Mantra1
Sony 55-inch A8G 4K UHD OLED
8 hours ago, Mantra1 said:
Is this a good price for Sony OLED TV and are there any opinions?
https://www.harveynorman.com.au/sony-55-inch-a8g-4k-uhd-oled-smart-tv.html
Thanks.
I'd buy this before that.
$100 cheaper.
https://www.harveynorman.com.au/lg-55-inch-c9-4k-uhd-oled-ai-thinq-smart-tv.html
You want to be sitting pretty damn close for a 55" 4K TV
65" is better.
9 hours ago, ols45 said:
Thanks for the tip. My viewing room is very small, so a 55" would be about right for me. I just thought that Sony OLEDs looked to have the best picture. LG used to have a name for reliability issues, but that was a few years ago now.
LG C9 Oled is fairly widely considered best television in the world.
WWW.TOMSGUIDE.COM
Know what you mean on LG a few years ago.
LuckyifitGoes
Edited by ols45
1 minute ago, ols45 said:
Yep that's the one
Thanks. I'll go down to my local HN and have a look. Is the sound OK.?...the Sony apparently has excellent sound and I don't think I can afford a soundbar as well. Cheers.
I have last years Sony and the sound is great. I don’t use a sound bar.
Also the Sony has best upscaling which is important if you watch FTA channels.
Thanks @Whites With a bit of luck I should be able to compare both Sony and LG side by side. I think I'll just have to live with the sound, it shouldn't be too bad. OK, not as good as a soundbar, but that can be for the future. Must say, I did like the Sony's picture best of all.
