gaoli99
Dynaudio Excite X32's Floor Standing Speakers in Gloss White
Item: Dynaudio Excite X32's Floor Standing Speakers in Gloss White
Price: $1150
Item Condition: Used; One tweeter was pushed in, please see photo. It's a light film material that is prone to being pushed in. Doesn't affect sound quality at all fortunately. No scratches, chips or dents.
Reason for selling: Upgrading
Payment Method: Pickup - Cash, Paypal, COD Only. I will give preference to a local buyer who can pick up however I have the original boxes so can post at buyers cost. Please ask for a quote if interested.
Extra Info: Purchased new at Jan. 2016 with five years warranty. Comes with original packaging.
Hi I saw a salesman in a Hifi shop years ago suck a speaker that was pushed in by a kid out with a vacuum. Looked perfect after he had done it.
May need to make sure the nozzle is bigger than the part being sucked out so it doesnt damage it. Good luck.
Its easy to fix the tweeter - get a bit of sticky tape and gently affix the tape to it and pull it out gently.  I did this my Dynaudio speaker tweeter too when my little daughter pusher her finger at the tweeter dome!
It is easy to fix with a vacuum.
The sticky tape didn’t work for me, was worried that a vacuum cleaner would be too much but had success by sucking it out with short plastic straw.
empty paper towel roll over it and suck or toilet paper i guess
Sticky tape will remove the coating. It's best to stick to as mild a suction as will do the job. Someone should 3D print or otherwise manufacture guards for these - in the US some of the hifi guys use the wire guards from the Pro series speakers from a friendly Dynaudio rep who will sell them to them. Given that many of the Dyn listings have this characteristic it seems like a needed development.
Thanks to all for the suggestions.
Thanks all. The pushed in tweeter has been sucked out by using cardboard tube.
    • By Mick08
      Price: $2999 Item Condition: Great Condition Shipping Options: Pickup is available Suburb or Town: Pakenham State: Victoria Payment Method: Cash on Pickup or delivery Reason for selling: Upgrading complete system Further information:  For sale are 3 x Klipsch KL-650 speakers. These have been used sparingly in a home theatre room.  One speaker has a small scuff on the top back right hand side that you can see in one of the photos. Other than that they are in perfect condition and working order.
      I am more than happy to demo for anyone that is interested in buying and I can deliver Melbourne Metro at no charge
      Overview
      As the larger of the two LCR speakers in the Ultra2 family, the KL-650-THX features a front-firing port for low bass extension dual 6.5-inch Cerametallic™ woofers and a 6- by 10-inch Tractrix® Horn Tweeter. The tweeter driver is a 1-inch titanium-dome compression unit designed specifically for use with horns to provide high output with low distortion. The clarity and distinction of this LCR can also be attributed to its top-of-the-line internal wiring.
      The KL-650-THX enclosure has the same dado and rabbet construction used in Klipsch professional speakers ensuring cabinet integrity in suspended applications. The Omni-Mount suspension points on this loudspeaker facilitate wall or ceiling mounting using standard hardware.
      Available in a custom Galaxy black finish with an aluminum fascia the KL-650-THX delivers the ultimate in power detail and emotional impact from durable easy-to-install cabinets.
      Klipsch KL-650-THX Features:
      Front-firing port for low bass extension Dual 6.5-inch Cerametallic woofers 6- by 10-inch Tractrix Horn Tweeter with 1-inch titanium-dome compression driver Top-of-the-line internal wiring Frequency Response 48Hz-20kHz ± 3dB Sensitivity 97dB @ 2.83 volts / 1 meter Nominal Impedance 8 ohms compatible High Frequency Crossover 1400Hz Power Handling 150 watts maximum continuous (600 watts peak) Enclosure Type Bass reflex via front-mounted port Enclosure Material Medium density fiberboard construction (MDF) Tweeter 1″ (2.5cm) magnetically shielded titanium dome compression driver with 9.6oz ceramic magnet structure High Frequency Horn 10″ x 6″ rectangular 90°x 60 °Tractrix® Horn Woofer Two 6.5″ (16.5cm) magnetically shielded, Cerametallic™ cone, cast aluminum frame drivers Inputs Two sets of binding post speaker terminals (connected via brass strap jumpers) Dimensions 15″ (38.1cm) H x 17″ (43.2cm) W x 12.5″ (31.8cm) D (w/grille) Weight 39 lbs. (17.7kg) Finish Galaxy Black cabinet with Black anodized aluminum fascia Mounting 4-bolt pattern 1/4″-20 thread Photos: Advertisements without photos of the actual item will not be approved.
    • By Wood
      Price: $2300 Item Condition: Mint Shipping Options: Audition is not available, but in-person pickup can be arranged with limited personal contact,I can ship this item Suburb or Town: 2113 State: New South Wales Payment Method: EFT / PayPal / Cash Reason for selling: No Longer Required Further information:
      Purchased this from a fellow forum member late last year.
      Made an immediate improvement to my system, but I'm only using it as a power amp via HT bypass so the pre amp section is going to waste.
      I have played some music via USB and love the sound with my KEFs, but 90% of the time I'm watching a movie so want to move to a multi channel power amp like an Elektra.
      Is in mint condition.
      Comes with all the original packaging and accessories - bag, white gloves, remote, manual and polishing cloth.
      Still has warranty on it and can send original sales receipt from the first owner.
      Will be triple boxed if shipping is required.
      I will cover courier and insurance costs.
    • By Janjuc
      Price: $2100 Item Condition: Very Good ++ / Excellent Shipping Options: Audition is not available, but in-person pickup can be arranged with limited personal contact,I can ship this item Suburb or Town: Torquay State: Victoria Payment Method: Paypal (Friends + Family) or +3%, Cash, EFT Reason for selling: Rationalizing System Further information:
      Current equivalent EVO100 selling for $3400
      I have had this amp for about 4 years, the current tubes have around 400-450 hours of use. It has a small chip on the body at the back of the unit
      Excellent build and sound. Tubes included are Sylvania SV6L6GC, JAN 2 x 5814 and Primaluna  2 x 12AX7
      Has Adaptive Auto Biasing, and you can use 6550, KT90, EL-34, KT77, 6CA7, 6L6GC, KT66, 7581, EL37, and any of their equivalent power tubes.
      Hand made point to point wiring.
      Lots of reviews online.
      Shipping at cost and buyers risk, pickup preferred by mutual agreement.
      If picked up I will add a new set of tubes and a cover for the amp, value about $300+
      JJ
    • By onairpic
      Price: $250 Item Condition: Very Good Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Sydney (North Shore) State: New South Wales Payment Method: Paypal (plus 3%), Cash on Pick, Bank Transfer Reason for selling: NLR Further information:
      The SubSonic 5i has more power and a larger bass unit than the SubZero i. It also has a very different Class H design for its power amplification. Class H is a special high efficiency amplifier design. Briefly, audio amplifiers are inherently inefficient because they are designed to have the capability of delivering great output power yet spend most of their life delivering fairly low power. Their output devices must deliver current while withstanding the high power supply “rail” voltages needed for peak outputs. With a Class H design the rail voltages are not constant. They swing high when the music demands it and stay low during quiet passages. This is achieved by a sophisticated high frequency switching power supply. Power dissipated as heat is greatly reduced and more power is available per dollar of cost. A second benefit is that they tend to have high peak power relative to their steady state power. The SubSonic 5i, for example, has 150 watts continuous but is capable of 450 watt peaks. The result is a subwoofer capable of the great transients required by dynamic music and explosive sound effects.
      More info can be found in http://www.psbspeakers.com/products/subwoofers/SubSeries-5i-Subwoofer#heading-downloads
    • By Conch
      Item:  ATC SCM40
      Price: Removed from sale
      Item Condition: Excellent
      Reason for selling:
