brettwils Posted November 19, 2019 Share Posted November 19, 2019 (edited) SOLD Item: Vincent SP-331 Hybrid Power Amplifier Location: Sydney Price: $750 Item Condition: Perfect Reason for selling: Selling on behalf of my fathers estate Payment Method: Pickup - Cash, Paypal, COD Only Extra Info: Input signal incorporates two 6N16 valves each. There are 12 TOSHIBA transistors provided for the power in each case. The SP-331 can also be operated at 2 Ohm without difficulties. This is a hybrid tube and solid state power amplifier (you will require a pre-amplifier of some description to use with it). Nominal Output Power RMS/8 Ohm: 2 x 150 Watt Nominal Output Power RMS/4 Ohm: 2 x 300 Watt T.H.D.: < 0.1 % (1 kHz, 1 Watt) Input Sensitivity: 1,2 V Signal-Noise Ratio: > 90 dB Input Impedance: 47 kOhm Inputs: 1 x Stereo RCA Outputs: 4 x 2 Speaker Terminal Tubes: 2 x 6N16B Colour: Black Weight: 19 kg Dimensions ( W x H x D): 430 x 160 x 450 mm Photos: Advertisements without photos of the actual item will not be approved. Edited November 20, 2019 by brettwils Changed colour to black in specs 2 Link to comment Share on other sites More sharing options...
jakestar Posted November 19, 2019 Share Posted November 19, 2019 Great sounding amp for the money. Glwts. Link to comment Share on other sites More sharing options...
kurof Posted November 19, 2019 Share Posted November 19, 2019 Bargain great amp! Link to comment Share on other sites More sharing options...
Gremrock Posted November 20, 2019 Share Posted November 20, 2019 Would be perfect for a bass amp for my speaker project if I had some money at the moment haha Looks like a beast/bargain Link to comment Share on other sites More sharing options...
