Cono28
SOLD: FS: Pro-ject Tube Box DS2
Item: Pro-Ject Tube Box DS2 Tube Phono
Price: $480
Item Condition: Excellent , less than 50 hrs used
Reason for selling: NLR
Payment Method: Pickup - Cash, Paypal, Bank Transfer,Can be post at buyer expense.
This precision tube phono preamplifier benefits from outstanding circuit technology from Dr. Sykora and uses high-quality components. Compatible with both MM and MC cartridges. It offers connection for two turntables plus two selectable line outputs and a continuously variable selection of input impedance for low output MC cartridges while playing a record! Other features include input capacitance for MM cartridges and switchable subsonic, that prevents your amplifier and speakers of ultra low rumble below 20Hz. All components including tube output and polypropylene capacitors are audiophile-grade and guarantee a breathtaking sound experience. A perfect upgrade for ambitious vinyl lovers!
Next In line if falls through
JJ
Thanks everyone, this item sold.
    • By Believe1980s
      Item:  Pro-Ject Tube Box S Phono Preamplifier Sliver And Black Finish - Vinyl Pre-Amp
      Price: $280
      Item Condition: Mint / 99% New
      Reason for selling: upgraded
      Payment Method: Pickup - Cash, COD
      Pro-Ject Tube Box S Phono Preamplifier Sliver And Black Finish - Vinyl Pre-Amp.
      Only open for test! Under warranty.
      The sonic quality of the Tube Box S is extremely impressive; a big improvement from the Phono Box S, and an audiophile upgrade for most analogue hi-fi systems. With a wide range of settings parameters, it can meet the needs of almost any phono cartridge on the market. Carefully selected audiophile-grade components make it possible to enjoy your valuable vinyl collection like never before!
      The class-leading music reproduction of the Tube Box S gives pure dynamics, full transparency, analogue warmth, bass texture, detail resolution and purity for all audible frequencies.
        Features
      • Audiophile Performance
      • Audiophile-grade ECC83 (12AX7)
      • Dual mono configuration
      • Audiophile-grade polypropylene WIMA capacitors
      • Precise RIAA equalisation
      • Switchable input impedance/capacitance
      • 3 adjustable gain levels
      • Subsonic filter
      • Outstanding sound quality
      Technical Specifications
      Input impedance 10/100/1k/2k ohms(MC)/ 47k ohms (MM)
      Input capacitance 50/150/270/370pF
      Gain switch 41/51/61dB
      Signal-to-noise ratio MM (41 dB): 84dB (94dB – IEC -A)
      MC (51/61 dB): 67dB (75dB - IEC -A)
      THD 0.01% MM/ 0.05% MC
      RIAA deviance max. 0,4dB / 20Hz - 20kHz
      Subsonic filter -12dB @ 20Hz (non switchable)
      In/Out sockets 1 pair RCA connectors
      Power consumption 470mA / < 1 watt in standby
      Oversized power supply 18Volt DC/1000mA
      Dimensions (WxHxD) 103 x 74 x 104 mm
      103 x 74 x 115 mm (with sockets)
      Weight 810g net
    • By Believe1980s
      Item: Pro-Ject Debut III Piano Black Ortofon 2M Red including Ortofon stylus Gauge
      Price:  $199 reduced from $200 for Quick Sale
      Item Condition: turntable: wear and tear; Paint looks new; Stylus: 2M Red 6 months old
      Original power supply
      cable is refurbished when serviced 12 months ago, fully working, no damage. You can DIY to higher quality cable.
    • By bennyc
      Item: FS: Pro-Ject Carbon debut turntable (om10) and Cambridge Audio 651p  with TeraDak Linear power supply 12vac
      Location: Kensington Sydney or Campbelltown or can drop off to nearby area.
      Price: Turntable only ($250), Cambridge Audio 651p ($120), TeraDak LPS ($120)  SOLD or whole set ($450  $360)
      Item Condition: Good and working condition with original boxes
      Payment Method: Cash, Paypal, EFT
      Extra Info: less than 10hrs cartridge use as I was using another cartridge after second week. Some scratches on the phono amp as seen on photos
    • By pimpsqueak
      Item: Pro-ject DAC Box FL
      Price:  $80+postage
      Item Condition: 9.5/10
      Reason for selling: Upgraded to DAC with dual optical inputs
      Extra Info: Simple, small form factor DAC. The “FL” means filterless.  “The basic idea is to avoid all digital filtering, which is generally thought imperative to avoid aliasing distortion at ultrasonic frequencies, and instead use multi-bit conversion at the native data rate (no up-or oversampling).”
      The only reason I upgraded was for the extra inputs. Otherwise I have been really happy with this unit.
      Comes with Eversure power supply.  No original box, but I can securely box it for postage.
    • By spin vinyl
      Looking at downsizing almost all my equipment collection, as I currently now only use the items marked * due to space restrictions imposed on me.
      A lot of these have been in storage for many years.  I am thinking of listing various items in the next few weeks.
      Thoughts on what I should keep (as a single system for myself) and what to sell (ie likely to be in demand out there)?
      AMPLIFIERS
      ME850 (later) * ME25 (MM) * ME850 (early) ME25 (MC) ME240 (this has had about 5hrs use since last serviced by Trevor some years ago) ME RIAA Phono box (ditto re service) Luxman L510 (a real beauty - even just to look at) Luxman L235 Pioneer SX950 Receiver
      PHONO
      Garrard 301 * Pro-ject "Perspective" 6.9 Luxman PD264 Rega P2 (Wood) B+O 4002 B+O 1500 B+O 1202 Garrard 620S Rotel RP1500
      REEL+TAPE
      Akai GX646 4 track (reel to reel) Nakamichi ZX7 Nakamichi 680 Nakamichi BX-2 (Black) Nakamichi BX-2 (Silver) Marantz DD-82 (DCC) - rare Marantz SD-57 Luxman K-5A Luxman K-210 NAD 6000-Mk2 Rotel RD-620 Sony ES333
      CD
      Arcam CD-72 * Luxman D-321 Harmon Kardon HD7400 Marantz CD-41 Luxman D103u (Valve hybrid)
      SPEAKERS
      Wharfedale "Harewood" * Mission 730 Floor standing Celestion 2 way Floor standing Sansui 3 way floor standing Mordaunt Short Bookshelf
