Hytram
Dirac: XMC-1 vs Nad T758 vs Nad C658 vs.......
this is kinda a 2ch problem with 5.1 gear, never mix the 2 they say....
After having 5+ sets of speaker, 5+ Amps , lots of subs, cables and sources, REW and an UMIK-1 in my living room over the last 18 months one thing is clear, My room sucks.
I have massive hump between 1 to 5Khz that just makes 2Ch listening unbearable, Yamaha YPAO does settle it down but sucks all the life out of the music. The room needs lots of treatment, that's not going to happen, maybe a little but not to the extent that it needs.
I have been playing around DSP/EQ with JRiver on a PC using
REW with aUMIK-1 over the last week via a Music Fidelity M5si amp and actually got a reasonable result,  it can be better, and has proved to me that DSP room correction does work.
the equipment chain is as follows,
Sources, HTPC, BluRay, CD, HDD Music, Spotify/Tidal (on the Yamaha) into a Yamaha RV-X 1081 used as Preamp only, > Emotiva XPA-5 > either Ambience Superslims 1400 or Quad S5 for the mains, 2 x REL R3 Subs running from the Yamaha in mono via a DSPeaker Anti-Mode 8033 Cinema and stereo line-level in from the Mains (Ambience don't need the subs). Centre is an old Quadal that I still love, the rears are Mirage Omi 350.
for those that aren't
Familiar with the REL subs, they have a .1 RCA input with volume only that you run from the AVR and a Line-Level input with Volume and Freq that you run from the speakers, you can run them both at once and tune them in. Best of both worlds
the Quad S5 with the REL T3 running in stereo via line-level in are my pick ATM, that combo just suits rock a little more
the Ambiences are very picky with the room, so I need to run them both via Dirac to see which ones I keep. Jury is still out on that one, but one set has to go.
the MF M5si is now gone, fantastic amp but it didn't fix the hump (silly of me thinking it might) and had to go to finance the next step
I am not massively into movies much these days, but still enjoy Concerts on Bluray and multi-channel music a bit, the 5.1 system gets used more for Netflix and Tv more than anything and I'm really heavily getting back in to 2Ch, hence the change.
music is mainly Prog rock to Jazz, I don't consider myself a Audiophile, but what to get the best out of my gear.
Budget, about $2.5k tops.
scenario #1
Nad C658 between the Yamaha RV-X 1081 and the XPA-5 on the main chs only, the analogue in on the C658 can be set up as a HT Bypass, so the 5.1 will be basically untouched but 2 ch Spotify/Tidal and HHD music will all be running via the C658. Dirac will be limited to the mains speakers and line level in of the subs only.
but this is probably the best 2ch solution.
cost ~$2300 to $2500 with Dirac full
scenario #2
Nad T758 v3
get rid of the Yamaha RV-X 1081 and replace with the T758 as a pre amp only (maybe use the amp stage for Atmos, but Atmos is not really on the radar ATM)
this will give me a better 5.1 system, allow me to get rid RV-X 1081 and the DSPeaker Anti-Mode.
Hearing rather good reports on the T758 with Dirac as a music pre, but it can't be as good as the C658 you would think (or could it?)  but their feature set is basically the same on both with Bluesound built in for all streaming/HDD duties.
because will sell the RV-X 1081 and the DSPeaker Anti-Mode this could be less that $1500 with full Dirac
scenario #3
Emotiva XMC-1
Emotiva are selling refurb XMC-1 pre's with 4k video and full Dirac for $1100USD, I can go via a friend in the states if they don't deliver to Aust (no Aust distributor listed on their website no more), problem they are out of stock, they were not yesterday, they are today....bummer
replace the Yamaha with the XMC-1 and have a killer 5.1 and 2 ch system but will have to buy something like a Bluesound Node 2i to do the Streaming duties as the XMC-1 does not do that.
selling the Yamaha and DSPeaker Anti-mode might pay for the Bluesound Node 2i, so with delivery it will still cost around $2k
both the Nads are thin on the ground ATM, cant find a C658 to demo but have found a hi-fi store that has the T758 and a C388, they are willing to set both up as 2ch preamps via separate Power amps to see if the T758 holds up as a 2ch pre.
I really like how Spotify runs via the Yamaha, for backgroud music. I can use the Spotify app on my phone and its turns on the Yamaha automatically and plays, this is a big plus to the wife as she hates having to touch any of the remotes or gear, so in a way I want to T758 to sound great because it should operate similar. I really have to make it simple.
the XMC-1 will require turning things on manually via remote methinks.... but there is a Sonus One lying around somewhere if it gets too hard 😉
so, any other options or directions?
which would be your choice?
ta
Marty
Edited by Hytram
I won't touch on your room or treatment at all but from I can see you've had some average sources and average preamps in the mix, shame the MF had to go because long term that may have been your best shot at superior 2ch sound, but I also get why it had to go.
For 2ch I'm with you option 1 should in theory give you the best performance.
But  you also said you like concert movies (as I do) and I'd be surprised if the yammy could do those justice given the same room issues.
that pushes me to number 2 as an all rounder and as a first step, as you've said you get Dirac for both 2ch and surround and you have some money left over which may be used to purchase a Node 2 and an external Dac like a Klein (both in classifieds for around $850) these added should improve the 2ch performance again which is what I've experienced when adding them to my surround set-up.
id forget the emo route, they are refurbished for a reason and I wouldn't like to have a big black box that needed to be shipped os every time it needed warranty support.
If you can accept the 1 year warranty on the XMC1 and o/s servicing the ones on offer are not strictly refurbished but trade ins checked out from people trading up to the new series [Emo are very generous] . The good thing about a XMC1 is with a bad room you can do a REW cal with your Umik  [the XMC1 has a special laptop download that works in concert with REW to use its PEQ ] then after using one of your 2 PEQ presets you can then use dirac on top of it to really knock down any freq humps ..
The other thing about a XMC1 is its 2ch dual differential circuitry which unlike all the alternatives at this price point does not have any single ended circuitry at all ;including my present Yam 5100 . Oh and its got 2 independent sub outs for your REL's ; no cheap spliced single lfe channel
Quote
 The Left and Right main channels are fully balanced with no balanced-to-singled-ended conversion taking place. This is a great feature of the XMC-1 and it was very expensive to include. This allows balanced two channel audiophile listening.  It is also worth noting that this is a pure analog path with no AD/DA conversion, unlike many other products. In fact, the 7.1 inputs are pure analog, which is great for multi-channel SACD listening.
The XMC-1 supports two sets of speaker presets, each of which has 11 bands of independent parametric EQ. The EQ values can be entered manually or they can be imported from the software room-calibration tool Room Equalization Wizard (REW), which can be found on the web.
Heres a review if you decide your comfortable with an o/s option ; whatever your comfortable with counts.
HOMETHEATERHIFI.COM
Emotiva, Emotiva XMC-1, Surround Processor, Preamplifier
I suggest going back to basics and firstly simplifying your 2 Ch music chain, then look at 5.1 and whether it should be integrated together.  While mixing and matching different bits gives you flexibility, it makes for a complicated setup.  Adding any HT gear to the 2 Ch chain will be a compromise.
I do not like Option 1, using the C658 to convert an analogue signal  from the Yamaha for the sake of using Dirac.  The Yamaha has already severely compromised your 2 Ch signal and it is further compromised by doing a A2D stage. The C658 is excellent, but should not be used this way.  Maybe you should redesigning your setup using this as the centre piece?
I have the NAD T758V3 and it is excellent for movies and reasonable for 2 Ch.   If that I was all I had, I could live with it for 2 ch.  If your source DAC is good, it is better to feed the NAD analogue and pay the price for an A2D conversion to enable Dirac to be applied.  The T758V3 should be ok as a prepro, though it will not match a 2 channel preamp for the same price.
p/s  I have a separate 2 Ch system because that is my focus. And my systems are in living room, so appreciate the issues you are facing.
@Snoopy8 with option 1 doesn’t the c658 act as the streamer and 2ch pre with ht bypass directly into the emo amp, which for 2ch would be the cleanest and easiest 2ch path?
A method usually strongly suggested for integrating 2ch and HT systems.
you save me the reply on this one, Option 2, all 2Ch music would not go anywhere near the Yamaha
Yeah, average gear, but has some Amazing loan gear like Arcam Tube CD and Audio Research and Arcam Pre-s which up the sound but didnt solve the problem!
room treatment will be a different thread later down the track, doing Renovations ATM the Louge room will be last
I will regret selling the MF, but money says otherwise
Quote
Agreed
Quote
its not bad believe it or not, the YAPO does an 'OK' job but not brilliant
Quote
have read great things about the Klein but if the Pre in the T758 is no good then its a moot point
Quote
these refurbs are not dead units, they are from their upgrade program, so they are refurb 2nd hand units...actually, whats worse?!
but, yes. the sending back to the US could be an issue, but they do work with you and local repairers for warranty work I believe
I would go with option 2 to simplify things at a lower cost than option 1.
I'm sure option 1 is good but I think it's an overpriced product as NAD will probably sell only a handful of C658's compared to the T758V3 .
Edited by Satanica
thanks for your reply,
the XMC-1 gives me a lot of flexability  but a lot of complexity too
FWIW, the XMC-1 has an excellent DAC, and it isn't that complex to set up. Also, Dirac > YPAO by several orders of magnitude, but you'll have to fork out $100 for a licence to use it with the XMC.
A "massive hump" at these frequencies cannot be caused by "the room".
So you are saying room acoustics can not cause a harsh sound that shows up in a waterfall graph across those frequencies?
Maybe I need to move the elephant first? 😛
Edited by Hytram
Speeling
Yes, if YPAO worked as good as Dirac we wouldnt here.... Actually we probably be in another thread talking about other stuff
I have factored in the $100usd for full dirac in the costings
Everything I have read about the XMC-1 SQ is fantastic, including the DAC.
I wish I could demo the T758 and XMC-1 head to head.. Seeing I am probably not going to leave the digital realm for 2ch for source material it would be great to compare... The XMC-1 would blow the NAD out of the water with 2ch analogue in.
Edited by Hytram
18 minutes ago, Hytram said:
So you are saying room acoustics can not cause a harsh sound that show up in a waterfall graph across those frequencies?
Room sound will (of course) be visible in such a plot.
... but what it won't do, is cause a "massive hump" in the overall SPL between 1 and 5khz.
So... it depends on exactly what you are referring to.
I am probably using the wrong term.. Maybe a massive amount of ringing in those frequencies?
The standard SPL graph in REW is reasonably flat, far from perfect, no massive hump in that range..
In the waterfall graph, between those frequencies the decay time (?) on those frequencies linger far more that any other above 200hz...
Para eq values via REW put into Jriver or even the 10 band EQ in Jriver not only made a huge audio difference, but cut the decay(?)times on the WF graph too..
But the para eq in jriver made the sound compressed, normal 10 band eq and also a 16  band plug in was OK.  (only OK)
After trying an amazing amount of different gear in different configurations, nothing solved the issue, different soundstaging, transparency, musicality and all those good things, but always harsh..
Only 2 things have solved it so far.. DSP and the Mirage Omi 350.. They have their midrange angled up at 45 degrees, problem went away, crap imagining and an average sounding speaker though..
So with that thought, Puting blocks under the front of the Quad S5, ambience ribbons and a pair of Martin Logans to angle them up a bit reduced the problem, but reduced the soundstage too.
Edited by Hytram
Removing naughty words
Agree, I think the c658 is overpriced too, hard to tell if it’s Dirac making these products appear good or the unit itself.
for my money I’d be looking at the minidsp Dirac products too, some cost effective options there.
All these things are foreign to me and I enjoy my sound given my modest setup, do you live in a glass box?
what are the actual problems with the room? Mine is a no symmetrical open ended family room which is far from perfect but the sound is fine for me.
Ive hesitated getting dsp for this type of reason, being obsessed over the dots, dashes and graphs, would do my head in!
I forgot to mention MiniDSP , I have looked seriously into them, the Dirac enabled SHD was a contender, it would have fit in the same as the C658 but it has no HT Bypass. its about $1800 AUD delivered
with its 4 outputs I could have played around with by-amping which is something I have always wanted to play with
or using a DDRC-24 or DDRC-88A in line between the Yamaha and XPA-5 was an option but the Yamaha would still be there and that is one of the weak points in the 2ch setup
I dont know what the actual problem is, except everything else has been changed and the issue stays
5mt wide, 8mt long
Front wall is rendered brick
rest is plaster
back wall has large glass covered painting on it, probably doesn't help
bay window on one side closer to the front 1/3
2.5mt opening on the other side closer to front 1/3, room in there is floorboards
carpet everywhere except last 1.5mt which is floor boards
I wasnt going to bring any of this up yet as the room will be remodelled in 12 -18 months, I can do diffusion panels on the brick wall (behind speakers) but not much else unless its hidden
the advantage with Dirac, it does most of it for you, but you do know have to drive A PC
5mt wide, 8mt long
rest is plaster
Doesn’t sound horrendous maybe apart from the brick front wall but I’m no acoustics expert!
That's important going forward and its in the interests of brands like NAD too . The XMC1 is locked to a proprietary version of dirac live and those with dirac2.0 apart from the enhanced 2ch phase correction algorithm is designed to make easier upgrades in the future like the new sub bass management module coming out [ not that this applies to Martys problem per se];) They have said 1 upgrade a year ; however unlikely..
Chances are the old design t758 will be on runout when the new upgraded T778 turns up very soon ; as will the 777v3 both handily with bluos etc :)
what does this really mean to a maybe purchaser of a xmc-1?
does it give us an inferior Dirac, or just what is out there now with no upgrades?
The reason Dirac introduced 2.0 was to amalgamate all the different proprietary solutions like Arcam ;NAD and Emotiva have into 1 simplified code set going forward so they could implement add ons like the sub bass management tier system more easily :)
Really there is little difference between Emo's and 2.0 at the moment but I wouldn't expect any improvements going forward as Emo now has the RMC1; XMC2 etc to accept the new 2.0 [when it turns up ; they are still waiting for a non beta code from Dirac :whistle: just like Arcam wont launch  Dirac until sometime next year for their new lineup..]
Also a factor is the XMC1's Momentum data system /texas instruments architecture which is different to the new line ups so complicating any modular additions to the old line I suspect ?
to throw another one into the mix..
I only realised last night that I should have  40% discount card on Emotiva Processors on file with them from when I bought the UMC-1 off them years ago, they a looking into it
it cant be used on the Refurb XMC-1 but can be used on the XMC-2 which will be around $3K to $3.3AUD (depending on duties/GST) landed
the XMC-2 has Dirac "coming soon" and as EQ that works with REW.
XMC-2 is probably a better unit (hardware-wise) than the XMC-1 (which I have).  There are some fundamental differences that may mean it doesn't suit: it only has XLR outputs, and no 7-channel inputs.  It also has the same firmware as the RMC-1 and nobody seems completely happy with that even this far down the track.
And of course no Dirac yet: "soon" has no strictly temporal meaning when it comes to Emotiva, it is simply a tensed term that means "after today".  It could be delivered next week or the Earth could spin into the sun before it arrives.
    • By NADbooffa
      Price: $375 Item Condition: 9/10 used but immaculate Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Vermont (VIC 3133) State: Victoria Payment Method: Cash on Pick Up, Paypal (buyer to pay the fees), EFT Reason for selling: No Longer Needed Further information:    This immaculate condition NAD Sorround Sound Receiver is now ready to go to a new home. Bought from Klapp Audio (Prahan) and well looked after since new. Always stayed in my Hi-Fi rack and comes from a smoke and pet free home. I have the original box so this can be sent via courier if the buyer can organize the transportation.
      NAD, the highly regarded manufacturer of high-performance audio components, incorporating NAD's ""Music First"" philosophy as the cornerstone to their ambitious design goals for this T 762 made in England.
      The T 762 offers Dolby Digital, Dolby Digital EX, DTS, DTS-ES, and DTS Neo:6 decoding, along with 7.1 Matrix, Dolby Pro Logic, Dolby Pro Logic II, and the proprietary NAD EARS circuitry for creating natural surround sound from any format input, 7.1, 6.1, 5.1, and 2.0 stereo, digital or analog. Also included is an HDCD decoder plus a ""Stereo Enhanced"" mode that uses no processing, but allows the stereo signal to be sent to any or all of the selected 7.1 channels, depending on listener preference. There is also an analog bypass mode for stereo purists. Surround processing is automatically detected via the digital inputs, and the most appropriate decoding format is switched in. Conversion of the decoded digital bit stream is performed with high resolution and extremely linear D/A converters, carefully selected for their performance capabilities.
      The EARS (Enhanced Ambience Recovery System) circuitry uses DSP technology to extract the natural ambience in a stereo recording and redirect it to the surround channels, creating a warm, natural reverberant effect without any artificiality.
      Full Disclosure Power rating, with all channels driven simultaneously, at any frequency from 20 Hz to 20 kHz, with less than 0.08% THD at 8 and 4 ohms. Also specified is Dynamic Power at 8 ohms, 4 ohms, and 2 ohms. The T 762 delivers 100 watts per channel of continuous power with all six channels driven simultaneously at rated distortion into 4 or 8 ohms. Dynamic power is rated at 300 watts into 2 ohms.
      Five A/V presets can be stored for instant recall with unique speaker configuration, level, distance, surround mode, and tone control settings for instant recall. This allows a user to set up one type of playback for multichannel music and a completely different setup for movie soundtracks. Channel volume settings for sub, center, and surround channels can be adjusted on the fly without entering any setup menus.
      Pick up (VIC 3133) is preferred, but I can package it up for the buyer to arrange own transport arrangement.
      NAD HTR 2 Remote is included.
    • By Hi-Fi Whipped
      Price: $ Item Condition: As New Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Sunshine Coast State: Queensland Payment Method: Paypal+3%, Bank Transfer, Cash on Collection Reason for selling: Great Product, it's just me! Can Ship to most cities for $30.00
      RRP$2599
      3 weeks old, AS NEW Impeccable condition with all accessories most still in the plastic, suit new buyers.
      You can see my posts in the owners thread about how I found the C658 in use. But basically this thing is extremely powerful, Dirac is a game changer for sure and it seamlessly integrated my subs with my fronts which was the main reason I purchased it, so that box was ticked.
      For years I have listened to my music without any eq or bass or treble, I've been all about tweaking placement of speakers etc. to get the most out of my gear.
      The eq capabilities on this thing are insane, you seriously feel like you have your own recording studio,  you can tweak the sound to within an inch of its life which for some would be heaven, but for me its made me a little obsessive compulsive! I know for a fact that if I invested more time in getting the sound right I would definitely get there but given where I've come from I'm making a gut call early and going back to the basics. What that is I'm not entirely sure at this stage but will see if this gets snapped up and go from there.
      Anyone that's ever brought things from me knows I look after my gear probably better than my kids so be assured this unit is in impeccable condition, not a mark on it, and comes from a smoke free home.
      WARRANTY - Balance of 2 year warranty (Owned for 3 weeks) will be transferred to new owner.
      Link to the SNA Owners Thread:
      Photos: Advertisements without photos of the actual item will not be approved.ell
    • By Hi-Fi Whipped
      This unit has been mentioned in a number of threads so a couple of us thought it was time for a dedicated thread for users to share experiences and tips and also general discussion providing it stays on topic.
      NAD C658 BluOS Streaming DAC with Dirac Live integration
      Manufacturers Product Page: https://nadelectronics.com/product/c-658-bluos-streaming-dac/
      Dirac Live Website: https://live.dirac.com/
      Front
      Rear
      Features & Details
      BluOS Network Streaming with MQA Decoding ESS Sabre DAC Dirac Live Room Correction Gigabit Ethernet Dual Band Wi-Fi AC/N 2 Way Qualcomm aptX HD Bluetooth 2x MDC Slots for Future Expansion MM Phono Input 2x Line Inputs, 2x Optical inputs, 2x Coax Inputs Balanced Preamp Output Preamp Output Stereo Subwoofer Output USB Socket for adding optional Wireless Output Module IR In with Learning Function Trigger In/Out
      Dirac Live Reviews & Guides
      https://audiophilestyle.com/ca/reviews/dirac-live-2-digital-room-correction-software-walkthrough-r884/
      Nad C658 Product Reviews
      https://hometheaterhifi.com/reviews/amplifier/nad-c-658-bluos-streaming-dac-review/
      https://www.soundandvision.com/content/nad-c-658-network-audio-playerpreamplifier-review
      https://www.whathifi.com/reviews/nad-c-658
      https://www.stereo.net.au/reviews/nad-electronics-c-658-streaming-dac-preamp-review
      Nad C658 Video Reviews
    • By j_davis_1980
      Item: NAD C325BEE stereo integrated amp 50 W per ch 8ohms.
      Price: $250
      Item Condition: good
      Reason for selling: NLR
      Extra Info: A nice sounding amp in good condition. Original remote included. I don’t have the box, hence no shipping.
