robio_d
FS or Trade: Custom Lampizator Amber 2 R2R & Volume Control - Price Drop
Item:  Custom Lampizator Amber 2 R2R & Volume Control
Price: $4800AUD - Won't go any lower.
Item Condition: Mint/Near New
Reason for selling: Change of direction
Pretty much NIB Custom Lampizator Amber 2. This is no ordinary Amber 2 though, with the same R2R DAC board from the Atlantic, 44khz Super Clock, 5v 5Y3 Rectifier, the Baltic Analog output section with 6N6P tubes, remote volume control with analog in and dual parallel analog outputs, rca spdif, toslink, BNC and USB - The works! I was informed by the NZ dealer that the final tuning was done by Lukasz himself.
I had this delivered in Feb 2019, with big plans for an entire new system based around the Lampizator, but life circumstances changed and I have downsized my system significantly. It had approx 1 months use and has been boxed since then. I was hoping to put it back in the system, but time to let it go to a home where it will see the use it deserves.
This is a very flexible and amazing sounding DAC/Pre that can be the control centre of your entire system. The lampizator sound is in full effect: detailed, musical, smooth, big and what I can only describe as expensive sounding. I have fully tested prior to listing and everything is 100%.
The Lampizator is an absolutely mint condition with both Factory warranty stickers intact, which means there is over 4 years to go on the Lampizator transferable warranty.
The Power supply is switchable between 230v and 115V so good for the most of the world.
If you are in the market for a new Lampizator Amber, get this instead and grab $2400nzd of upgrades for free for less than the price of the current Amber. I'll even throw in an extra set of 6N6P and an extra 5Y3.
Shipping to Aus would be approx $250 AUD.  I'll go halves on PayPal fees.
Will consider trade/exchange for a banging set of higher power Tube Mono Blocks - for those that would love the DAC but don't have $5k sat around BUT (like most of us) have a bunch of extra gear collecting dust ;)  If you have something post in the comments and I'll check em out.  Looking for 60W plus.  Not looking to spend extra so must be lower, on or marginally over the price.  So no $15k amps unless your willing to drop a $hit ton and give me a nice xmas pressie!
hi
wold you have any photos with the top of by anychance?
10 minutes ago, Island boy said:
hi
Hi not possible sorry, the factory warranty stickers would come off. You can ask lampizator permission to open to change tubes etc, but in its current state there can be no argument that it hasn’t been tampered.
9 minutes ago, robio_d said:
That’s fair enough!
10 minutes ago, robio_d said:
    • By Minimalfi
      Item: Pioneer N-50A-K Black DAC/Network Streamer includes original box, manual, drivers (CD) and remote control
      Price: $350
      Item Condition: Second hand but much loved, I would consider this perfect condition for a second hand item
      Reason for selling: I bought this unit as a DAC upgrade to my CD transport I was especially interested in it's high quality power transformer and twin ESS ES9011S SABRE32 Ultra DAC, sadly it has become redundant after I switched to a Chord Chordette HD and Innuos Zen Mini setup
      Component style network audio player that can also act as a high quality digital to analogue converter. USB, Optical, Optical and Coaxial.
      Interesting ancillary feature is that it can convert USB to Optical or Coax out
      In lossless (up to 192kHz);
      WAV AIFF FLAC Apple Lossless (only 96kHz for this one) Plus Direct Stream Digital in both 2.8MHz and 5.6MHz varieties (aka DSD64 and DSD128)
      The core of the unit is a pair of ESS ES9011S SABRE32 Ultra DAC chips, one for each channel.
      The unit offers a ‘Direct’ mode, plus things like 32-bit and 192kHz upsampling for standard resolution material
    • By Signatune
      Item: CHORD Hugo TT (DAC / Pre Amp/ Headphone Amp)
      Price: $2250 $2650
      Item Condition: Excellent  (2 tiny scratches on back corner that are hard to find, as pictured)
      Reason for selling: No Longer Required
      Payment Method: Pickup or ship - Cash, Paypal, COD , Bank Transfer.
      Shipping: I have a shipping box that is the correct size for it with soft foam inserts so it will travel safely & can be shipped at buyers expense.
      Extra Info:  I purchased this from a SNA member around 2 years ago & since then it has been driving various headphones & used as a DAC / Preamp with a Mcintosh Mc275 tube amp.
      I have personally found that the Hugo TT Dac/preamp has the ability to make even the most harsh recordings sound smooth & nice.
      Comes with remote, wall charger, and USB stick with drivers  for windows.
      Specs;
      Materials: Clamshell precision machined aluminium casing with steel ball bearing buttons, gloss black acrylic signal window, glass viewing portal, and dot matrix display. natural silver colour.
      Battery: 4x Rechargeable custom Enix Energies 3.7v 9.6Wh Li-ion (lithium-ion (2600mAh) batteries*
      Tap length filter: 26,368 – 4 element Pulse Array design
      Super capacitor energy storage: 10,000,000μF
      Play time: In excess of fourteen (14) hours
      Charging: Nominal four (8) hours via included 9v 1a charger
      Connectivity (input): USB Type-B (White): 44.1kHz – 384kHz – 16bit – 32bit
      Coax (BNC) (Red): 44.1kHz – 384kHz – 16bit – 32bit
      Optical (Green): 44.1kHz – 192kHz – 16bit – 24bit
      Connectivity (input wireless): Bluetooth (Apt X) (Blue): 44.1kHz – 48kHz – 16bit
      Connectivity (output): 2x ¼” jack headphone output
      1x 3.5mm jack headphone output
      1x stereo (L & R) unbalanced RCA output
      1x stereo (L & R) unbalanced XLR output
      PCM support: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 358.8kHz, and 384kHz.
      DSD support: DSD transmitted via DoP. DSD64 (Single) to DSD256 (Quad-DSD)
      Volume control: Digital, activated in 1dB increments.
      Line-level mode: Activated via dual press of Input and Crossfeed upon startup
      Driver support: Driverless with Mac OS X and Linux, driver required for Windows OS
      Reviews;
      https://chordelectronics.co.uk/product/hugo-tt/
      https://www.whathifi.com/chord/hugo-tt/review
      https://www.trustedreviews.com/reviews/chord-hugo-tt-ttoby
      https://www.head-fi.org/showcase/chord-hugo-tt.20578/
      http://www.6moons.com/audioreviews2/chord/1.html
      Feel free to ask any questions.
    • By DigitalDave
      Item: PS Audio PerfectWave DAC (upgraded to MK II)
      Price: $2,100 ono (i'll include shipping Aust wide)
      Reason for selling: recently bought a new DAC,  this is now surplus to requirements
      Payment Method: Pickup - Cash, Paypal (buyer to pay fees), bank transfer
      Extra Info: I've had this since new circa 2012 and upgraded to MK II shortly afterwards.
      I recently had the pleasure to compare it with some current high end DAC's such as the Naim NDX 2, PS Audio Directstream, and Auralic Vega G2 on loan for home demo's. Whilst in the end I went for something new and different, it was in small degrees that the PWD II was bested as is the law of diminishing returns in this hobby of ours. At the end of the day the PWD is a really good DAC that is transparent, dynamic, musical and listening to music from it as the source is pretty bloody awesome.
      Other than being a really good DAC in its own right, the cool thing is that down the track you can upgrade to Directstream DAC, and also upgrade the Bridge to the mk II if you have Roon.
      Original double boxing and remote (mk II remote) included. I cant find OEM power cable so I'm including a 1.5m Grave Science power cable which is an upgrade in itself at no extra cost.
      From the Darko review of the MK II some years ago;
      https://darko.audio/2012/10/ps-audio-perfectwave-dac-mkii-review-part-2/
      "Think of the MKI as a flat white or a cappuccino. Then picture a long black (Americano). That’s the MKII. It’s tastier and brings more zing. More kick too. Without the milk and froth, you’re closer to the bean, closer to the music. The MKI presentation is a shade more congealed that its successor. The NativeX-ing MKII is more proficient at clearing clean spaces between stage players without a thinning of acoustic mass.
      The PerfectWave MKII isn’t the best DAC in the world either. To say so is dumb hyperbole. Running up a Tom Evans amplifier and Avant Garde Trio hill against a dCS Puccini + uClock saw the dCS ascend with more graceful ease – the PS Audio unit was contrasted as a meal with beautifully presented tonal flavours but tainted by too much pepper and spice. There’s nothing out of the ordinary there. At AU$29k, one would expect the dCS to best the considerably cheaper PS Audio box. That the latter got so close with listener satisfaction and detail trawl is commendable."
    • By CMAN
      Item: Rega DAC-R Digital Analogue Converter
      Price: $700
      Item Condition: Used, in excellent condition
      Reason for selling: To upgrade
      Extra Info: Purchased brand new from Life Style Store in September 2015
      Current RRP: $1299 on https://www.stereophonic.com.au/rega-dac-r-digital-to-analogue-converter/
      As per official Rega website: http://www.rega.co.uk/dac-r-1.html
      What Hi-Fi review: https://www.whathifi.com/rega/dac-r/review
    • By Arv
      Item: Primare DAC 30 in Black
      Price: $750 Price Drop - $725
      Item Condition: Used, Excellent Condition
      Reason for selling: Upgrade/ NLR
      Payment Method: Pickup - Cash, Paypal As Friend (or + %Fees), COD Only
      I am the 2nd owner of this DAC and had purchased this DAC from a fellow SNA member @chick3nrice start of this year to replace my previous DAC (Audiolab M-DAC). Refer to previous FS listing:
      The DAC had performed well in my system and I felt it was a step-up in comparison to the M-DAC... especially in terms of better resolution and detail. Also see previous FS listing for chick3nrice's impressions of the DAC.
      The DAC is in excellent used condition as can be seen in the pictures. Included is the remote, powercable, manual and have the original factory packaging and box. Able to ship interstate at buyers expense and risk; rest assured it will be well packed.
      Few reviews online as well:
      http://www.hifiplus.com/articles/primare-dac30-digital-to-analogue-converter/?page=3
      http://www.the-ear.net/review-hardware/primare-dac-30-digital-analogue-converter
      https://www.stereolifemagazine.com/reviews/item/964-primare-dac30
