MixedBag
FS: The Beatles - Sgt. Pepper’s Lonely Hearts Club Band. Original Master Recording MFQR 1-100
Item: The Beatles
Price: $900 ONO (reasonable offers only please)
Item Condition: Vinyl NM, Box/cover VG+
Reason for selling: Someone else will appreciate this more...
Payment Method: Pickup - Cash, Paypal, or bank transfer
An Original Master Recording
UHQR by Mobile Fidelity Sound Lab
Limited edition no. 2079 (of 5000)
No certificate of authenticity unfortunately.
Will be posted with signature for $25, Australia wide.
    • By AudioTrends
      Item: Quad II-Eighty Power Amplifier - 80 Watt Mono Valve Power Amplifiers (Pair)
      Price: $9,500 was $14,999
      Item Condition: Demonstration Model
      Reason for selling: It is the last model and needs to be moved.
      The Quad II-Eighty Mono Valve Power Amplifiers are some of the most richly rewarding audio components you will ever lay ears on. From the company that bought you the electrostatic speaker, Quad continues it's tradition of 'The Closest Approach To The Original Sound'.
      The range topper of the Quad Valve power amplifier series is the Quad II-Eighty amplifier. The perfect partner to Quad’s electrostatic speakers, the II-Eighty is not merely a nod in the direction of retro styling, it’s a modern high-performance amplifier designed by one of the most famous tube-amplifier designers in the world using more than a little inspiration from the original Quad II amplifier.
      The new Quad II Series circuit design is the work of Tim de Paravicini, a man widely acknowledged to be the UK's foremost valve amp designer. His design is faithful to Peter Walker's philosophy of cathode loading onto the same output stage and fundamental simplicity of design, ensuring the new amp delivers the same wealth of detail and exquisite tone as its famous predecessor.
      The Quad ll-Eighty is an 80 watt mono power amplifier following in the tradition and philosophies of Quad founder, Peter Walker. The output section consists of four KT88 valves running as two pairs in push pull with the hallmark Quad topology of partial cathode loading in the output transformer.
      This method reduces distortion when compared to the usual Ultra Linear or triode methods, however, it does require a greater grid driving voltage. This is achieved, again in true Quad fashion, using a balanced pair input stage.
      The output transformer has been designed to improve high frequency performance and accurately balance the two push pull halves. Also the transformer has been designed to make sure that full output is realised at the bass frequencies down to 20Hz.
      Each output valve has its own cathode resistors to provide reliability and self-matching. The screen grids of the KT88 valves are run from a lower voltage, again for good reliability. The whole amplifier has a total of only 16 dB of feed-back providing good stability into virtually any known loudspeaker and especially the famed Quad electrostatic loudspeakers.
      Features:
      Design: Mono Valve Power Amplifier Input Sensitivity (nominal): 1V RMS for full output Power Output: 80W RMS Output Impedance: 4 Ohms or 8 Ohms, selectable THD @ 80 Watts: 0.5% - 30Hz - 15kHz 1.0% - 20 - 20kHz Residual Hum and Noise: Better than -94dB Frequency Response: 10Hz - 30kHz (+0dB, -0.5dB) 3Hz - 50kHz (-3dB) Damping Factor: 16 @ 1kHz (referred to 8 Ohms) Power Consumption: 180VA maximum Valves: 2 x 6SL7 1 x 6SN7 4 x KT88 Size (WxHxD): 430 x 220 x 190mm each Weight: 20.3kg each Finish: Lancaster Grey Manufacturer's Warranty: 2 Years
    • By AudioTrends
      Features:
    • By Muzza71
      Item:  Tauris Georgia HiFi Stand 4 Tier Shelf Tempered Glass
      Price: $100
      Item Condition: Very Good
      Reason for selling: NLR
      Some light swirl marks and scratches but nothing to obvious.
      750mm Height 650 Depth 500mm Wide
      470mm between inside posts
      450mm deep to rear frame.
      245mm bottom shelf height
      200mm middle shelf height
      210mm top shelf height
      Shelves be can interchanged.
      The rear frame has been opened up to accommodate different terminal positions on amplifiers and source components on 2 shelves.
      The bottom shelf has 6mm rubber sandwiched between two perspex glass plates to assist with sound absorbsion/isolation.
      Bottom shelf weight limit 45kg, other shelves 25kg.
    • By Muzza71
      Item: Speaker Stands 735mm High - Tempered Glass
      Price: $50
      These can be filled with your preferred sound deadener/Absorber.
      735mm high including spikes, perfect for smallerish bookshelves around 300mm in height
      Top plate D 180mm x W 150mm x 8mm thick
      Bottom plate D 300mm x W 220mm x 8mm thick
    • By bdavis84
      Item: KRIX Phoenix Floorstanding Speakers
      Price: $600
      Item Condition: Like New
      Reason for selling: Downscaling
      Extra Info: 2 small holes in one of the speaker mesh. Otherwise great condition. Barely used over the past 7 years. Also includes quad braided speaker wire valued at $25 pm.
