solid understanding of networking. Reading the data sheets of these new audio optimised switching devices is hysterical.
I’m semi tempted to get some white box Broadcom switches and pump them out to this audience. At least my switches will be fast, ultra low latency, highly configurable and the data sheet would reflect some semblance of reality.
  • Like 5
I'll reiterate - it's not the quality of data. Data gets there just fine. It's jitter. Of all measurements possible, OS jitter is prolly the best (albeit indirect) measure of any possible differences. The buffer really doesn't matter to these ends. When I reassemble my rig it'd be interesting to compile a kernel with appropriate tracers and run a few experiments to these ends.
The simple measure of proof is to pull the Ethernet cable and listen for a difference. If there's going to be any effect whatsoever it should be audible under this condition. Now... there's a range of possibilities and configurations therein. A lot of people won't be able to pull the cable because their streamers will stop streaming... etc etc.
Unfortunately there's a ton of snake oil out there from various audiophile vendors to the wrong ends. Wireworld makes a nice cable but (a) their suggestion that data integrity is somehow at stake is BS and (b) it shouldn't take a special cable. Just... no. Ethernet over optical has existed for eons for long distance work and even short runs (in very high EMI industrial environments) just for this purpose. It's engineered, it works. Again, we get into the possibilities and configurations - people with $10k servers running copper cabling only are going to have issues.
It'd be a welcome addition to any experiment to these ends - I'd run it.
Whilst I agree with you 100%, you're wasting your breath here.
  • Haha 1
46 minutes ago, PositivelyMusicallyGeared said:
So few even within the IT industry, to be honest.
im only quoting the last comment here but im am referring all previous. disclosure: i sell these switches and in particular Paul Pang manufactured in Taiwan. And of course there are many other brands.  i stand by my products. i do not sell anything that i dont believe is a good product. i do not sell anything that i dont believe is good value for money. these are modified for audio switches not IT INDUSTRY switches. i am not qualified in any IT or engineering area. i am qualified in audio. that is my business, without giving a technical explanation i can categorically state that these switches do improve audio. you can quote all sorts of reasons why they would or would not work but at the end of the day its what comes out of your audio system that is the proof in the pudding. the 2 switches i put into @assi 's system are: 1/ Paul Pang D-link TCXO based switch and 2/ the Paul Pang OCXO based dual switch. The technical specs along with photos are available on Paul's website. Yes optical is the way to go and this will take over from the current ethernet network set up eventually however we are not there yet in the audio world unless you are prepared to spend big. i am willing to demo these switches anywhere in melbourne and you are welcome to come to me for a demo as well. @assi is a serious audio lover and the quality of his system shows that. the comments he makes in reference to his experience with yesterdays demo are exactly as he described. my philosophy is the basis for a good digital rig is good power and good ethernet. both of which i can easily demonstrate.
It's crazy that we have intelligent people on this thread hellbent on making it a 100% one-way-or-the-other argument.
There are so many things that change system-to-system.
correct impact varies hugely on system to system ...... what i say is that audio grade switches should have more of an impact on an internet network than just a local one however i was quite surprised at how well the switches worked on @Assisi's local network.....as was he. and again i am willing to demonstrate these switches anywhere in melbourne and i will leave the decision to your ears ......should it be no impact positive impact or negative impact. its just my opinion that they absolutely make a difference.....
Conversely it's crazy that we have intelligent people on any thread here hellbent on believing that everything makes a difference.
  • Like 3
I admit, I was getting fed up with it, and started reading a certain other, more measurement oriented forum, but, not being content, some of the above mentioned have migrated there as well.  So annoying :)
I can understand how some people could feel aggrieved that people selling these items have no idea how they actually work and where they might be applicable therein. I'm not suggesting this is you, though there are some disingenuous types pushing all manner of snakeoil as though simply more=better. That's a BS argument to part people from their hard earned.
I'm not comfortable with the notion that they 'absolutely' make a difference. In a suitably designed system they should make zero difference. It's possible to engineer accordingly.
The test is simple - if you can pull the cable and hear a difference, dig deeper. If you can't, whatever Ethernet could do is being dealt with - spend no more.
Meanwhile at the other end of the argument...
Con, you have an extremely expensive DAC very specifically engineered to deal with these sorts of issues. If I'd paid what you paid for yours and a $4 Ethernet cable way upstream made a snot of difference, I'd be an extremely aggrieved customer. This said the market for people with your DAC is small.
A bit like the market for people with a relevant understanding how buffers, interrupts and timing circuits actually work and can interact pending any number of configurations being small - the market for people being able to point out these components and say 'a ha! A buffer! Everything else is bullshit and none of you know what you're talking about, you're all stupid!' is considerably larger.
But if you want to believe that your experiences are absolute, or that an Ethernet NIC having a buffer (or a USB receiver or whatever) kills any possibility of anything upstream doing anything downstream re timing, go for it.
I'm just not sure (aside from the usuals hi-fiving each other on likes) that what everyone loves on a discussion forum is having discussion replaced with their being told they're idiots.
No-one likes that.   I have discovered that someone thinking a particular product works, and spending their hard-earned on it, is NOT what actually is annoying to me.   What IS irksome is some of those people posing as experts, and arguing and evangelising on forums.  It also makes me very wary, when I am seeking advice in areas where I have no expertise of my own.
i didnt say i have no idea how they work....i do....however what i did say is listen before you make a call... like it or not leave it to your ears. again i stand by my products and if you listen to them and dont like them then so be it....
I heard the audophile ethernet switch in a system where the ethernet cable went straight into the speakers themselves and were actively amplified in a system that cost much less than mine and should have been the most prone to the effect of network based noise possible, AND had had rave reviews about the improvements that it caused. The owner of the system graciously allowed me to audition his system with and without the switch and I heard no difference in any configuration which means it can only be one or two of the following:
1. I'm too deaf to hear the difference - which is possible given my right ear impairment.
2. The owner suffered from positive expectation bias.
3. I suffered from negative expectation bias.
Given that was in a system that had a mechanism for possibly benefiting from isolation, it rips my heart out to see people obsessing about changes that cannot benefit from isolation, and fussing over a myriad of other ethernet things that can't possibly affect sound, but then this is for the same market that is... well whatever, I've started ranting now so I'll butt out again.
OK then - purely to foster a discussion here - how do you think they work?
There is nothing intrinsic about the combination  you mention that suggests it's 'most prone' to network-based noise.
All three outcomes are possible.
Audible differences are possible. Whether so in a given scenario... TBD.
I'd be interested to try this, maybe not necessarily broadcom, we were discussing Ubiquiti earlier, and there's others.
How about choose a switch with a SFP port and DC input, configure it the best possible, and worh out the cost including expert time..
We could use this thread to reach consensus about the selection of a switch and configuration settings etc, tapping into the experience of SNA members.
Then actually try it ... rather than talk/debate about it.
We'd need to choose a total cost too. It may be a gamble - audiophile switches may perform better at similar cost.
I'd suggest aim for a total cost under AU$600, bearing in mind the cost 'audiophile' switches.
Who's in?
Edited by dbastin
typo
theres a fourth option IT ACTUALLY MADE NO DIFFERENCE...and im not yelling lol.....i dont know your system but if you are using tidal and roon and are willing to hear my switches i will endorse your opinion provided we have consensus on the day and an independent uninterested/unbiased listener should be present.
Number 2 implies that. I'm sorry for not explicitly saying so.
7 hours ago, rmpfyf said:
@Assisi
There have been many posts on this forum and others that deny the benefit of Audio quality switches etc.  For some time now I have not posted on Stereonet about things that I have tried and the results.  Too often the responses were, that is just opinion, where are the measurements or you are just biased.  I posted previously purely so that people could aware of my experience which to me is as valid any other.  I posted yesterday about the switches purely because the experience was just palpable.  If I go down the path of getting a serious switch based on yesterday experience, I predict that it will be the best cost Vs performance outcome for my system that I have ever done.  My DAC which is a Weiss Medus, is in the serious league, as is the rest of my system.
I do wonder how many who post rely on either theory or their particular technical networking expertise without having tried quality audio switches?  It seems to me posters with the technical knowledge or networking experience seem to be focussed on the why it can’t be so.  Maybe the focus could be more towards if it is so why.  Just have a look at the Roon forum and the thread.
Do router and ethernet cables affect sound quality?”
https://community.roonlabs.com/t/do-router-and-ethernet-cables-affect-sound-quality/92544/15
I have read many of the posts about networking on forums, understood some but as a consequence of the reading I had a reasonable degree of scepticism as to what to expect with the two switches trialled yesterday.  I said in my previous post I know virtually nothing about the technical aspects of switches etc.  I had to find out what an OCXO and TCXO.  I think I mixed up which Paul Pang switch has to which clock has what  in my previous post.
I do not know what:
"...separate PHY per port and dedicated ASICs are the way." means.
I just try things and listen and form my own position on what I hear.
I am certain that anybody on Stereonet who listened to my system would be impressed.  Three people have recently heard my system and each was very positive about the result that I have achieved.  I am sure that the switches did not fix any discernible inherent problem in my system.  The switches somehow provided a serious but totally unexpected benefit.
     You asked the question "I take it you dropped speed to 100Mbps for your tests?"
No.  Why
John
@dbastin,
I am very aware of your list and thank you for preparing it.  I have read many of the links that are on the list and more.  The matter of an audio quality switch for me is work in progress.  The SoTM interests me because of the AudioBacon review and it has 2 optical ports whereas the Paul Pang do not
John
19 minutes ago, Dacman said:
great so how can you comment on the impact of a switch on tidal?
Do we have to go down that rabbit hole again? Some of us are scientists, engineers, software engineers... and know how this stuff works. I also was open enough to auditioning it on a system that had it in spite of myself.
Edited by Ittaku
48 minutes ago, dbastin said:
I'd suggest aim for a total cost under AU$600, besring in mind the cost 'audiophile' switches.
Bespoke engineering and that these are enterprise-grade hardware might not make for that limit :)
wow very impressive scientists engineers software engineers....great.... please read my other posts in this thread and attend the actual demo, back to @Assisi 's comment on his observations....are they not valid? and btw your qualifications still do not qualify you to comment on the impact of an audio ethernet switch on tidal. lets see scientists, they conduct actual tests dont they? if you dont like rabbit holes dont comment
Like I said, let's not go there. Feel free to wander off in whatever direction you want. In the audiophile world science and facts take a back seat at all times and you're not allowed to argue them so I won't bother since auditioning is king (which as I said earlier, I did in spite of myself.)
I do not know what:
No.  Why
John
John,
IMHO at what the Medus costs it'd be fair to expect a better effort in clocking signals.
I'd drop the speed because your effective jitter should fall usefully, which can be audible.
Thanks for your observations and experiences.
I set this thread up for these debates to occur.  In hindsight I should have included in my opening thread ...
Please share you suggestions for optimising regular switches for audio, and experiences with their sound quality, ideally in comparison to switches on the list in Part A.
I am hopeful this thread can generate some solid recomnendations for those not interesred in the switches listed in Part A.  Such as, good switches, configurations, tweaks, etc.
Maybe the thread should be called ... how a regular switch will suffice.
But how do they work?
Do we really need to understand how they work? To mimic?
All I need to understand is If I hear a benefit.
56 minutes ago, Dacman said:
the components are upgraded and they have good quality clocks installed....as opposed to standard switches
What's upgraded, exactly? Clocks are a jitter argument. How far do you recommend people install them from their transport?
Mimic, no. Some of us can't spend so easily in lieu of understanding is all. Not a critique of others.
"lets not go there"  'feel free to wander off in whatever direction" very scientific lol why are you even commenting if you cant use one of these switches in your system?
1 hour ago, rmpfyf said:
John,
I have no idea as to the degree of clocking level that the Medus achieves.  All I know is that the outcome from the DAC is wonderful.  For me it is about everything that is on my local network  before any signal reaches the DAC.
How do I reduce the network speed?  I am sure that it may be simple matter for you Ric but not so for me.  There are 5 devices networked plus a Netgear switch and the optical couplers that do have dip switches for speed.
John
John
Depends what you've got :)
What's the last switch before the DAC? You may be able to login and set a maximum speed on a given port. Shoot over a make/model and let's dig into a manual together.
So you could be comparing:
- Netgear (base)
- EtherRegen
- Paul Pang x 2
- EX/CX internal switches.
Sounds fun, I wish I wasn't so far away.  Any chance one of you can try to get a Melco S100 to try too?
Given the switches being compared, maybe report your findings in Part A.
