HiFi Collector Adelaide
Astell & Kern AK100 32 Gb portable system
Item:  Astell & Kern AK100 32 Gb portable system
Price: $490
Item Condition: excellent
The Astell&Kern AK100 is the ultimate portable high-fidelity audio system capable of studio Mastering Quality Sound (MQS) support and playback. MQS (24bit, 96kHz -192kHz) is considered as the digital music format with the most amount of information and commonly saved as a lossless 24bit WAV/FLAC format. The difference between MQS and MP3s/CDs (WAV) can be heard and felt because the sound is distortion free because no data loss occurs within the MQS (24bit) source. The Astell&Kern AK100 does not need external MQS encoding and results in a more refined and pure sound.
Features:
Bit-to-bit Mastering Quality Sound (MQS) playback
World's first portable device equipped with the Wolfson WM8740 24bit/192kHz DAC
Dual MicroSD card slots with 32GB of internal flash memory - 96GB of music storage space
Use the Astell&Kern AK100 with or as an external optical DAC
Refined design w/ integrated volume wheel & brushed aluminum body
Intuitive user interface experience with touchscreen LCD & control buttons
Technical Specs
Dimensions: 2.32” x 3.11” x 0.55” (in)
Weight: 4.3oz
DAC: Wolfson WM8740 (24bit/192kHz)
Display: 2.4" IPS Touch Screen (320 x 240)
Memory: 32GB Internal / Dual Micro SD card slots (32 GB each)
Audio Formats: WAV/FLAC/MP3/OGG/WMV/APE/AAC/AIFF/ALAC
Bluetooth: 3.0/A2DP
Output Level: 1.5 VRMS
THD+N: < 0.0008%/1kHz ; < 0.001%/10Hz ~ 20kHz
Signal to Noise: 110 dB
Frequency Response: ± 0.14 dB/10Hz ~ 20kHz
Jitter: 90 PS
Edited by HiFi Collector Adelaide
    • By Fuba
      Item Condition: Used and full working order Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Sydney State: New South Wales Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Not being used 3 meters pair terminated with Burri Bus banana.
      https://www.audiotrends.com.au/van-den-hul-berri-8-8-banana.html#panel
      The BERRI BUS is van den Hul's top of the range termination system for loudspeaker cables. It's colourful, built like a tank and offers the most secure and best sounding connection available.
      The van den Hul D-352 Speaker Cable is everything we've come to expect from this cable maker - fatigue free, a big bold spacious presentation with the finese that good audio equipment deserves. A cable that manages to combine the qualities of copper, silver and carbon into a truly great sounding, yet affordable package.
      Overview
      The D-352 is the next step up from the popular CS-122 and sounds even better. More substantial in every way, the D-352 digs a little deeper, has a slightly more gutsy bass, a larger scale & soundstage presentation and is a touch richer in balance. The best thing about the entire Van Den Hul range is the total lack of fatigue when listening for long periods. Many cable brands tend to shout at you to get the message across but Van Den Hul cables are faithfully transparent to the sound of the music and always leave you feeling relaxed after a listening session.
      Each lead is made of 296 x 0.15 mm and includes Matched Crystal (MC) high purity Oxygen Free Copper strands with a dense and very pure silver coating. Covering the two conductors is an extra layer saturated with Linear Structured Carbon that has been applied to improve the sonic performance and to transform the radiated magnetic field into an audio signal again. Of course, the cable jacket is made from van den Hul's own HULLIFLEX 3, a very flexible and mechanically superb insulation material. The resistance per lead is an impresive 0.34 Ohm/100 meter. Total metal cross-section area for each conductor is 5.23 mm², equalling AWG 10 which is very thick and definitely at a level where substantial terminations will be required. Another thing in common to some other van den Hul speaker cables is the outer construction. The plus and minus leads are different in jacket-shape with printing in the flat middle section. Both properties are easy polarity-finders.
    • By Fuba
      Item Condition: As New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Sydney State: New South Wales Payment Method: Paypal, EFT, Cash on Pickup etc Reason for selling: Not being used Van Den Hul The Mainsstream BS Hybrid IEC Power Cable
      2 Meters and terminated with Oyaide Australian plug (3 pins) and IEC socket.
      The MAINSSTREAM BS HYBRID has been specially designed bearing uncompromised mains power distribution to high-end audio, video and professional equipment in mind and is able to deliver a virtually unlimited stream of low noise mains power.
      Van Den Hul's 12.5mm special quality heavy power cable The MAINSSTREAM BS HYBRID is the smaller diameter version of their 15mm The MAINSSTREAM HYBRID. Despite its smaller diameter, The MAINSSTREAM BS HYBRID features all essential qualities as found in its bigger sister; All conductors are of the same heavy gauge as in The MAINSSTREAM HYBRID. The MAINSSTREAM BS HYBRID is likewise equipped with a heavy braided screen. Omission of the extra mechanically protective sub-jacket beneath the screen makes this cable thinner.
      Features:
      A unique embedded power-line noise suppression filter. A very high continuous current capacity and a maximum transparency with regards to instantaneously drawn current surges. Strong shielding against in and outwards radiation of electromagnetic and radio frequency interference. Heavy conductors and shield of the high quality also found in Van Den Hul's loudspeaker cables. Extreme ruggedness and therefore a very long lifespan
    • By Fuba
      Item Condition: As New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Sydney State: New South Wales Payment Method: Paypal, EFT, Cash on Pickup etc Reason for selling: Not being used Van den Hul The Magnum Hybrid  Terminated Speaker Cable (2 Meter Pair) Terminated with Van Den Hul Spades
      The Magnum Hybrid is the next step up from the popular D-352 and sounds even better. More substantial in every way, the Magnum digs a little deeper, has a slightly more gutsy bass, a larger scale & soundstage presentation and is a touch richer in balance. The best thing about the entire Van Den Hul range is the total lack of fatigue when listening for long periods. Many cable brands tend to shout at you to get the message across but Van Den Hul cables are faithfully transparent to the sound of the music and always leave you feeling relaxed after a listening session.
      Each lead is made of 483 x 0.15 mm and Matched Crystal (MC) high purity Oxygen Free Copper strands with a dense and very pure silver coating. Covering the two conductors is an extra layer saturated with Linear Structured Carbon that is applied to improve the sonic performance and to transform the radiated magnetic field into an audio signal again. The cable jacket is made from van den Hul's HULLIFLEX 5, a very flexible and mechanically superb insulation material. The resistance per lead is: 0.21 Ohm/100 meter. Total metal cross-section area for each conductor is 8.54 mm², equalling AWG 8 which is very thick and definitely at a level where substantial terminations will be required. Another thing in common to some other van den Hul speaker cables is the outer construction. The plus and minus leads are different in jacket-shape with printing in the flat middle section. Both properties are easy polarity-finders. .
    • By Jeddie
      Item Condition: Used Shipping Options: Pickup available and you can audition. Suburb or Town: 2198 State: New South Wales Payment Method: Cash, EFT Reason for selling: NLR Further information:
      Have had this solid wood chest of drawers for a while, but we don't have a need for it.  My wife restored it to its present state with a few expected imperfections (see photos)
      Dimensions;  895mm w x 435mm d x 790mm h
    • By scribble
      Item Condition: Excellent Shipping Options: Shipping is available at agreed cost. Suburb or Town: Adelaide State: South Australia Payment Method: PayPal Reason for selling: NLR Further information:
      Hi I’m Selling a Devialet 200 Amplifier Streamer/ DAC/ PhonoStage. In Excellent condition.
      * ( The amplifier is an original 200 Master Unit , not an upgraded version !! ).
      * l can negotiate price if the offer is reasonable.
      *This amp does not disappoint and has an Excellent Streamer/Dac and PhonoStage.
      Complete with remote and all original factory packaging. So interstate courier delivery welcome.
      Photos
      PLEASE READ
