Naim man
Musical Fidelity XLPS MM/MC Phono stage
Item: Musical Fidelity XLPS Phono stage mm/mc
Price: $295 incl postage
Item Condition:excellent
Reason for selling:NLR
Payment Method: Pickup - Cash, Paypal, Bank transfer
Extra Info:excellent vintage phono stage, mm/mc, sounds wonderful. POSTAGE INCLUDED
Photos: AdvertisementsA7E8CC43-355A-46F7-9A92-A5DB6A2D107B.thumb.jpeg.acbe9509aa95ba4d8a9d5efedea2e47b.jpeg59C8E4A8-44C0-4E63-907B-81B9EF0D08B1.thumb.jpeg.34de3d80160399717f17a1dd67e5df84.jpegA65A7B19-F51A-48C0-BF07-6F403D3B357F.thumb.jpeg.1a85135d93d311b60651a5b581336d3c.jpeg9EF54D1F-F724-4979-A74D-0D5EAA7ADA6D.thumb.jpeg.481a56a6ed6abc83c1b0efe223919dfc.jpeg06904487-96F1-493B-98DF-D7E84EB4AD21.thumb.jpeg.a3194e8eff49de20f4a2c26e8496cc6a.jpegAE6EC383-DA86-44F6-B6DF-52CCB001AD85.thumb.jpeg.d208a159c750aa1760f3b912277ab24e.jpeg without photos of the actual item will not be approved.
    • By rangie
      Item: Astell & Kern SP1000 Cooper
      Price: $2,100
      Item Condition: Used. Very good condition.
      Reason for selling: Slowly getting out of head-fi and re-focusing on stereo hifi.
      Payment Method: Pickup - Cash, Paypal, bank transfer.
      For sale is a Astell & Kern SP1000 Cooper.
      Excellent condition. Works well with no issue at all.
      Comes with original box/packaging, original accessories and spare screen protectors etc.
      Purchased in September 2019, still under warranty.
      Include two (2) x leather cases - one original case and one Dignis Artisan case worth $250, the Dignis case provides better protection to the corner.
      A clear protective film (that comes with the Dignis case) was applied to the top and corners of the body.
      Can post anywhere at cost. Pickup is welcome too.
      Donation will be made to SNA if sold to a member here.
      Please feel free to contact me if interested. Thanks!
    • By timelord9
      Item: Vincent Audio SV237. Black.
      Price: 1300 dollarydoos.
      Item Condition: Excellent
      Reason for selling: Raising capital for domestic transducer development.
      Extra Info: Purchased 2nd hand last year, this amp has seen very little use. I have the original box, but its super heavy and (at this stage) would prefer not to post. The amp is in perfect working order and buyers can demo with my Focals. Pick up from Thornbury or Abbotsford.
      Specs:
      Frequency Response: 20 Hz - 20 kHz +/- 0.5 dB, 20 Hz - 50 kHz +/-2 dB Nominal Output Power RMS / 8 Ohm: 2 x 150 Watt Nominal Output Power RMS / 4 Ohm: 2 x 250 Watt Nominal Output Power Class A / 8 Ohm: 2 x 10 Watt Harmonic Distortion: < 0.1 % (1 kHz, 1 Watt) Input Sensitivity: 300 mV Signal-Noise Ratio: > 90 dB Input Impedance: 47 kOhm Inputs: 4 x Stereo RCA, 1 USB Outputs: 1 x Stereo RCA Pre Out, 1 x Stereo RCA Rec Out, 4 x 2 Speaker Terminal, 2 x 3.5 mm Jack (Power Control) Tubes: 1 x 12AX7; 2 x 6N1P-EV Colour: Black  Weight: 20.4 kg Dimensions (WxHxD): 430 x 152 x 435 mm
      Comes with remote.
      Note: This is the original SV237. The link below is with the updated digital input.
      https://www.vincent-tac.de/en/product-lines/tubeline/sv-237mk.html
    • By anthony vinyl
      Item: Micro Seiki BL 91 turntable with SME 309 tonearm
      Price: 3400
      Item Condition: very good
      Reason for selling: a very reluctant sale but want funds for another project  .
      Payment Method: cash ,  PayPal +% , transfer
      Extra Info: a very special combo. the SME 309 should need no introduction - see online reviews. superb in styling and a breeze to use.   the micro seiki is simply a beautiful turntable both in form and function.  from vinyl engine specs site it
      "Features a massive, thick, 12.2 inch platter, employing special alloy bearings machined and polished with techniques usually reserved for turbojet engines.
      Micro Seiki engineers devised an exclusive oil-bath damping system to support the entire rotating assembly in complete isolation from all mechanical resonances.
      A precision-ground drive belt connects the rotating assembly to the brushless, servo-controlled motor with total isolation from motor generated vibration.
      In fact, the BL-91 (L) is probably the smoothest, most vibration-free device of its kind ever built. the plinth is multi-laminar natural wood finished with hand rubbed natural ebony... 16 kg"
      all original handbooks for SME and micro seiki. . please note the benz cart is NOT included in sale price .  please also see blemish on tonearm where it sits in holder ( common )and blemish on plinth. also the wire connectors on the tonearm head shell to cartridge have shabby insulation that is unnoticeable from above and does not affect performance. would prefer a pickup but will consider postage. preference for pickup.  will consider seperating - although the unit is functionally and aesthetically outstanding as it is. .
    • By SoundGuy
      Price: $12,000 $10,500 $9300
      Main Features
      Gain 26.8dB
      Power Consumption 300W
      Width 17.75" (45.1cm)
      Depth 19.83" (50.4cm)
    • By zenikoy
      I'm back in Perth for 2 weeks from this weekend, so thought I would relist this in case anyone is interested now. Local pick-up only as time is short and I wont have time to do it properly.
      Item: Technics SL1200 Mk1 Turntable
      Price: $390
      Item Condition: Very Good. Awesome condition for around 45 years old. Totally functional.
      Reason for selling: I have another 3 turntables and this has been out of use for a while.
      Payment Method: Definitely Perth Pickup only - Cash
      Extra Info: Overall excellent condition, Original smoked cover in very good condition except for repair at rear hinge.
