Arry74
Speaker phase problem
Hi
I have a problem that I am not sure I can fix.
I have in-ceiling speakers that are very difficult to get to.
When I had them connected initially, the company that installed them used speaker wire where the negative and positive wires look exactly the same as the outer sheath is the same.
I recently purchased a new receiver and when I disconnected it I dropped the cables accidentally and now I do not know which is positive and which is negative.
The grills on the speakers do not come off so I cannot see which way the cones are moving.
I have watched YouTube videos on it but no one explains if / how you can check phase if you cannot see the speaker end of the connections.
Any help would be greatly appreciated.
There are some apps for mobile phone/iPad/etc. that test speaker polarity.  Download, connect phone to amp, place phone mic near speaker and read + or -.  You'll need to use a left or right speaker output from your amp.  Mark cables and done.
Or you plug them in have a listen if they sound hollow crappy then reverse them you won't kill anything with a short test.
A while back I actually ran one of my speakers out of phase for a few weeks without realising, it survived.
speakers don't care if they're connected "out of phase" - there's zero risk of damage...
@Buffle's idea could work - I've never used apps like that...
Can you get up on a ladder and shine a torch through the grille and see the driver? having the the room reasonably dark would help.
If so get a friend to connect a battery (like a D cell or a 9V smoke alarm battery - not a car battery) to the terminals at the receiver end, and try to identify which way the driver moves.
You want the driver moving forwards with the +ve lead connected to the +ve end of the battery.
Don't leave the battery connected - have your friend connect and disconnect the battery while you adjust the torch to get a good angle to see driver movement...the driver will move forwards or backwards and stop each time the battery is connected, and go back to neutral when disconnected.
If you can't see driver movement with a D cell (1.5V) try a 9V (ie smoke alarm) battery.
Mark the leads at the receiver end...
just checking - sometimes there's a "tactile" ridge you can feel on the wire that's not obvious on a visual inspection...?
...given you didn't install the speakers I'd still go through the process to confirm polarity.
Mike
Forget all the fancy stuff.😀
Sit where the sound is best. Play.
Reverse one speaker's connection. Play
The connection that gives the best bass and musicality is (almost inevitably) 'in phase'. If you can't tell--don't worry, no damage will occur; and if you can't tell--it doesn't matter.
Relax and enjoy.
The other approach that may work, if you can't tell with your ears, is to use a Sound Pressure Level meter app for your phone.  Set speakers up to reasonable volume (75db or so) on a piece of music you can repeat, ideally with a bit of bass and without changing volume try the leads each way around.  In phase should be slightly louder.  Should turn amp off between the two wiring scenarios, just don't adjust the volume.  Haven't tried it exactly as above - but regularly do similar to ensure sub-woofers are in phase with main speakers using a test tone.
Edited by gibbo9000
most room correction software will also tell you if a speaker is out of phase
This.
Simpy run the run the calibration routine in your AVR with it's microphone, and all will be well.
46 minutes ago, Arry74 said:
Will Anthem ARC find the problem?
Hmmm... Thinking about this some, I don't know.
You can try it....  it can't hurt, worst case it "it won't fix it".
One way to determine if you have the ceiling speakers in phase with one another, is to find a mode in your receiver which sends "stereo to all speakers".    Then, disconnect all dpeakers ecept the ceiling ones.... and play music.   Flip the phase of the speaker you're unsure about, and the difference should be obvious as you change it back and forth.    One will be dramatically better.
On 21/12/2019 at 11:17 AM, Arry74 said:
Hi
Use a AA battery to test it use your wire touch both end battery see which way it works. Speaker will make some sound for you to test.
Tried that but how do you tell in phase or not?
  • Connect a 9 Volt battery to the leads of the speaker, positive lead to positive battery end and negative lead to negative battery end.
    If a pulse is generated in the speaker then the speaker is still functioning properly.
my understanding is that if the positive/negative is wrong then the speaker won’t make sound when testing by battery.
16 minutes ago, TDX said:
  • my understanding is that if the positive/negative is wrong then the speaker won’t make sound when testing by battery.
Not correct, there can be a sound (or not) both ways
Apps are dodgy and will give variable results
seeing the movement or listening and picking the better/louder are the simplest ways as mentioned previously
When I do this I get sound both ways.
Forgive me if I have missed something here.  I would have thought applying a DC voltage (AA battery) will drive a once off change in speaker cone position and unlikely to make any ongoing noise.  What you are looking for as suggested earlier in thread is the direction the cone moves.  If you have the correct +ve and -ve for the wiring then the once off movement will be in the same direction for both cones (out of in)
    • By ChrisMS
      Item: Sonus Faber Piccolo Solo Centre Channel Speaker
      Price: $300
      Item Condition: Excellent
      Reason for selling: Simplified audio system, no longer required
      Extra Info: Finished in black leather, hand made in Italy. Owned from new since 2001 with sparing use.
      Pickup from Northcote, VIC
    • By anthony vinyl
      Item: bruce edgar horn bass speaker cabinet with altec 511 and 909 16A compression driver
      Price: 1900
      Item Condition:  very good
      Reason for selling: nlr
      Payment Method: Pickup - Cash, Paypal +3%, COD Only
      Extra Info: full horn system. very rare bruce edgar designed horn as detailed in sound practices magazine.  bruce Edgar was super famous horn designer - an aeronautical engineer who i think designed the tractix horns.  very open and spacious bass that gives a life like presentation - sound very wide and deep . "you are there" sound - musicians are in the room with you.
      HF driver is altec 909 16 which has adjustable attenuation .flare is Altec 511 as used in altec A7 VOTT . bass cab is 1080H X 800W X 600D. the cabinets are in very good condition overall except for chip as shown and some minor blemishes. very solid and very heavy - excellent workmanship and build quality . HF driver and surround 300H X 600W X500D . for the article please read http://volvotreter.de/downloads/Edgar-Show-Horn.pdf or simply type in bruce Edgar show horn into your search engine. This is a small outlay for a lot of speaker
      Photos: Advertisements without photos of the actual item will not be approved.
    • By SBM
      Hello everyone,
      Good day can any one recommend a good budget power conditioner.
      Thank you.
    • By Bugs
      Item: Electro Voice Sub Woofer
      Price: $250
      Item Condition: Good
      Reason for selling: NLR
      Payment Method: Pickup - Cash COD
      Extra Info: Owned this unit for a few years now, Had the driver re-coned professionally, and the cabinet was made to EV specs by a local Cabinet Maker. It has a Plate Amp fitted, 400 Watts from memory, although I had a bridged Yamaha Power Amp, 1100 watts prior to that. The driver is a proper PA unit which cost over a grand back in the day. If you want to rattle the windows, this is the one. 600x600x1000, weight? HEAVY. Can demo, Due to size and weight, pickup only.
    • By CMAN
      Item: Mirage MX 5.1 Home Theater Speaker System with Mirage MM-6 Powered Subwoofer (includes five palm-size speakers, a compact subwoofer cube and a step down transformer)
      Price: $400
      Item Condition: Used, in great working condition with no known faults. Fully operational and functions as intended. Good cosmetic condition. No cracks or holes. Barely any scratches/marks.
      Reason for selling: To upgrade
      Extra Info: Purchased brand new from a high end stereo retailer
      Product Descriptions & Specs: https://www.crutchfield.com/S-mvKwTyd9Z7d/p_653MX51B/Mirage-MX-5-1.html
