hammer193
McDonalds vs Michelin star
So, my main ‘A’ system consists of an LP12 lingo 4, project tube box ds2 pre, bryston b100 amp & castle avon 5’s. I love the sound and 99% of the time it is perfect for my tastes. Occasionally i play my ‘C’ system in our library room which is a crappy old tape player, sansui 7500 amp, jbl sub and Kef c55 spks in the bookshelves almost facing eachother ( I know ) but in that booky carpeted room it sounds like honey sunset in brown 70’s shagpile carpet dripping warmth down the walls and its great.
1% of the time it’d be good to get a similar sound from system ‘A’. Is there anyway i can ‘saboutage ‘ the clarity of that system for the rare times i’d like to or am i asking to fix a tow bar to a porsche ?
Just play Isaac Hayes.....
You haven't really given us enough specific info to make more than very general suggestions of what you might do to your 'A' system, @hammer193:(
However, I would say:
  1. bryston amps are not known for their 'warmness'.  :)
  2. what cart do you have on your LP12?
the Bryston is just what i want 99% of the time & the tube box takes away a bit of brightness. The cart is an Adikt.
I suppose the tube box pre is the most expendable as it is the cheapest component so are there any pre amps available where there is a simple switch to go from high res / accurate to low res / warmth/ muffled ?? I bought system ‘A’ after extensive auditioning so as i mentioned, 99% of the time it is just what i want, just wish there was someway to change it up in the rare instances i’d like it to sound differently.
Get a decent phono pre (no opamp $50 boxes) and use tubes so they add something  to the music rather than taking something away from the music.
I see you're in Adelaide - see if you can persuade Ben ('Tait0') to bring his Muse phono stage over, so you can listen to it in your system with the Adikt MM.
If you want more bass in system 'A' (you said your 'C' system has a sub) ... then buy a sub.  Adding a sub - OME - will 'warm' up your bass and mid range ... as well as giving you the lower octave.
If you want more warmth - with the Bryston - then about the only thing you can do is change the phono stage.
Build a Nelson Pass H2 and put it in front of your amp. I introduces 2nd harmonics and gives a "tube" sound.
I have built one but have not tried it yes as my main amp has the 2nd harmonics already.
yeah i forgot to mention a Rel T9i is my sub for ‘A’ system.
Are you playing cassettes or tape in your C system?
Also--have you tried the Sansui in the A system (seriously)?
yes, system ‘C’ is tape only.
and yes I have run system ‘A’ with the Sansui and for that 1% of the time it would be great but not all the time.
The other issue with the Sansui it is only rated & 25 W which is not enough to power the speakers.
sorry casette tape, not reel to reel.
I'll put on my tin hat and suggest a Graphic Equaliser....
yeah Bob, could be the easiest answer. Definitely food for thought.
Guest Muon N'
Very in vogue these days :)
nm
Edited by rantan
Guest Muon N'
9 minutes ago, rantan said:
Just like DBTs.
Whatever you do, don't look at your gear and don't trust what you hear:frantics:
Best time to don one :ph34r:
On 03/12/2019 at 11:06 AM, hammer193 said:
<snip>Is there anyway i can ‘saboutage ‘ the clarity of that system for the rare times i’d like to or am i asking to fix a tow bar to a porsche ?
Porsche tow bar--no problem.🤣
As for changing the 'A' system; why bother? Just change rooms.😃
If you want to degrade the sound of your "A" system, why not put a crappy cassette deck in so you can listen to cassettes in that room.  Or add a second entry-level turntable (eg a Crossley)?
How about trying different tubes on your phono pre?
A set of Brimar tubes will give you that warm fuzzy sound you are looking for.
The rest of the time you can use your existing tubes.
