Dimitri K
TANDBERG HI-FI SPEAKERS 112-7
Item: TANDBERG HI-FI SPEAKERS 112-7
Price: $380
Item Condition: Excellent condition
Reason for selling: Not using
Tandberg 2-Way Speaker System Model Hi-Fi System 112-7.
Extremely rare, Vintage wooden case, 60 - 16000 Hz, 3,2 ohms, Made in Norway.
    • By Sound Gallery
      Item: Marten Duke 2 Bookshelf Speakers in Piano Black with Original Marten Stand
      Price: On Hold (Combo RRP is $14850)
      Item Condition: As new condition for both speakers and Stand. Comes with all original box, paper and accessories for the speakers. Unfortunately no box for the stands but will be well packed if needed.
      Reason for selling: Customer Upgrade
      Payment Method: Pickup - Cash, Paypal + fee or direct deposit
      Taken from Marten website:
      Duke 2 Stand up and be counted.
      Simply one of the world’s greatest stand speakers, Duke 2 is true to the spirit of Heritage. The classic design of its cabinet and controlled sound, make it the perfect start-up model for your high-end system.
      What you get Great things come in small(er) packages. The Duke is a 2-way system, comprising a newly developed 7″ ceramic bass/mid-range driver and a new tweeter, which uses pioneering technology to achieve diamond-like performance.
      A must for the true audiophile with a modest listening space.
      2-way ported Mundorf enhanced crossover Accuton bass drivers Cell tweeters
      Features Greater than the sum of its parts Cell tweeter designed with the latest Accuton technology. Bass drivers with higher transparency and resolution using the latest Accuton technology. Improved crossover using leading Mundorf components.
      Internal wiring Premium cables for purer sound. We use Jorma Design internal wiring, for its exemplary quality and performance. Handmade in Sweden, the cables use separate + and – for enhanced shielding and the highest quality Copper.
      This offers natural, transparent sound; the perfect choice for our speakers.
      Cables are integral components, so they must work harmoniously with our precision design and build. Jorma Design delivers exactly what a Marten speaker demands.
      Your space Music as refined as your home. Music is your environment, as much as your sofa or the pictures on your wall: it enhances the space around you. The Heritage series fits seamlessly in to your home, giving you visual appeal as well as award-winning sound.
      Technical specifications
      Speaker (front)
      1 x 7 ” Ceramic unit
      1 x 1 ” Ceramic unit
      Frequency range
      38-40 000 Hz ±3dB
      Power rating
      150 W
      Sensitivity
      88 dB/w/m
      Impedance
      4 ohm (3.7 ohms min)
      Type
      2-way ported (39 Hz)
      Crossover frequency
      Second order, 3000 Hz
      Components
      Low loss copper foil coils and silver/gold in oil capacitors
      Terminals
      Single-wiring WBT
      Internal wiring
      Jorma Design
      Cabinet
      23mm veneered MDF
      Dimensions W x H x D
      22 x 40 x 33 cm (8.6 x 15.7 x 12.9 ”)
      Net weight
      13 kg (29 lbs)
    • By Sound Gallery
      Item: ATC SCM 19A FLOORSTANDING SPEAKERS in Cherry (Ex demo)
      Price: $5300
      Item Condition: Ex demo speakers. Comes with all original paper and accessories, no box but will be well packed if delivery is needed.  There is a dent on one of the speakers as pictured.
      Reason for selling: Rotate Stock
        SCM19A
      Overview
      New ATC designed and built dual suspension 25mm soft dome HF unit with precision alloy wave guide. “SL” spec bass driver with 75mm integral Soft Dome. 9kg optimised short-coil/long gap motor assembly. On-board grounded source 182 watt Class A/B Bi-amplifier. Active crossover filters and overload protection. 6 year warranty. Specifications: Drivers: HF ATC 25mm dual suspension Tweeter, Mid/LF ATC 150mm SL
      Matched Response: +/- 0.5dB
      Frequency Response (-6dB): 54Hz-22kHz
      Dispersion: ±80° Coherent Horizontal, ±10° Coherent Vertical
      Max SPL: 108dB
      Crossover Frequency: 2.5kHz
      Connectors: Male XLR
      Input sensitivity: 1V
      Filters: 2nd Order critically damped with phase compensation
      Overload Protection: Active FET momentary gain reduction
      Fault Protection: DC fault protection and thermal trip. Fault indication on rear panel mounted LED
      Amplifier Output: 150W LF, 32W HF
      Dimensions (HxWxD): 980 x 370 x 344mm (inc. foot plinth & amp, spikes add 25mm to height, grill adds 34mm to depth)
      Weight: 31kg
    • By beetle-audio
      Item:  Antipodes DX Gen 3 with 2TB SSD (Black) Relist
      Price: $4800 including freight anywhere in Australia
      Item Condition: Used but in perfect condition. Comes with original box, manual and power cord.
      Reason for selling: NLR
      Payment Method: Pickup or deliver at cost - Direct Deposit, Cash or Paypal + charges.
      I don't think this unit need any introduction. This is the last and latest of the DX model. I love the idea of one unit with the drive built in which makes it less messy with cables. There are already some HD music in the unit itself if the new owner decide to keep. As a Roon core it works perfectly with the unit and highly recommended for the beautiful and easy to control interface.
    • By beetle-audio
      FS: Sennheiser HD800S & HDVD800 DAC & Headphone amp combo
      Price: $2700 (RRP$5398)
      Item Condition: As new with original packaging. Will throw in aluminium headphone stand and better cable cable if sold at the asking price.
      Info below taken from Sennheiser website:
      SENNHEISER HD800S AUDIOPHILE HEADPHONES
      A modern classic, Sennheiser’s reference class HD 800 headphones deliver sound that is as natural as possible and true in every detail. Improving on a seemingly perfect formula is not a task undertaken lightly, but Sennheiser’s engineers have succeeded in enhancing still further the sound reproduction in the open, circumaural HD 800 S.
      SENNHEISER HDVD800 DAC AND HEADPHONE AMPLIFIER
      With Sennheiser's HDVD 800, sound is perfect. The HDVD 800 is able to connect with digital sources and is equipped with a high-quality Burr-Brown digital/analog converter (DAC) that converts digital audio data into analog signals with a resolution of 24 bits and a sampling rate of up to 192 kHz.
    • By sakabatou
      Item: Oyaide Neo D+ USB 2.0 Class-S Cable (1m) A-B
      Price: $50 + postage if required
      Item Condition: Excellent used condition with packaging
      An excellent budget upgrade cable
      https://www.storedj.com.au/oyaide-neo-d-usb-2-0-class-s-cable-1m
      Item: QED Reference HDMI Cable 1M
      Price: $120
      Also an excellent i2s cable for the LVDS format
      https://www.deniswhitehomecinema.com.au/qed-reference-high-grade-hdmi-cable.html
      Item: SUPRA HD5 High Speed HDMI Cables 0.5m length
      Price: $60 + postage if required
      Short length makes it perfect for use as an LVDS i2s interconnect
