Audio Connection
EAR 834P Phono Stage
Item: EAR 834P MM/MC Tube Phono Stage
Price: $1,000.00
Item Condition: Used
Payment Method: Pickup - Cash, Credit Card, Direct Deposit
The EAR 834P Deluxe tube phono stage is a classic! There is something truly magical when records are played back through tubes and the 834p Deluxe is one of the most enchanting we've heard.  Of course, the 834p Deluxe has the entrancing midrange you'd expect from a tube phono stage, but world-renowned audio designer Tim de Paravicini has designed the 834p Deluxe with incredible extension at both frequency extremes. Taut powerful bass, extended airy highs, the 834p Deluxe does it all at a very fair price!
The 834p Deluxe is Moving Magnet/Moving Coil selectable, with 70dB of gain in the MC setting making it compatible with virtually every MC cartridge on the market. There is nothing as affordable and versatile in a tube phono stage that comes close to the listening pleasure you will receive from this world-class design! The 834p Deluxe is a Music Direct best seller!
The 834p Deluxe uses three 12AX7 tubes to achieve its great sound; these long lasting tubes are easily accessible, allowing more ambitious users to experiment with a wide variety of tubes. With a detachable cord, chassis mount jacks and exceptional build quality, the 834p Deluxe should be on every audiophile's short list of high-performance phono stages.
    • By Mr_Gadget
      Item: Titan AV Modern Bookshelf Speaker Stands 870mm Dual Leg
      Price: $90
      Item Condition: New (never used but with cosmetic blemish from factory as shown in photo)
      Reason for selling: not needed
      Extra Info: These stands were purchased earlier this year with the intention to use them as surround speaker stands, I ended up wall mounting the speakers so did not use them. They have a cosmetic blemish on the top plate from factory but will not be seen once a speaker is placed on top.
      Specs:
      • 2 x 870mm Dual Leg Bookshelf speaker stands • Height: 870mm • Top plate 200mm x 250mm x 6mm • Base plate 250mm x 300mm x 8mm  • Main material: Glass & Aluminium • Colour: Gloss black • Max weight load: 10kg per stand • Tempered glass base plate with floor spikes for added stability • Cable management included for a clean and organized appearance • Aluminium supporting poles • Weight: 9kg • Instructions included
      Photos: Advertisements without photos of the actual item will not be approved.
    • By D’accordo
      Item: Dynaudio Confidence C2 Platinum
      Price: 9500  (RRP22K)
      Item Condition: Pristine, hardly used 18months Old
      Reason for selling: selling for Friend
      Extra Info: My friend has upgraded C4 and asked me to sell this for him as he is not familiar with selling on SNA. These big boys was in his Theatre roon. It is now in my place for sale. Audition and inspection is welcome if agree on the price.
      He purchased this around 18months ago in CAV Melbourne. This Excellent condition Speakers will come with original box, cataloge and tools and receipt if required.
      The Confidence C2 serves up seamless balance, effortless control and the kind of sound that will keep you glued to your seat
      The slimline C2 Platinum adapts our reflection-conquering DDC tech to a more compact floorstanding design. The drivers comprise two 17cm mid/bass drivers, matched to twin 28mm Esotar2 tweeters – all designed to deliver seamless integration, unparalleled staging and a real sense of Being There.
      Like the C4 Platinum, the C2 features adjustable spikes hidden in the base for fine-tuning their position in your room, while concealed speaker-cable connectors in the back keep everything neat. After all, your eyes should be on the speakers – not the wiring.
      What’s Dynaudio Directivity Control?
      Much like motor-racing technology ends up in your family car, we’ve taken the expertise we’ve gained from decades of building professional monitors for major recording studios and applied it to home audio.
      It’s all about compensating for floors and ceilings – which reflect the sound coming from your loudspeakers and introduce distortions and time delays. It’s those effects that colour the sound you hear – and while a splash of colour is lovely on the wall, you don’t want it in your music.
      We utilised Dynaudio Directivity Control (DDC) in the Confidence Platinum C4 and C2 to minimise those unwanted distortions. The vertical symmetrical driver array and sophisticated crossover are designed to reduce the energy dispersed to floors and ceilings by up to 75%. That means more of it comes directly to you in your seat, and makes the speakers far less dependent on the room they’re in.
      It isn’t just a driver arrangement, though: every part of the signal chain is optimised for the technology. Each tweeter complements each woofer in frequency response and phase relationship. Each crossover component is precisely selected for the job. And on the floorstanding speakers in the Confidence Platinum range, we make sure each set of drivers and crossover parts is precisely matched to the other – so they work in tandem.
      Specification :
        Sensitivity: 87dB (2,83V / 1m) IEC Power Handling: 300W Impedance: 4 Ohms Frequency Response (± 3 dB): 28Hz – 25kHz Box Principle: Bass Reflex Rear Ported Crossover: 2 (3) way Crossover frequency: 2200, (8000)Hz Crossover Topology: 1st order   Woofer: 2 x 17cm MSP Tweeter: 2 x 28mm Esotar² Weight: 40kg / 88lb Dimensions (W x H x D): 238 x 1532 x 445mm   9.4 x 60.3 x 17.5in Dimensions with feet/grill (W x H x D): 420 x 1532 x 475mm   16.5 x 60.3 x 18.7in
    • By kelossus
      Item: As above
      Price:  $150
      Item Condition: As below
      Reason for selling:
      https://www.discogs.com/Dave-Kelly-Dave-Kelly/master/581625
      Only got two releases on Vinyl and both the UK and Aussie pressing are highly sort after. This copy is absolutely mint, not a single mark on the record. It looks brand new and un-played. I am asking $150 which is far less than what a copy in this nick sells for.
    • By Diynamic
      Item: Sennheiser HD 25 II
      Price: 150
      Item Condition: As new
      Reason for selling Too many
       Have had these for a few years as spares , only comes with a pouch . Never , only taken out of packing. These headphones are serious quality for the price range all parts are replaceable, I’ve known a few people who have had the same pair for 20 years and still going strong  Been in production since the 1970s .......Simlpe , classic old school cans 🙂
    • By mexicoke68
      Item: Intercity HD-1L Headphone Amplifier Limited Edition
      Price: 550 o.n.o
      Reason for selling: Moving to speakers
      Crystal clear sounding amp with an impressive spec sheet. Has an accurate, reference grade sound signature, which reminds me of the sound from high end Yamaha amps.
      Made by a boutique manufacturer in Tokyo only for the Japanese market. These are selling on eBay for ~$1000 in used condition.
      Specs: https://web.archive.org/web/20070705193913/http://www.intercity.co.jp/productinfo/hd-1l/hd-1l.html
      Measurements: https://web.archive.org/web/20120716131939/http://www.intercity.co.jp/productinfo/hd-1l/measurement/hd-1l_result.html
