Mat-with-one-t
Phono stage options for dual arm setups
Hi all.  I’m on a slow journey towards a dual arm turntable setup.  It’s slow as I am just collecting parts as I go, as they come up on the market at good prices.  It all adds up quick, what with a 9” and a 12” arm, carts for each, plinth, turntable, etc.  ouch.
The table is a Garrard 401 in a plinth for 2 arms with changeable armboards.
Arm 1: Ortofon 9” TA-110.  Likely running LOMC stereo carts.
Arm 2: Audio Creative 12” Groovemaster 2. Likely running SPU’s, hopefully including a mono cart
In my mind there’re a few options for the Phono Stage.
1. Use a different stage for each arm.
- advantage perhaps using stages better “tuned” to each arm setup
- disadvantage perhaps cost, cabling, space....
- having to switch, or worse, to plug/unplug all the time
2. Use a stage that can cope with everything
- advantage is neat and simpler.
- disadvantage maybe trying the “one size fits all” approach.  Also few options out there, and all really expensive (such as the Luxman EQ-500, at 3x the value of my Subaru)
My inclination for the SPU arm is perhaps tubes.  I’m also happy to build a kit.  I would’ve loved one of Duc’s stages for example.  I currently have a Black Cube SE on my VPI Classic which does a great job.
I’ll be eventually building a custom cabinet for the table and the rest of my kit, so I can allocate space.
Interested in hearing how people have approached the dual-arm or multiple table approach!
Mat
I use a DIY hybrid tube phono, with a mc and a mm stage. Have MM cart on the 9" and MC on the 12". So each can be set up correctly for cart and its simply by flicking a switch to one to the other.
Not sure if he still sells kits.
https://tavishdesign.com/
Sure there will be others out there that allow for a simple flick of a switch.
The musical fidelity M6 and nuvista phono stages have three inputs, which can be configured independently,  and range from moderately to very expensive. I have not heard anything bad about them, but to be fair I have struggled to find anything much about them at all on the internet. Someone called out for SNA experiences with them a while back without any response. I would like the nuvista phono to match my integrated, but at $7000, it is a bit more than what I can afford!
I would like a double arm table, but have had to compromise with an arm with interchangeable headshells/carts. First world problems, as they say.
12 hours ago, Douglas HiFi said:
The Gold Note PH10 sounds great and has reviewed very, very well.
https://www.goldnote.it/phono-stages/ph-10/
Adding the optional PS10 power supply raise it up a notch or two.
I believe there will soon be an optional tube output stage add on as well.
Cheers Douglas 😏.  I’ve come across that one in the past.  I’ll do some reading.....looks promising, esp if they come up with a tube output stage....
Thanks mate.  I recall Tavish as an option, but they always seem “sold out” or “new version coming”.....I wonder if they’re still going?  I recall good reviews.  I’ll contact them....
Did you receive an answer? Would be interested if he is still making them.
On 08/12/2019 at 5:20 PM, Mat-with-one-t said:
Anyone know of all-Tube units that can cope with all this?
Yes - Aesthetix Rhea. Sounds great but you need very low noise tubes in the first two positions so 4 low noise in total.
Any globes in mind?
56 minutes ago, Mat-with-one-t said:
Any globes in mind?
Jim McShane will hand select Sovtek 12ax7lps if you tell him they are for a Rhea
To be clear he hand selects them after testing them one at a time for noise
Yep they are.  They no longer do kits though.....
Exactly what I’m after, but maybe with one digit too many on the price!!  Bugger.....
Yeah geez.  All units with a great feature set start hitting that $7k mark.  May be cheaper to have 2 stages...!
What is your budget?
Not exactly sure as yet,ate, but certainly not $7k.  My missus would put an adjustable load on my own cantilever.....
